									Ecodan - rubbish data - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-rubbish-data/</link>
            <lastBuildDate>Wed, 15 Apr 2026 22:34:08 +0000</lastBuildDate>
                        <title>RE: Ecodan - rubbish data</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-rubbish-data/#post-16525</link>
                        <pubDate>Sun, 19 Feb 2023 12:39:53 +0000</pubDate>
                        <description><![CDATA[Thanks @HarriUp. I&#039;ll look into those, I have also been looking at the Open Energy Monitor.
Cheers
Gavin]]></description>
                        <content:encoded><![CDATA[<p>Thanks @HarriUp. I'll look into those, I have also been looking at the Open Energy Monitor.</p>
<p>Cheers</p>
<p>Gavin</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Gfletcher</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-rubbish-data/#post-16525</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-rubbish-data/#post-16498</link>
                        <pubDate>Sat, 18 Feb 2023 18:38:30 +0000</pubDate>
                        <description><![CDATA[Yep, the self-measurement of the Ecodans is highly inaccurate. For January mine gives me a consumed estimate of 687kWh against a metered value 631kWh.
If you want an accurate value you&#039;ll n...]]></description>
                        <content:encoded><![CDATA[<p>Yep, the self-measurement of the Ecodans is highly inaccurate. For January mine gives me a consumed estimate of 687kWh against a metered value 631kWh.</p>
<p>If you want an accurate value you'll need a meter on the supply circuit. It will depend how much you are happy to intervene in the the wiring arrangements. A straight forward meter inserted into the supply circuit (https://metersuk.co.uk/products/single-phase-electric-the-tiny/) will give you an accurate record but one that you will have to read yourself as and when. I have my circuit wired through an Eastron SDM120 meter mounted next to the consumer unit which then feeds a value into an OpenEnergyMonitor setup which records and displays the energy consumed via computer/phone. If you don't want to rewire the mains at all you could go with a CT clamp-based arrangement where a circular magnet is clamped around the live wire inside the consumer unit (eg https://metersuk.co.uk/products/single-phase-electric-meter/).</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-rubbish-data/#post-16498</guid>
                        <title>Ecodan - rubbish data</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-rubbish-data/#post-16492</link>
                        <pubDate>Sat, 18 Feb 2023 17:28:29 +0000</pubDate>
                        <description><![CDATA[Hi,
I have an Ecodan 8.5kW ASHP - I have been logging data from the FT6 display (I don&#039;t have Melcloud) manually and keeping track of daily household energy use, and the information just do...]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>I have an Ecodan 8.5kW ASHP - I have been logging data from the FT6 display (I don't have Melcloud) manually and keeping track of daily household energy use, and the information just doesn't seem to tally. I suppose I shouldn't mind so much, but I would like to understand more accurately how much electricity the unit is using. </p>
<p>An example of the sort of data that is being generated - for January the FT6 is saying that the heatpump consumed 402kWh of electricity for both DHW and heating. The delivered energy was 902 giving a COP of 2.24. My total household energy use was 488kWh for January. Therefore if I take the consumption data that means that on average the heatpump was using 13kWh a day (not unreasonable) and the rest of the house was using 2.8kWh a day (4 bed house with 2 adults working from home and 2 teenagers). The total household energy use is correct - that is what I am billed! Pre-heatpump my average household energy use across the whole year was 5.6kWh a day. Is there anything I can do with my existing setup to improve the accuracy of reporting, or do I need to look at a 3rd party system to record actual use? Any pointers would be helpful.</p>
<p>Cheers</p>
<p>Gavin   </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-rubbish-data/#post-16492</guid>
