									Designing ASHP system using the Freedom toolkit spreadsheet - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/</link>
            <lastBuildDate>Tue, 06 Oct 2026 15:00:27 +0000</lastBuildDate>
                        <title>RE: Designing ASHP system using the Freedom toolkit spreadsheet</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/paged/2/#post-8502</link>
                        <pubDate>Mon, 02 May 2022 21:11:37 +0000</pubDate>
                        <description><![CDATA[Posted by: @jezzaf 
@hughf Hi.. just read your comment and the last line caught my attention and if I understand you correctly  .. so many years ago I did a self install of a Trianco Active...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="2397" data-postid="8472" data-mention="jezzaf">
<div class="wpforo-post-quote-author"><strong> Posted by: @jezzaf </strong></div>
<p>@hughf Hi.. just read your comment and the last line caught my attention and if I understand you correctly  .. so many years ago I did a self install of a Trianco Active Air Heatpump .... it was a rebadged  chinese made machine anyway the compressor failed I can't now remember if it was in warranty or just out. The point was that as I was not an "approved installer" the manufacturer "Trianco" would not even talk to me or assist in any way.  Ended up scrapping the unit and now happy with air to air. But moving to G2 listed Farmhouse in Somerset in two weeks so its  full circle for me back to oil :)        </p>
<p>That's unfortunate, but the nature of the beast with any sort of refrigeration in a domestic environment over here. Look at the US, HVAC tech's everywhere, perfectly capable of changing all the parts inside your average split ac/heatpump unit. Compressors, 4 way vavles, expansion valves, filters, all available from the spares suppliers or kept on the van.</p>
<p>To be honest, I like to write down my tech at a reasonable rate, so if I can get 10 years out of something that costs £3k, I'm happy with that. I wouldn't expect any issues within 10 years, perhaps a regas, but that's easy enough for anyone with F-gas to do.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/paged/2/#post-8502</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/paged/2/#post-8496</link>
                        <pubDate>Mon, 02 May 2022 17:50:33 +0000</pubDate>
                        <description><![CDATA[@hughf - it is definitely on the cards, but I haven&#039;t quite got to the Oscar Wilde moment yet (&#039;either the PHE goes, or I go&#039;) as I am still a bit in favour of the pros of separating the two...]]></description>
                        <content:encoded><![CDATA[<p>@hughf - it is definitely on the cards, but I haven't quite got to the Oscar Wilde moment yet ('either the PHE goes, or I go') as I am still a bit in favour of the pros of separating the two circuits, and now we have warmer weather, it is less easy to investigate the cons, losses due to the PHE. Mine also got hampered by the installer's plumber's well intentioned but unwise habit of reversing the flow, ie removing the contraflow by rotating the pump through 180 degrees, in a bid to improve radiator heating (they tend to be too cold, even with adequate primary flow temps). I think this is most likely inadequate circulating flow rate, despite the pump being on its max flow rate setting, water in effect stagnates in the rads and cools down, and it will be easier to fit a higher flow rate circulating pump if the two circuits are separate. There is also the question of the adequacy of the circulating pump in the heat pump, if it has to maintain a fast flow round all the rads, rather than just the PHE.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/paged/2/#post-8496</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8486</link>
                        <pubDate>Mon, 02 May 2022 09:56:28 +0000</pubDate>
                        <description><![CDATA[@cathoderay I’ve read your thread completely, I’d bin that plate off at the first opportunity, can’t see the point of it at all.]]></description>
                        <content:encoded><![CDATA[<ol>
<li>@cathoderay I’ve read your thread completely, I’d bin that plate off at the first opportunity, can’t see the point of it at all. </li>
</ol>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8486</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8483</link>
                        <pubDate>Mon, 02 May 2022 09:46:51 +0000</pubDate>
                        <description><![CDATA[Posted by: @hughf 
I&#039;m not installing it with a LLH or a Plate
You may have seen the discussion on these, both in the thread I started about my installation, and elsewhere. One interesti...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="2601" data-postid="8481" data-mention="hughf">
<div class="wpforo-post-quote-author"><strong> Posted by: @hughf </strong></div>
<p>I'm not installing it with a LLH or a Plate</p>
<p>You may have seen the discussion on these, both in the thread I started about my installation, and elsewhere. One interesting point is that Freedom changed their requirement for these, from being and absolutely essential component (bye bye warranty if not used etc) to, in their latest installation manual, it being shown as a component, but the warranty voiding aspect if not used has been removed.</p>
<p>I still have my PHE in place, and am still on the fence about it, pros (keeps rad circuit crud away from primary ASHP circuit) and cons (extra expense, losses and something else to go wrong).  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8483</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8481</link>
                        <pubDate>Mon, 02 May 2022 09:34:25 +0000</pubDate>
                        <description><![CDATA[@cathoderay I agree, this stuff should be out in the open and available (I write/use open source software as part of my job - don&#039;t have time for closed source stuff)... Thanks for your radi...]]></description>
                        <content:encoded><![CDATA[<p>@cathoderay I agree, this stuff should be out in the open and available (I write/use open source software as part of my job - don't have time for closed source stuff)... Thanks for your radiator sizing sheet, I'll have a play with that.</p>
<p>It's really odd that Midea won't sell to end users, even if no warranty was offered. I'd be happy to buy one if they knocked some coin off for warranty voiding - I'll void it anyway as I'm not installing it with a LLH or a Plate - ain't got the space for that, I'll just use the overly long loops of 28mm...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8481</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8480</link>
                        <pubDate>Mon, 02 May 2022 09:29:41 +0000</pubDate>
                        <description><![CDATA[@editor - not sure where to post this here seems as good as any other place, as this thread is about using spreadsheet calculators. FWIW, this is my modified OFGEM rad sizing calculator, bas...]]></description>
                        <content:encoded><![CDATA[<p>@editor - not sure where to post this here seems as good as any other place, as this thread is about using spreadsheet calculators. FWIW, this is my modified OFGEM rad sizing calculator, based on delta t conversion factors so you get a more accurate (!) result. It currently contains data for a typical hypothetical old leaky 3 bedroom house, which can be edited to suit. It also allows you to add more rads if the contained list does not meet your needs (get the delta t 50 value from manufacturer's data). I set it up and use it in LibreOffice Calc, but but should work in anything that can open xlsx files. </p>
1265
<p>It goes without saying, use is entirely at user's risk, if you turn your house into a freezer of a frying pan using the calculator, it is your responsibility, not mine. But, in the right hands, it might be of use to some people, if only as an independent sanity check.</p>
<p>@hughf - I think various people have been borrowing other people's calculator spreadsheets and modifying them over the years - just as I have done with the OFGEM calculator. If the spreadsheet is available online, that is what will happen (and it is basically a good thing, openness and transparency and not to mention error checking etc). Freedom made their calculator available online, ie put in the public domain, so, as I see it, it is available to all. I suspect many installers also send property/quote specific copies to their customers, again increasing general circulation.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8480</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8477</link>
                        <pubDate>Mon, 02 May 2022 09:10:21 +0000</pubDate>
                        <description><![CDATA[As per the thread title really, and following on from my introduction post - I&#039;ve been designing a new CH system for my Wife&#039;s 1946 end of terrace in rural somerset. We have 300mm loft insul...]]></description>
                        <content:encoded><![CDATA[<p>As per the thread title really, and following on from my introduction post - I've been designing a new CH system for my Wife's 1946 end of terrace in rural somerset. We have 300mm loft insulation, blown cavity walls, relatively recent DG (due to be replaced with Uw 0.9 units this year) and we currently heat with a 35yr old Baxi Bermuda. Typically using 17MWh of Gas/year for CH and DHW and looking to upgrade from the current system that is on borrowed time.</p>
<p>I can't see the merit in installing a new gas combi, only to find in 2035 that we can't find a replacement when that fails. Plus, it would be nice to ditch the gas finally so I don't have to bother a gas safe engineer and try and ninja a 28mm gas through the house to the new boiler location.</p>
<p>Attached are my latest workings using the Freedom toolkit. At the moment I'm torn between a Midea (concerned by the fact they might not sell me one), a Cool Energy CE-iVT9 (concerned by the efficiency using r410 vs r32 - I don't know enough about the finer points of refrigerants to assess this), and an LG Therma V (because the controller looks excellent, I like the look of the AI weather comp mode, and they're cheap as chips)</p>
1263]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8477</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8476</link>
                        <pubDate>Mon, 02 May 2022 08:59:32 +0000</pubDate>
                        <description><![CDATA[Posted by: @editor 
@hughf, welcome to the forums and look forward to hearing how your system comes along and which ASHP you chose. I’ve created a dedicated thread for you, so please contin...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="1" data-postid="8471" data-mention="editor">
<div class="wpforo-post-quote-author"><strong> Posted by: @editor </strong></div>
<p>@hughf, welcome to the forums and look forward to hearing how your system comes along and which ASHP you chose. I’ve created a dedicated thread for you, so please continue to share updates here.</p>
<p>Thanks for creating this thread for me Mars, appreciated...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8476</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8472</link>
                        <pubDate>Mon, 02 May 2022 08:44:07 +0000</pubDate>
                        <description><![CDATA[@hughf Hi.. just read your comment and the last line caught my attention and if I understand you correctly  .. so many years ago I did a self install of a Trianco Active Air Heatpump .... it...]]></description>
                        <content:encoded><![CDATA[<p>@hughf Hi.. just read your comment and the last line caught my attention and if I understand you correctly  .. so many years ago I did a self install of a Trianco Active Air Heatpump .... it was a rebadged  chinese made machine anyway the compressor failed I can't now remember if it was in warranty or just out. The point was that as I was not an "approved installer" the manufacturer "Trianco" would not even talk to me or assist in any way.  Ended up scrapping the unit and now happy with air to air. But moving to G2 listed Farmhouse in Somerset in two weeks so its  full circle for me back to oil :)        </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>jezzaf</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8472</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8471</link>
                        <pubDate>Mon, 02 May 2022 08:38:25 +0000</pubDate>
                        <description><![CDATA[@hughf, welcome to the forums and look forward to hearing how your system comes along and which ASHP you chose. I’ve created a dedicated thread for you, so please continue to share updates h...]]></description>
                        <content:encoded><![CDATA[<p>@hughf, welcome to the forums and look forward to hearing how your system comes along and which ASHP you chose. I’ve created a dedicated thread for you, so please continue to share updates here.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/designing-ashp-system-using-the-freedom-toolkit-spreadsheet/#post-8471</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-06 16:00:27 by W3 Total Cache
