									Daikin Altherma ASHP help needed – Radiators are not heating up - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/</link>
            <lastBuildDate>Mon, 13 Apr 2026 12:13:08 +0000</lastBuildDate>
                        <title>RE: Daikin Altherma ASHP help needed – Radiators are not heating up</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28680</link>
                        <pubDate>Mon, 11 Mar 2024 12:41:36 +0000</pubDate>
                        <description><![CDATA[@editor No thanks :)]]></description>
                        <content:encoded><![CDATA[@editor No thanks :)]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>uffda</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28680</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28679</link>
                        <pubDate>Mon, 11 Mar 2024 12:41:06 +0000</pubDate>
                        <description><![CDATA[@derek-m Okay thanks :)]]></description>
                        <content:encoded><![CDATA[@derek-m Okay thanks :)]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28679</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28678</link>
                        <pubDate>Mon, 11 Mar 2024 12:40:29 +0000</pubDate>
                        <description><![CDATA[@hughf Many thanks :)]]></description>
                        <content:encoded><![CDATA[@hughf Many thanks :)]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28678</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28664</link>
                        <pubDate>Mon, 11 Mar 2024 10:33:39 +0000</pubDate>
                        <description><![CDATA[Are you maintaining the desired indoor temperature?
During milder weather the heat loss from your home will be much lower, so your radiators do not need to be very warm.]]></description>
<p>Forgive me if this is in the wrong section but this is my first post.</p>
<p>My Daikin Alterma seems to be working but I don't have much heat coming through the radiators.</p>
<p>Please can someone tell me if the figures in the attached photo are correct and if not tell me how I can fix this?</p>
<p>Many thanks in advance :)</p>
6716
6715
<p>  s</p>
<p>Are you maintaining the desired indoor temperature?</p>
<p>During milder weather the heat loss from your home will be much lower, so your radiators do not need to be very warm. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28664</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28654</link>
                        <pubDate>Mon, 11 Mar 2024 08:47:55 +0000</pubDate>
                        <description><![CDATA[Hi @uffda. Would you like me to put you in touch with Daikin and their engineer to help sort this out?]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@</span><span>uffda. Would you like me to put you in touch with Daikin and their engineer to help sort this out?</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28654</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28594</link>
                        <pubDate>Sat, 09 Mar 2024 22:11:23 +0000</pubDate>
                        <description><![CDATA[@uffda I’ve just received a message from Daikin who have kindly offered to send out an engineer to you to see if they can resolve the issue. Please let me know if this is of interest.]]></description>
                        <content:encoded><![CDATA[<p>@<span>uffda I’ve just received a message from Daikin who have kindly offered to send out an engineer to you to see if they can resolve the issue. Please let me know if this is of interest.</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28594</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28591</link>
                        <pubDate>Sat, 09 Mar 2024 21:32:11 +0000</pubDate>
                        <description><![CDATA[That’s a daikin hybrid system which uses an intergas boiler as the gas fired bit.
looks like it’s firing at 31 degrees flow temp, which is probably about right depending on your radiator si...]]></description>
                        <content:encoded><![CDATA[<p>That’s a daikin hybrid system which uses an intergas boiler as the gas fired bit.</p>
<p>looks like it’s firing at 31 degrees flow temp, which is probably about right depending on your radiator sizing and the outside temp when you took that photo.</p>
<p>I prefer to spend a bit more on running costs and have my weather comp bottom out at 38.5 degree flow, as you can at least feel that temp flowing through the rads.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28591</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28590</link>
                        <pubDate>Sat, 09 Mar 2024 21:29:35 +0000</pubDate>
                        <description><![CDATA[@uffda welcome to the forums. Is this something that has started recently and the rads were fine up until now?]]></description>
                        <content:encoded><![CDATA[<p><span>@uffda welcome to the forums. Is this something that has started recently and the rads were fine up until now?</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28590</guid>
                        <title>Daikin Altherma ASHP help needed – Radiators are not heating up</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28584</link>
                        <pubDate>Sat, 09 Mar 2024 16:52:56 +0000</pubDate>
                        <description><![CDATA[Forgive me if this is in the wrong section but this is my first post.
My Daikin Alterma seems to be working but I don&#039;t have much heat coming through the radiators.
Please can someone tell...]]></description>
                        <content:encoded><![CDATA[<p>Forgive me if this is in the wrong section but this is my first post.</p>
6716
6715
<p>  s</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-pressure-advice-please/#post-28584</guid>
