									Ecodan Melcloud temperature control with compensation curve - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/</link>
            <lastBuildDate>Fri, 15 May 2026 02:35:19 +0000</lastBuildDate>
                        <title>RE: Ecodan Melcloud temperature control with compensation curve</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16305</link>
                        <pubDate>Mon, 13 Feb 2023 09:25:55 +0000</pubDate>
                        <description><![CDATA[@kev-m 🤣 🤣 🤣]]></description>
                        <content:encoded><![CDATA[@kev-m 🤣 🤣 🤣]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16305</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16291</link>
                        <pubDate>Sun, 12 Feb 2023 19:18:51 +0000</pubDate>
                        <description><![CDATA[@derek-m thanks. The balancing was done by an accredited (by Ecodan) air source heating engineer. I am not sure what a lock shield valve is) but if it is fitted at one end of the radiator, y...]]></description>
                        <content:encoded><![CDATA[<p>@derek-m thanks. The balancing was done by an accredited (by Ecodan) air source heating engineer. I am not sure what a lock shield valve is) but if it is fitted at one end of the radiator, yes.  We have TRV valves. The WC curve settings are 45 c/30c</p>
<p>The heat loss calculation was 12KW, since when we have improved insulation </p>
<p>Our House is a 4 bedroom detached house on two storeys, built in about 1920. The floor area is about  240 sq metres, so quite big</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Dotty9943</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16291</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16290</link>
                        <pubDate>Sun, 12 Feb 2023 19:02:27 +0000</pubDate>
                        <description><![CDATA[This is much harder now! A few questions:
Are you letting WC control room temperature or are you using thermostats; either Mitsubishi or 3rd party?  Is the ASHP running all the time or is o...]]></description>
<p>@kev-m Now that you have solved the problem of temperature readings, this has enabled me to move on to the next stage of my attempts to find out why my heat pump is achieving such poor COP scores (They are about 2.3 when the predicted score is 3.2 and better.  We have done the following without much progress</p>
<p>a. On the basis of the Ecodan recommendations following a heat loss study, we have up graded all our radiators</p>
<p>b. We have replaced doors and windows so that all our doors and windows are now double glazed</p>
<p>c. We have put new thicker insulation in our loft</p>
<p>c. We have put throttles in our chimneys</p>
<p>d. Our radiators were rebalanced last week</p>
<p>e. We have set weather compensation so that flow temperature is at the recommended level</p>
<p>f. The heat loss study confirmed that our 14 kw is big enough to heat our. House and compensate for the heat loss</p>
<p>G. The system was serviced in December, when the filters were cleaned.</p>
<p>My web researches don’t suggest any other explanation for poor efficiency so can any one come up with new ideas?  Failing that I don’t know what to do short of taking our heat pump out and starting again with an efficient combi boiler</p>
<p>This is much harder now! A few questions:</p>
<p>Are you letting WC control room temperature or are you using thermostats; either Mitsubishi or 3rd party?  Is the ASHP running all the time or is off/cooler some of the time </p>
<p>What sort of flow temps do you have at, say 0 and 5 degrees outside? </p>
<p>Are you including HW in your numbers?  If so, how hot and do you use a lot?</p>
<p>Do you have different zones in the house that are on and off at different times, or do you use TRVs a lot?</p>
<p>Do you have a buffer or low loss header?</p>
<p>I have a 14kW Ecodan and my January COP for heating and HW is about 3.1 so far. 2.3 is a bit low but it depends how you are using it.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16290</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16289</link>
                        <pubDate>Sun, 12 Feb 2023 18:49:41 +0000</pubDate>
                        <description><![CDATA[I am devastated. 😪 
It would appear the &#039;peasant&#039;s are revolting&#039;, but then they always have been. Have you been &#039;eating cake&#039; again? 😋]]></description>
<p>Oh @kev-m you star you 😘🤣</p>
<p>@dotty9943 I’m glad you’re on the up 👍</p>
<p>I was fed up of Derek getting all the plaudits, this is just the start for me!! 😆 </p>
<p>I am devastated. 😪 </p>
<p>It would appear the 'peasant's are revolting', but then they always have been. Have you been 'eating cake' again? 😋 </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16289</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16288</link>
                        <pubDate>Sun, 12 Feb 2023 18:43:36 +0000</pubDate>
                        <description><![CDATA[Low efficiency can be caused by incorrect WC settings, also using on - off type thermostats. Having a buffer tank, low loss header or plate heat exchanger can also have a detrimental affect....]]></description>
<p><strong>Who re-balanced the radiators? Was it done using the lockshield valves? Do you have any TRV's fitted?</strong></p>
<p><strong>What are the settings of the WC curve?</strong></p>
<p><strong>What are the heat loss calculations for your home? What type and size is your home?</strong></p>
<p>Low efficiency can be caused by incorrect WC settings, also using on - off type thermostats. Having a buffer tank, low loss header or plate heat exchanger can also have a detrimental affect. Do you have any of the above installed?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16288</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16287</link>
                        <pubDate>Sun, 12 Feb 2023 18:39:20 +0000</pubDate>
                        <description><![CDATA[I was fed up of Derek getting all the plaudits, this is just the start for me!! 😆]]></description>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/paged/2/#post-16287</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16286</link>
                        <pubDate>Sun, 12 Feb 2023 18:07:07 +0000</pubDate>
                        <description><![CDATA[@kev-m Now that you have solved the problem of temperature readings, this has enabled me to move on to the next stage of my attempts to find out why my heat pump is achieving such poor COP s...]]></description>
                        <content:encoded><![CDATA[<p>@kev-m Now that you have solved the problem of temperature readings, this has enabled me to move on to the next stage of my attempts to find out why my heat pump is achieving such poor COP scores (They are about 2.3 when the predicted score is 3.2 and better.  We have done the following without much progress</p>
<p>My web researches don’t suggest any other explanation for poor efficiency so can any one come up with new ideas?  Failing that I don’t know what to do short of taking our heat pump out and starting again with an efficient combi boiler</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16286</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16284</link>
                        <pubDate>Sun, 12 Feb 2023 18:00:40 +0000</pubDate>
                        <description><![CDATA[Oh @kev-m you star you 😘🤣
@dotty9943 I’m glad you’re on the up 👍]]></description>
                        <content:encoded><![CDATA[<p>Oh @kev-m you star you 😘🤣</p>
<p>@dotty9943 I’m glad you’re on the up 👍</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16284</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16281</link>
                        <pubDate>Sun, 12 Feb 2023 17:26:13 +0000</pubDate>
                        <description><![CDATA[@kev-m you are a star!  I have been struggling with this for days.  With your tip I have got it to work at last]]></description>
                        <content:encoded><![CDATA[@kev-m you are a star!  I have been struggling with this for days.  With your tip I have got it to work at last]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16281</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16277</link>
                        <pubDate>Sun, 12 Feb 2023 16:41:21 +0000</pubDate>
                        <description><![CDATA[-39C means that the software running the FTC is a buggy version that needs to be updated. There is a firmware check in the MelCloud app, I presume this is the software that needs to be updat...]]></description>
                        <content:encoded><![CDATA[<p>-39C means that the software running the FTC is a buggy version that needs to be updated. There is a firmware check in the MelCloud app, I presume this is the software that needs to be updated (mine was changed during an engineer visit), there's only one way to find out! When you switch to room mode the FTC will be using this incorrect temperature as a gauge of how much energy it needs to put in, this will be massively wrong, which is what might be triggering the back-up heaters to come on . You don't want to be in room mode until you have an accurate temperature showing.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-melcloud-temperature-control-with-compensation-curve/#post-16277</guid>
