									Ecodan U4 error code - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/</link>
            <lastBuildDate>Sat, 14 Nov 2026 18:34:26 +0000</lastBuildDate>
                        <title>RE: Ecodan U4 error code</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31486</link>
                        <pubDate>Tue, 18 Jun 2024 15:05:58 +0000</pubDate>
                        <description><![CDATA[Oh I didn&#039;t see that - so I&#039;m getting 300-320 ohms on that thermistor....]]></description>
                        <content:encoded><![CDATA[<p>Oh I didn't see that - so I'm getting 300-320 ohms on that thermistor....</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>spacebiscuit</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31486</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31485</link>
                        <pubDate>Tue, 18 Jun 2024 14:06:36 +0000</pubDate>
                        <description><![CDATA[@spacebiscuit
Page 55 shows the resistance range for TH32, which could be measured if you have a suitable multimeter. You could also test the circuit board by connecting a suitable resistor...]]></description>
                        <content:encoded><![CDATA[<p>@spacebiscuit</p>
<p>Page 55 shows the resistance range for TH32, which could be measured if you have a suitable multimeter. You could also test the circuit board by connecting a suitable resistor in place of the thermistor.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31485</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31484</link>
                        <pubDate>Tue, 18 Jun 2024 13:25:30 +0000</pubDate>
                        <description><![CDATA[On SW2 switches 1, 4 and 6 need to be on - this will then return a number corresponding to a thermistor. Although in my case it returned &#039;3&#039; which could be one of two. So I then had to try 3...]]></description>
                        <content:encoded><![CDATA[<p>On SW2 switches 1, 4 and 6 need to be on - this will then return a number corresponding to a thermistor. Although in my case it returned '3' which could be one of two. So I then had to try 3,4,5 on which gives the temperature of the inlet - mine was read '102' which is not achievable and so indicates a bad resistance reading and therefore TH32 being the faulty thermistor - I hope!</p>
<p>See pages 74 and 76 here:</p>
<p>https://www.renewableenergyhub.co.uk/uploads/products/1628/product_brochures/Ecodan_ATW_PUHZ-HW140VHA2-BS-PUHZ-HW140YHA2-BS_Service.pdf </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31484</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31483</link>
                        <pubDate>Tue, 18 Jun 2024 11:58:14 +0000</pubDate>
                        <description><![CDATA[@spacebiscuit could you detail what switches you changed maybe useful for someone else in the future thanks]]></description>
                        <content:encoded><![CDATA[@spacebiscuit could you detail what switches you changed maybe useful for someone else in the future thanks]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31483</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31482</link>
                        <pubDate>Tue, 18 Jun 2024 10:17:34 +0000</pubDate>
                        <description><![CDATA[I discovered that there are some dip switches (SW2) that can be set on the unit&#039;s controller board which will indicate the exact thermistor at fault. In my case it was the water inlet thermi...]]></description>
                        <content:encoded><![CDATA[<p>I discovered that there are some dip switches (SW2) that can be set on the unit's controller board which will indicate the exact thermistor at fault. In my case it was the water inlet thermistor that was showing a wrong resistance which I missed when I was testing each thermistor for general operation not actual readings.</p>
<p>Part ordered and hopefully that will be it fixed!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31482</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31458</link>
                        <pubDate>Mon, 17 Jun 2024 13:42:28 +0000</pubDate>
                        <description><![CDATA[I&#039;ve cleaned that solder joint up and resoldered it, looks good now. But today no matter what I&#039;ve tried the machine will not spin up. I&#039;ve tried wiggling the wires connectors, thermistors o...]]></description>
                        <content:encoded><![CDATA[<p>I've cleaned that solder joint up and resoldered it, looks good now. But today no matter what I've tried the machine will not spin up. I've tried wiggling the wires connectors, thermistors on the pipes but nothing! I'm all out of ideas.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/paged/2/#post-31458</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31447</link>
                        <pubDate>Mon, 17 Jun 2024 09:42:54 +0000</pubDate>
                        <description><![CDATA[Try moving the plug/socket and see if there is any movement or that the alarm clears or appears.]]></description>
<p>I found this on the board where TH4 (Thermistor Discharge) plugs. The rest of the solder joints look clean as can be seen on TH3.</p>
7497
<p>Does the joint look bad? </p>
<p>Try moving the plug/socket and see if there is any movement or that the alarm clears or appears.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31447</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31444</link>
                        <pubDate>Mon, 17 Jun 2024 08:45:35 +0000</pubDate>
                        <description><![CDATA[I found this on the board where TH4 (Thermistor Discharge) plugs. The rest of the solder joints look clean as can be seen on TH3.
Does the joint look bad?]]></description>
                        <content:encoded><![CDATA[<p>I found this on the board where TH4 (Thermistor Discharge) plugs. The rest of the solder joints look clean as can be seen on TH3.</p>
7497
<p>Does the joint look bad? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31444</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31441</link>
                        <pubDate>Sun, 16 Jun 2024 23:04:01 +0000</pubDate>
                        <description><![CDATA[I would suggest that you check the soldered joints on the board with a magnifying glass. Intermittent faults can be caused by &#039;dry joints&#039; on a circuit board.
Also check the wiring for dama...]]></description>
<p>Thanks - over the weekend I order a replacement power board which I switched out - didn't fix the issue. However after checking the thermistors for their resistance readings the pump spun up after reconnecting them to the board - the pump ran for 30 minutes long enough to heat the cylinder. Then an hour later I had the same U4 error again. I left the machine for sometime, removed each thermistor form the board took the reading and again the pump spun up, this time for about 5 minutes but stopped when I was carefully removing the corner panel where the PCBs are.</p>
<p>Whenever the pump stops I get good resistance readings, I'm wondering if it is an issue on the control board rather than the actual thermistors?</p>
<p>I would suggest that you check the soldered joints on the board with a magnifying glass. Intermittent faults can be caused by 'dry joints' on a circuit board.</p>
<p>Also check the wiring for damage or bad connections in the plugs and sockets.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31441</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31440</link>
                        <pubDate>Sun, 16 Jun 2024 22:21:26 +0000</pubDate>
                        <description><![CDATA[Thanks - over the weekend I order a replacement power board which I switched out - didn&#039;t fix the issue. However after checking the thermistors for their resistance readings the pump spun up...]]></description>
                        <content:encoded><![CDATA[<p>Thanks - over the weekend I order a replacement power board which I switched out - didn't fix the issue. However after checking the thermistors for their resistance readings the pump spun up after reconnecting them to the board - the pump ran for 30 minutes long enough to heat the cylinder. Then an hour later I had the same U4 error again. I left the machine for sometime, removed each thermistor form the board took the reading and again the pump spun up, this time for about 5 minutes but stopped when I was carefully removing the corner panel where the PCBs are.<br /><br />Whenever the pump stops I get good resistance readings, I'm wondering if it is an issue on the control board rather than the actual thermistors?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-error/#post-31440</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 18:34:26 by W3 Total Cache
