									Ecodan Energy Monitoring Pack - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/</link>
            <lastBuildDate>Wed, 14 Oct 2026 04:01:24 +0000</lastBuildDate>
                        <title>RE: Ecodan Energy Monitoring Pack</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50402</link>
                        <pubDate>Mon, 13 Oct 2025 15:57:39 +0000</pubDate>
                        <description><![CDATA[@batpred that’s an idea yes. Will look into it]]></description>
                        <content:encoded><![CDATA[@batpred that’s an idea yes. Will look into it]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Carpenterstation</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50402</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50342</link>
                        <pubDate>Mon, 13 Oct 2025 09:44:05 +0000</pubDate>
                        <description><![CDATA[Even large pumps can be on 16 amps single phase, so the thought of installing a smart socket or switch that can measure energy comes to mind.. &#x1f609; 
May need to inform your pum...]]></description>
<p>How are your heat pumps wired up? Two single phase circuits or a single three phase? The OEM kit can monitor multiple electricity meters, at 45 amp per single phase and 100 amp three phase. </p>
<p>Even large pumps can be on 16 amps single phase, so the thought of installing a smart socket or switch that can measure energy comes to mind.. &#x1f609; </p>
<p>May need to inform your pump installer.. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50342</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50341</link>
                        <pubDate>Mon, 13 Oct 2025 09:38:59 +0000</pubDate>
                        <description><![CDATA[@carpenterstation one thing you may want to look into is a CT clamp. Some WiFi based models even allow you to measure several cables. 
Then you just get that info via the app.
Or then move...]]></description>
                        <content:encoded><![CDATA[<p>@carpenterstation one thing you may want to look into is a CT clamp. Some WiFi based models even allow you to measure several cables. </p>
<p>Then you just get that info via the app.</p>
<p>Or then move to a home assistant setup taking the sensor feeds and just let it do all the calculations for you.. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50341</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50289</link>
                        <pubDate>Sun, 12 Oct 2025 12:40:24 +0000</pubDate>
                        <description><![CDATA[Interesting. I tried very hard to monitor energy consumption through the Ecodan heat pumps without any real success and it didn’t feel accurate (we have a cascade system so the app is not ab...]]></description>
                        <content:encoded><![CDATA[<p>Interesting. I tried very hard to monitor energy consumption through the Ecodan heat pumps without any real success and it didn’t feel accurate (we have a cascade system so the app is not able to measure energy consumption). So instead I monitor the whole house usage and compare it annually. I figure the other domestic non-heating electrical usage is more or less the same each year (previously LPG heated the house and water). <br /><br /></p>
<p>but it is in theory a condition of the BUS grant that we monitor our usage and efficiency.  Not really that easy to do!</p>
<p>ps must change profile picture. Makes the house look cold - but it really isn’t!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50289</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50285</link>
                        <pubDate>Sun, 12 Oct 2025 11:20:16 +0000</pubDate>
                        <description><![CDATA[I&#039;ve monitored our Ecodan 11.2 since it was installed 3 years ago with the objective of optimising its performance. At installation a separate electricity consumption meter was installed whi...]]></description>
                        <content:encoded><![CDATA[<p>I've monitored our Ecodan 11.2 since it was installed 3 years ago with the objective of optimising its performance. At installation a separate electricity consumption meter was installed which has consistently shown that the HP overestimates the energy it consumes. This is most obvious when only hot water is heated in the summer though the HP shows energy being consumed but none output. <br />The overestimate is variable. For a while I took daily readings and it varied between +1 and -5 (where - is an overestimate). More recently I recorded weekly for a year and it ranged between -5 and -8 per week. Now I feel things are broadly optimised I'm just keeping monthly records. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/paged/2/#post-50285</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-50177</link>
                        <pubDate>Fri, 10 Oct 2025 18:45:23 +0000</pubDate>
                        <description><![CDATA[Hi @carpenterstation  
Did you ever resolve the energy monitoring for your cascade system as I have the same issue with a rencent install?
Thanks. Caroline]]></description>
                        <content:encoded><![CDATA[<p>Hi @carpenterstation  </p>
<p>Did you ever resolve the energy monitoring for your cascade system as I have the same issue with a rencent install?</p>
<p>Thanks. Caroline </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>CAMorgan</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-50177</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42686</link>
                        <pubDate>Thu, 20 Feb 2025 14:11:17 +0000</pubDate>
                        <description><![CDATA[@robs I have no idea how the supply is wired but it is off one of the consumer units that is attached to one of the phases - so I guess 2 single phase circuits. 
should the functionality to...]]></description>
                        <content:encoded><![CDATA[<p>@robs I have no idea how the supply is wired but it is off one of the consumer units that is attached to one of the phases - so I guess 2 single phase circuits. <br /><br /></p>
<p>should the functionality to measure my usage have been provided by the installer as a condition of the MCS accreditation? Or do I now have to pay more for it?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42686</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42659</link>
                        <pubDate>Wed, 19 Feb 2025 19:26:56 +0000</pubDate>
                        <description><![CDATA[That&#039;s really a question for the OpenEnergyMonitor folk (hello@openenergymonitor.zendesk.com) but if you just wanted to monitor the combined input/output then it seems likely. If you could f...]]></description>
<p>Hi @Robs - would the OpenEnergyMonitor be able to compute a COP on a cascade system? </p>
<p>That's really a question for the OpenEnergyMonitor folk (hello@openenergymonitor.zendesk.com) but if you just wanted to monitor the combined input/output then it seems likely. If you could fit the flow meter and temperature probes in pipework where the water to/from your two heat pumps is combined then it would look like just one heat pump to the sensors. How are your heat pumps wired up? Two single phase circuits or a single three phase? The OEM kit can monitor multiple electricity meters, at 45 amp per single phase and 100 amp three phase. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42659</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42624</link>
                        <pubDate>Tue, 18 Feb 2025 22:51:43 +0000</pubDate>
                        <description><![CDATA[Hi @Robs - would the OpenEnergyMonitor be able to compute a COP on a cascade system? I am currently using a combination of a solar app (Sunsynk) and smart meter readings to try and estimate ...]]></description>
                        <content:encoded><![CDATA[<p>Hi @Robs - would the OpenEnergyMonitor be able to compute a COP on a cascade system? I am currently using a combination of a solar app (Sunsynk) and smart meter readings to try and estimate usage (also comparing to previous years). <br /><br /></p>
<p>but as Jan and feb have been unusually cold this year I am finding the electric usage very high - (I suspect that had we still been on LPG that usage too would have been very high) but I don’t yet know the efficiency I am getting out of the system. I am running pure weather compensation trying to keep downstairs at 19 or 20 degrees and upstairs a couple of degrees cooler. (All TRVs open, and all room stats set above these temperatures) </p>
<p>i am acutely aware that I am unable at present (should ofgem ask - which is their right under the terms of the BUS grant) to measure my energy usage because the MELCloud cannot compute energy usage for cascade systems. Can anyone help here please? Does anyone else have this issue? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42624</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42620</link>
                        <pubDate>Tue, 18 Feb 2025 22:22:25 +0000</pubDate>
                        <description><![CDATA[Mitsubishi&#039;s use a Sika flow meter and two thermistors (attached to the outside of the flow and return pipes) in the &quot;plant room&quot;. From those the flow rate and dT can be determined (SUNandAi...]]></description>
<p>You're welcome, @downfield.</p>
<p>...</p>
<p>Do you know if the outside unit has a heat meter?  On OpenEnergyMonitor they all seem to be fitting heat meters to their systems so I thought maybe the "heat produced" was just an estimate rather than a measured quantity.</p>
<p>...</p>
<p>Sadly I don't know, but would be interested to know since I have a Mitsi myself. Nor, like you, do I know the detail of what a heat meter is actually measuring or the specifics of how it does it.</p>
<p>Mitsubishi's use a Sika flow meter and two thermistors (attached to the outside of the flow and return pipes) in the "plant room". From those the flow rate and dT can be determined (SUNandAir's post describes why these are important). In comparison to OpenEnergyMonitor kit, the flow meter is also a class 2 device but the thermistors attached externally are far less accurate (OEM uses digital temp probes in the water), so OEM kit will be able to more accurately calculate the heat/power produced. In addition, the OEM kit uses a class 1 electricity meter to measure electrical input - I don't know what Mitsubishi use for their COP "estimates". </p>
<p>Having a Mitsubishi with both Mitsubishi's and OpenEnergyMonitor monitoring, Mitsubishi/MELCloud gives a rough idea of what is happening but OEM is more accurate and gives far more detail. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-energy-monitoring-pack/#post-42620</guid>
Object Caching 60/67 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-10-14 05:01:24 by W3 Total Cache
