									Cost of running my new Air source surprising me - please help on most efficient way to run it! - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/</link>
            <lastBuildDate>Fri, 15 May 2026 02:32:50 +0000</lastBuildDate>
                        <title>RE: Cost of running my new Air source surprising me - please help on most efficient way to run it!</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/3/#post-6921</link>
                        <pubDate>Wed, 23 Feb 2022 14:12:24 +0000</pubDate>
                        <description><![CDATA[Posted by: @derek-m 
Hi @kev-m 
Without me having to go through the manual again, is there a monitoring section within the controller menu, where it is possible to see what the flow and re...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="6" data-postid="5028" data-mention="derek-m">
<div class="wpforo-post-quote-author"><strong> Posted by: @derek-m </strong></div>
<p>Hi @kev-m </p>
<p>Without me having to go through the manual again, is there a monitoring section within the controller menu, where it is possible to see what the flow and return temperatures are actually reading?</p>
<p>Much easier to do this via the melcoud app or web browser. It can show hourly temperatures for flow/return/tank temp etc.</p>
1047]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>George</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/3/#post-6921</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/3/#post-6914</link>
                        <pubDate>Wed, 23 Feb 2022 13:45:53 +0000</pubDate>
                        <description><![CDATA[To edit the compensation curve on the FTC, enter the menu by holding down the menu button instead of pressing it. The menu will look the same at first, but when you go into the options such ...]]></description>
                        <content:encoded><![CDATA[To edit the compensation curve on the FTC, enter the menu by holding down the menu button instead of pressing it. The menu will look the same at first, but when you go into the options such as Heating, you will see extra options, including an Edit option for the compensation curve.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/3/#post-6914</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/3/#post-5097</link>
                        <pubDate>Mon, 27 Dec 2021 14:52:43 +0000</pubDate>
                        <description><![CDATA[Hi @peter 
Thanks for the update. It may be that you do not need to adjust the weather compensation, since auto adaptation should compensate for any differences that may occur. You can down...]]></description>
                        <content:encoded><![CDATA[<p>Hi @peter </p>
<p>Thanks for the update. It may be that you do not need to adjust the weather compensation, since auto adaptation should compensate for any differences that may occur. You can download all the installation and operation manuals should you require more detailed information.</p>
<p>I am pleased to see that your energy consumption is now only 25% to 30% of the previous day. Well worth a little time and effort.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/3/#post-5097</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5095</link>
                        <pubDate>Mon, 27 Dec 2021 14:18:25 +0000</pubDate>
                        <description><![CDATA[@derek-m Sorry - been busy with family in over Christmas etc
I have moved the remote controller down to the living area and removed the schedules from all the thermostats.  So its now runni...]]></description>
                        <content:encoded><![CDATA[<p>@derek-m Sorry - been busy with family in over Christmas etc</p>
<p>I have moved the remote controller down to the living area and removed the schedules from all the thermostats.  So its now running on AutoAdaptation set to 20 degrees with the controller in the living room.  And its working really well - so thanks!  House is keeping a consistent temperature, heating costs are down.  </p>
<p>So thanks for all your help. </p>
<p>On the weather compensation curve - I haven't been able to edit it.  There doesn't seem to be an edit button and the manual just suggests contacting the installer.  </p>
<p>I also managed to get Melcloud up and running on wednesday.  so starting to see some data which really helps.</p>
<p>This is my electricity usage record - it was Thursday that i made the changes and removed the remote controller downstairs. So from a electricity usage point of view it seems to be working well.  House has stayed a nice consistent temp as well. </p>
609
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Peter</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5095</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5088</link>
                        <pubDate>Mon, 27 Dec 2021 10:29:42 +0000</pubDate>
                        <description><![CDATA[If Peter&#039;s house is anything like mine it&#039;s all hands to the &#039;pump&#039; to get Christmas done before returning to the heat pump !]]></description>
                        <content:encoded><![CDATA[<p>If Peter's house is anything like mine it's all hands to the 'pump' to get Christmas done before returning to the heat pump !</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>heat-pump-newbie</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5088</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5081</link>
                        <pubDate>Sun, 26 Dec 2021 13:39:31 +0000</pubDate>
Did you move the remote controller into your living area? Did you make the suggested changes?
If you do not provide feedback then it limits how much help and advice we can provi...]]></description>
<p>Did you move the remote controller into your living area? Did you make the suggested changes?</p>
<p>If you do not provide feedback then it limits how much help and advice we can provide, and makes me wonder if I am wasting my time trying to help.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5081</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5080</link>
                        <pubDate>Sun, 26 Dec 2021 13:15:09 +0000</pubDate>
                        <description><![CDATA[@hr_3 Sorry a little bit misleading there.  £13 was total electricity, not just the airsource/hot water.  
It was just what prompted me to decide I needed to figure out the most efficien...]]></description>
                        <content:encoded><![CDATA[<p>@hr_3 Sorry a little bit misleading there.  £13 was total electricity, not just the airsource/hot water.  </p>
<p>It was just what prompted me to decide I needed to figure out the most efficient way of running the air source.  </p>
<p>It's a completely different mindset to a normal heating system, so glad to get feedback on whether my costs are reasonable.  Thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5080</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5063</link>
                        <pubDate>Sat, 25 Dec 2021 21:06:23 +0000</pubDate>
                        <description><![CDATA[Hi Peter
How are you working out £13 per day?
621kw in Nov at say 21p per unit works out at £4.3 pd plus your water, no way £13 per day
Your usage doesn&#039;t seem that high if I am honest,]]></description>
                        <content:encoded><![CDATA[<p>Hi Peter</p>
<p>How are you working out £13 per day?</p>
<p>621kw in Nov at say 21p per unit works out at £4.3 pd plus your water, no way £13 per day</p>
<p>Your usage doesn't seem that high if I am honest, </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Hr_3</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5063</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5052</link>
                        <pubDate>Fri, 24 Dec 2021 15:33:35 +0000</pubDate>
no, I tried that, pressing holding and the other F butttons but nothing.]]></description>
                        <content:encoded><![CDATA[<p>@derek-m </p>
<p>no, I tried that, pressing holding and the other F butttons but nothing.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5052</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5051</link>
                        <pubDate>Fri, 24 Dec 2021 15:24:23 +0000</pubDate>
                        <description><![CDATA[Posted by: @kev-m 
Wow, this is something I&#039;ve never seen. Holding down F1 gives this.  The Set Temp. (flow) is what the weather compensation curve says flow temp should be.  If I change th...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="15" data-postid="5037" data-mention="kev-m">
<div class="wpforo-post-quote-author"><strong> Posted by: @kev-m </strong></div>
<p>Wow, this is something I've never seen. Holding down F1 gives this.  The Set Temp. (flow) is what the weather compensation curve says flow temp should be.  If I change the offset, that number changes. (Remember due to my duff sensors the flow temp is under reading by about 5-6C so when weather comp asks for 28C it actually delivers 33-34C, which is what my own thermometer says).</p>
<p>Quite useful.</p>
605
<p>  </p>
<p>Hi Kev,</p>
<p>If you press F1 more than once, are there any additional screens?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/cost-of-running-my-new-air-source-surprising-me-please-help-on-most-efficient-way-to-run-it/paged/2/#post-5051</guid>
