									Daikin Heat Pump Cycling Frequency? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-heatpump-cycling-frequency/</link>
            <lastBuildDate>Sun, 08 Nov 2026 02:11:03 +0000</lastBuildDate>
                        <title>RE: Daikin Heat Pump Cycling Frequency?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-heatpump-cycling-frequency/#post-43753</link>
                        <pubDate>Tue, 11 Mar 2025 22:58:53 +0000</pubDate>
                        <description><![CDATA[I think your current method of logging F-gas pipe temperatures using a Raspberry Pi and DS18B20 sensors gives you useful data, but it has limitations if you’re trying to accurately track com...]]></description>
                        <content:encoded><![CDATA[<p><span>I think your current method of logging F-gas pipe temperatures using a Raspberry Pi and DS18B20 sensors gives you useful data, but it has limitations if you’re trying to accurately track compressor cycling.</span></p>
<p><span>F-gas temperature changes can indicate compressor activity, but they don’t give you a clear picture of power draw, start/stop frequency or how hard the compressor is working. If you want precise compressor start frequency and run durations, a Shelly EM or similar power monitor on the heat pump’s supply circuit would be much more effective.</span></p>
<p><span>With the Shelly, you’d get real-time power consumption data, making it easy to track exactly when the compressor starts and stops, rather than inferring it from temperature changes.</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-heatpump-cycling-frequency/#post-43753</guid>
                        <title>Daikin Heat Pump Cycling Frequency?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-heatpump-cycling-frequency/#post-43752</link>
                        <pubDate>Tue, 11 Mar 2025 21:10:08 +0000</pubDate>
                        <description><![CDATA[I am monitoring my heat pump&#039;s compressor start frequency during the colder months, the only monitoring I have is a &quot;raspberry pi&quot; and DS18b20 temperature probes. Currently I am plotting and...]]></description>
                        <content:encoded><![CDATA[<p>I am monitoring my heat pump's compressor start frequency during the colder months, the only monitoring I have is a "raspberry pi" and DS18b20 temperature probes. Currently I am plotting and logging the compressor's F-gas pipe temperatures. </p>
<p>Please can anyone advise if this is a sound method or should I install a Shelly energy monitor ??</p>
10779
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Ubert767</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-heatpump-cycling-frequency/#post-43752</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 02:11:03 by W3 Total Cache
