									Daikin Altherma 3M in Buckinghamshire - Snoring Noise - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/</link>
            <lastBuildDate>Tue, 18 Aug 2026 05:04:54 +0000</lastBuildDate>
                        <title>RE: Daikin Altherma 3M in Buckinghamshire - Snoring Noise</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-38647</link>
                        <pubDate>Fri, 13 Dec 2024 18:12:05 +0000</pubDate>
                        <description><![CDATA[I don&#039;t know if this helps, but you can change the pump limitation parameter to restrict the top end pump speed. It&#039;s in Installer Settings, so you&#039;ll need to change the user profile to Inst...]]></description>
                        <content:encoded><![CDATA[<p>I don't know if this helps, but you can change the pump limitation parameter to restrict the top end pump speed. It's in Installer Settings, so you'll need to change the user profile to Installer. From there, it's under Installer Settings &gt; Field settings table &gt; 9-0D. Change the value from whatever it is (probably 0) to 4. This will cause the pump speed to run at a maximum of 21lpm on start up. I found the default 30lpm much too loud and found no downsides to dropping this to 21lpm (which is 60%). Since my radiators were happily warm enough at the reduced 11lpm after initial 20 minutes or so, I was fairly sure it'd be fine at 21lpm as well. Sure enough, all rads warm up nicely and maintain their heat. Virtually silent running now. </p>
<p>It's all in the <a href="///Users/geary/Downloads/EB_DLA09-14D3V3_W1_EB_DLA-D3V3_W1_Installer%20reference%20guide_4PEN620241-1B_English.pdf" target="_blank" rel="noopener">Installer Reference Guide.</a></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>chrisgeary</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-38647</guid>
                        <title>RE: Daikin Altherma 3M in Buckinghamshire</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-9104</link>
                        <pubDate>Fri, 22 Jul 2022 06:43:03 +0000</pubDate>
                        <description><![CDATA[Update on this. The bathroom towel rail plumbing was re-routed so that stopped that noise. The low loss header added and that reduced the flow noise in the airing cupboard. apparently if we ...]]></description>
                        <content:encoded><![CDATA[<p>Update on this. The bathroom towel rail plumbing was re-routed so that stopped that noise. The low loss header added and that reduced the flow noise in the airing cupboard. <br />apparently if we want to add underfloor heating downstairs we’d have had to do that anyway?  <br />we’ve also added a bit of soundproof board to the adjacent bedroom wall but don’t know if that works yet as heating is off for summer.</p>
<p>just left with very large electricity bill for the two months when first installed with faulty PCB board so we had to use Booster all the time and run on leaving water temp thermostat.  Really bad that Daikin supplied faulty kit and didn’t compensate us for the consequences.  It’d be like buying a faulty car and getting a huge fuel bill because it was running inefficiency and then refusing to rectify it or compensate.  </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>BridgetJohn</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-9104</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8214</link>
                        <pubDate>Tue, 12 Apr 2022 12:11:01 +0000</pubDate>
                        <description><![CDATA[@bridgetjohn that is the solution I have - see Worcestershire ASHP. 
The purests would say this adds complexity and reduces efficiency. Which is probably true. Ideally you’d change radiator...]]></description>
                        <content:encoded><![CDATA[<p>@bridgetjohn that is the solution I have - see Worcestershire ASHP. <br /><br /></p>
<p>The purests would say this adds complexity and reduces efficiency. Which is probably true. Ideally you’d change radiators and reduce flow temperature. <br />I’m getting SCOP of 3.3 controlled via a Nest. I will change to weather compensation from end of April (after 1year ownership) to compare and hopefully improve SCOP. And my bungalow is warm with no radiator changes </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>JulianC</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8214</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8198</link>
                        <pubDate>Tue, 12 Apr 2022 09:42:54 +0000</pubDate>
Installer has proposed
&quot;We have discussed  your system and feel it would help if we separated the heat pump from the existing system by reconfiguring the buffer vessel to a low lo...]]></description>
                        <content:encoded><![CDATA[<p>@derek-m</p>
<p>Installer has proposed</p>
<p>"<span>We have discussed  your system and feel it would help if we separated the heat pump from the existing system by reconfiguring the buffer vessel to a low loss header and installing a secondary pump to the heating system. This will mean we can control the pump speed around the existing system which should in turn reduce the noise issues. "</span></p>
<p>Any thoughts?</p>
<p>also see above about suspected Single Pipe system.  The house was built in the 70's and extended late 70's. </p>
<p>Thanks in advance.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8198</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8104</link>
                        <pubDate>Thu, 07 Apr 2022 17:25:07 +0000</pubDate>
                        <description><![CDATA[@bridgetjohn Oh dear. I’m surprised that the installer didn’t convert to a 2-pipe system as a routine measure, the 1-pipe systems date back to the early days of central heating and never rea...]]></description>
                        <content:encoded><![CDATA[<p>@bridgetjohn Oh dear. I’m surprised that the installer didn’t convert to a 2-pipe system as a routine measure, the 1-pipe systems date back to the early days of central heating and never really worked well even then.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>cycleneil</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8104</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8073</link>
                        <pubDate>Thu, 07 Apr 2022 08:24:18 +0000</pubDate>
                        <description><![CDATA[@cycleneil Hi, yes, that&#039;s what I understand.  Ours is apparently single pipe and that is what is potentially causing the rushing water noise in the towel rail which links directly off the p...]]></description>
                        <content:encoded><![CDATA[<p>@cycleneil Hi, yes, that's what I understand.  Ours is apparently single pipe and that is what is potentially causing the rushing water noise in the towel rail which links directly off the pipes in the airing cupboard before they disappear into the floorboards and service the rest of the radiators.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8073</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8068</link>
                        <pubDate>Wed, 06 Apr 2022 17:37:13 +0000</pubDate>
                        <description><![CDATA[@bridgetjohn Do you mean single- pipe like the link:
Like that?]]></description>
                        <content:encoded><![CDATA[<p>@bridgetjohn Do you mean single- pipe like the link: https://www.buildingservicesindex.co.uk/entry/136545/AEL-Heating-Solutions-Ltd/Single-or-two-pipe-central-heating-system/</p>
<p>Like that?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/11/#post-8068</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/10/#post-8065</link>
                        <pubDate>Wed, 06 Apr 2022 15:57:39 +0000</pubDate>
                        <description><![CDATA[Hi
so we had a service engineer out from the installation company today.  He said that the noise is due to the water having to go from 22mm into 15mm pipes and having a single pipe system. ...]]></description>
<p>so we had a service engineer out from the installation company today.  He said that the noise is due to the water having to go from 22mm into 15mm pipes and having a single pipe system.  If we switch off the towel rail, it forces water to flow back through the overflow valve.</p>
<p>He did an air purge and said there was no air in the system - the noise literally comes from water rushing round the pipes and that towel rail.</p>
<p>He has lagged the pipes in the airing cupboard.</p>
<p>Does that make any sense?</p>
<p>He seems to be implying that the ASHP can't work with a single pipe system and we may need to change it.  If that's the case, why were we approved for fitting one on the assessment visit?</p>
<p>Thoughts welcome.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/10/#post-8065</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/10/#post-6880</link>
                        <pubDate>Mon, 21 Feb 2022 17:18:39 +0000</pubDate>
                        <description><![CDATA[@derek-m Hi, no not yet I&#039;m afraid.  I think it reduced a bit after following the tip with the valve on top of the holding tank.
I think there is more air to come out of the system, the bat...]]></description>
                        <content:encoded><![CDATA[<p>@derek-m Hi, no not yet I'm afraid.  I think it reduced a bit after following the tip with the valve on top of the holding tank.</p>
<p>I think there is more air to come out of the system, the bathroom towel rail needs attention too.  I suspect your tip with the pressure valve is also relevant, the pipes need lagging and the system balancing.</p>
<p>I think our next step is, armed with all this info to go back to the installer.  </p>
<p>I'll let you know how I get on.  Thanks.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/10/#post-6880</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/10/#post-6879</link>
                        <pubDate>Mon, 21 Feb 2022 16:15:24 +0000</pubDate>
                        <description><![CDATA[Posted by: @bridgetjohn 
@derek-m Thank you, I&#039;ll try that.  
In the meantime I wonder if the noise dropped a bit after opening the red cap on top of the grey tank.  Its not quiet but pote...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="2361" data-postid="6852" data-mention="bridgetjohn">
<div class="wpforo-post-quote-author"><strong> Posted by: @bridgetjohn </strong></div>
<p>@derek-m Thank you, I'll try that.  </p>
<p>In the meantime I wonder if the noise dropped a bit after opening the red cap on top of the grey tank.  Its not quiet but potentially sounds less like a washing machine.</p>
<p>Hi Bridget,</p>
<p>Have you resolved your noise problem yet?</p>
<p>Feedback is always useful.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/daikin-altherma-3m-in-buckinghamshire/paged/10/#post-6879</guid>
Object Caching 57/65 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-08-18 06:04:54 by W3 Total Cache
