									Defrost cycle question - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/defrost-cycle-question/</link>
            <lastBuildDate>Sun, 08 Nov 2026 02:05:30 +0000</lastBuildDate>
                        <title>RE: Defrost cycle question</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/defrost-cycle-question/#post-30534</link>
                        <pubDate>Fri, 03 May 2024 13:06:02 +0000</pubDate>
                        <description><![CDATA[@hughf Thanks for that.
Ah so they are talking about the refrigerant circuit direction reversing.
I knew it couldn&#039;t be the water circuit logically, I think it has been a rather long week ...]]></description>
                        <content:encoded><![CDATA[<p>@hughf Thanks for that.</p>
<p>Ah so they are talking about the refrigerant circuit direction reversing.</p>
<p>I knew it couldn't be the water circuit logically, I think it has been a rather long week &#x1f606;  </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>IRMartini</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/defrost-cycle-question/#post-30534</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/defrost-cycle-question/#post-30532</link>
                        <pubDate>Fri, 03 May 2024 12:58:30 +0000</pubDate>
                        <description><![CDATA[A valve in the heat pump causes the direction of the refrigerant to change. The water circuit carries on pumping as usual.]]></description>
                        <content:encoded><![CDATA[<p>A valve in the heat pump causes the direction of the refrigerant to change. The water circuit carries on pumping as usual.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/defrost-cycle-question/#post-30532</guid>
                        <title>Defrost cycle question</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/defrost-cycle-question/#post-30530</link>
                        <pubDate>Fri, 03 May 2024 12:05:25 +0000</pubDate>
                        <description><![CDATA[Sorry if this is a daft question:
But after reading about defrost cycles I&#039;m pretty sure I understand the basics of what is happening.
Instead of heat from the environment being used th...]]></description>
                        <content:encoded><![CDATA[<p>Sorry if this is a daft question:</p>
<p>But after reading about defrost cycles I'm pretty sure I understand the basics of what is happening.</p>
<p>Instead of heat from the environment being used the increase the temp of the heating circuit, during the defrost cycle heat from the heating circuit is used to warm the environment (melt the ice off the radiator)</p>
<p>All the descriptions I've read use the word reverse, the heat pump works in reverse or the heat pump reverses.</p>
<p>Does the actual water pump pumping the water round the heating circuit reverse direction?</p>
<p>Or is the 'reverse' just referring to the heating 'mode' reversing (going from heating to cooling) rather than the water flow reversing.</p>
<p>I'm pretty sure its just talking about the mode but after lots of searching I could find nothing definitive on the water pump direction.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/defrost-cycle-question/#post-30530</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 02:05:30 by W3 Total Cache
