									Ecodan Controller Placement? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/</link>
            <lastBuildDate>Tue, 17 Mar 2026 03:32:25 +0000</lastBuildDate>
                        <title>RE: Ecodan Controller Placement?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15460</link>
                        <pubDate>Fri, 03 Feb 2023 08:53:41 +0000</pubDate>
                        <description><![CDATA[They should only get as hot as the WC target if you&#039;re on WC.  If you&#039;re in AA they will get a lot hotter than that.]]></description>
                        <content:encoded><![CDATA[<p>They should only get as hot as the WC target if you're on WC.  If you're in AA they will get a lot hotter than that.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15460</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15458</link>
                        <pubDate>Fri, 03 Feb 2023 07:44:17 +0000</pubDate>
                        <description><![CDATA[In WC atm and if I turn the temp up on the thermostat (Mitsubishi wireless) the radiators get hotter.]]></description>
<p>@kev-m   Oh, dip switches!  I don't have the confidence to take the front off that box.</p>
<p>Just try room temp mode without looking at the dip switches. If it's not set to auto adapt I think it'll just act like a dumb thermostat like it's doing now.  If you want to know if it is on AA, turn up the temp a couple or three degrees and the radiators will get hotter. If it isn't, they won't.</p>
<p>In WC atm and if I turn the temp up on the thermostat (Mitsubishi wireless) the radiators get hotter.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15458</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15428</link>
                        <pubDate>Thu, 02 Feb 2023 17:39:25 +0000</pubDate>
                        <description><![CDATA[Just try room temp mode without looking at the dip switches. If it&#039;s not set to auto adapt I think it&#039;ll just act like a dumb thermostat like it&#039;s doing now.  If you want to know if it is on...]]></description>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15428</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15413</link>
                        <pubDate>Thu, 02 Feb 2023 15:14:49 +0000</pubDate>
                        <description><![CDATA[@kev-m   Oh, dip switches!  I don&#039;t have the confidence to take the front off that box.]]></description>
                        <content:encoded><![CDATA[@kev-m   Oh, dip switches!  I don't have the confidence to take the front off that box.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15413</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15403</link>
                        <pubDate>Thu, 02 Feb 2023 13:18:41 +0000</pubDate>
                        <description><![CDATA[Should be fine.  You need to make sure that the Room Sensor setting is set to &quot;Main RC&quot;.  It&#039;s on the menu under Initial Settings (the little cog wheel).  You also need to enable Auto Adapta...]]></description>
<p>My Ecodan controller is wall mounted beside the main box in the same (airing) cupboard as the DHW tank.   However I am set up for WC and adjust room temp' via a Mitsubishi wireless remote in the hall.   I would like to try Auto Adaptation to see if financial savings can be had.  Does my set up as described preclude or allow auto adaptation?</p>
<p>One single remote thermostat, single zone all to radiators.</p>
<p>Should be fine.  You need to make sure that the Room Sensor setting is set to "Main RC".  It's on the menu under Initial Settings (the little cog wheel).  You also need to enable Auto Adaptation via a dip switch. SW5-2.  The default is enabled (mine was enabled)</p>
<p>Have you tried just changing to Room Temp mode on the main controller in the airing cupboard?  If the two above things are in place it should just work.  You'll know because the first thing that will happen is your radiators will get much hotter for a couple of days.    </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15403</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15396</link>
                        <pubDate>Thu, 02 Feb 2023 11:45:29 +0000</pubDate>
                        <description><![CDATA[My Ecodan controller is wall mounted beside the main box in the same (airing) cupboard as the DHW tank.   However I am set up for WC and adjust room temp&#039; via a Mitsubishi wireless remote in...]]></description>
                        <content:encoded><![CDATA[<p>My Ecodan controller is wall mounted beside the main box in the same (airing) cupboard as the DHW tank.   However I am set up for WC and adjust room temp' via a Mitsubishi wireless remote in the hall.   I would like to try Auto Adaptation to see if financial savings can be had.  Does my set up as described preclude or allow auto adaptation?</p>
<p>One single remote thermostat, single zone all to radiators.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15396</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15350</link>
                        <pubDate>Wed, 01 Feb 2023 13:44:14 +0000</pubDate>
                        <description><![CDATA[Check and set the WC curve as shown in the video below. Try initial settings of 50C LWT at -5C outside air temperature and 25C LWT at 20C outside air temperature.
Once completed open fully ...]]></description>
<p>We have 2 thermostats (1 in the master bedroom - right next to the 'boiler cupboard' and 1 in the downstairs hallway - right next to the front door). </p>
<p>From memory they are Honeywell thermostats (I'll check when I get back) and were installed by Lovell's before we moved in. I'm able to set temperature and daily programs from them which the pump seems to respond to. </p>
<p>If it would help I'll ask Lovell's to provide a wireless Mitsubishi unit but only if I know it'll help. </p>
<p>Regarding the WC setting...we've been using the above suggested settings for the past 4/6 weeks and haven't noticed a great deal of difference. Particularly downstairs it seems to never reach the called for temp even when left for hours. This weekend for example we left the house at 3:30pm with the thermostat showing 16.5'c...before we left I turned it up to 18'c so that when we returned in 2/3 hours the house would be warm...but when we had got back the temp had dropped to 16'c. I know the DHW hadn't been on as that's on a timer.</p>
<p>I don't really want the temp at night above 16.5/17'c as A. it's too warm and B. too expensive but it takes what seems like a lifetime to then get back to a decent temp. The wife is getting pretty fed up with daily bills being well in excess of £10 a day whilst still being cold, so much so she's started to consider putting in a wood burner which defeats the purpose of an eco ASHP.     </p>
<p>Check and set the WC curve as shown in the video below. Try initial settings of 50C LWT at -5C outside air temperature and 25C LWT at 20C outside air temperature.</p>
<p>https://www.google.com/search?q=how+to+set+weather+compensation+on+ecodan+heat+pump&amp;rlz=1C1OPRB_enGB514GB552&amp;oq=how+to+set+weather+compensation+on+ecodan&amp;aqs=chrome.2.69i57j33i160l2.53193j1j7&amp;sourceid=chrome&amp;ie=UTF-8#fpstate=ive&amp;vld=cid:a02b8ba7,vid:uC3jydJydRQ</p>
<p>Once completed open fully any TRV's in the living areas, and set any thermostats to 1C above the desired temperature.</p>
<p>Leave the system running for a few hours then report back what has happened to the indoor temperatures.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15350</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15337</link>
                        <pubDate>Wed, 01 Feb 2023 11:26:40 +0000</pubDate>
                        <description><![CDATA[We have 2 thermostats (1 in the master bedroom - right next to the &#039;boiler cupboard&#039; and 1 in the downstairs hallway - right next to the front door). 
From memory they are Honeywell thermos...]]></description>
                        <content:encoded><![CDATA[<p>We have 2 thermostats (1 in the master bedroom - right next to the 'boiler cupboard' and 1 in the downstairs hallway - right next to the front door). </p>
<p>I don't really want the temp at night above 16.5/17'c as A. it's too warm and B. too expensive but it takes what seems like a lifetime to then get back to a decent temp. The wife is getting pretty fed up with daily bills being well in excess of £10 a day whilst still being cold, so much so she's started to consider putting in a wood burner which defeats the purpose of an eco ASHP.     </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Walsham_Matt</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15337</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15328</link>
                        <pubDate>Wed, 01 Feb 2023 09:46:35 +0000</pubDate>
                        <description><![CDATA[I got my installer to relocate my controller and replace my 3rd party (on off) room stat with the wireless Mitsubishi which is now set up as the room temp stat. I now have modulating auto ad...]]></description>
                        <content:encoded><![CDATA[<p>I got my installer to relocate my controller and replace my 3rd party (on off) room stat with the wireless Mitsubishi which is now set up as the room temp stat. I now have modulating auto adaptive control and weathe compensation. From the convenience of either my kitchen or lounge.</p>
<p>my argument was the installation did not give me the full functionality of the system. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15328</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15315</link>
                        <pubDate>Tue, 31 Jan 2023 21:30:04 +0000</pubDate>
                        <description><![CDATA[There&#039;s a setting in the menus somewhere to use remote thermistors, but I think it only works if they&#039;re either on a long wire from the controller, or are Mitsubishi remote units.
Third p...]]></description>
                        <content:encoded><![CDATA[There's a setting in the menus somewhere to use remote thermistors, but I think it only works if they're either on a long wire from the controller, or are Mitsubishi remote units.
Third party thermostats just send on/off signals, as described.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ecodan-controller-placement/#post-15315</guid>
