									Boxing in your cylinders. - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/</link>
            <lastBuildDate>Fri, 07 Aug 2026 10:56:05 +0000</lastBuildDate>
                        <title>RE: Boxing in your cylinders.</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/paged/2/#post-16464</link>
                        <pubDate>Fri, 17 Feb 2023 11:34:08 +0000</pubDate>
                        <description><![CDATA[@marvinator80 good on them. I wish my installer hadn&#039;t now, as it adds nothing and probably robs efficiency. It may be coming out one day. I don&#039;t need it for system volume with 22 radiators...]]></description>
                        <content:encoded><![CDATA[@marvinator80 good on them. I wish my installer hadn't now, as it adds nothing and probably robs efficiency. It may be coming out one day. I don't need it for system volume with 22 radiators and a 10kW unit. ;)]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/paged/2/#post-16464</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-16462</link>
                        <pubDate>Fri, 17 Feb 2023 11:22:16 +0000</pubDate>
                        <description><![CDATA[@allyfish hi ally, no they definitely didn’t.]]></description>
                        <content:encoded><![CDATA[@allyfish hi ally, no they definitely didn’t.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Marvinator80</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-16462</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-16460</link>
                        <pubDate>Fri, 17 Feb 2023 11:16:25 +0000</pubDate>
                        <description><![CDATA[@marvinator80 WOW! Absolutely fantastic. Very tidy.Out of interest, did your installer fit a low loss header and secondary pump or not? I don&#039;t see one there. I don&#039;t think single zone ASHPs...]]></description>
                        <content:encoded><![CDATA[@marvinator80 WOW! Absolutely fantastic. Very tidy.<br /><br />Out of interest, did your installer fit a low loss header and secondary pump or not? I don't see one there. I don't think single zone ASHPs need them, not with 15, 22 &amp; 28mm piping or underfloor circuits. Grant tend to default to using them, they had some issues with retrofits using 10mm and mircobore which need a higher delta T over the emitters, and could not get the required flow higher delta T and lower rate through them compared to standard 15mm piped rads without hydraulic de-coupling of ASHP from heating circuit. It's a compromise solution in my mind.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-16460</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-16454</link>
                        <pubDate>Fri, 17 Feb 2023 10:40:25 +0000</pubDate>
                        <description><![CDATA[Delighted with this outcome.]]></description>
                        <content:encoded><![CDATA[<p>Delighted with this outcome.</p>
3061
2586]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-16454</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15086</link>
                        <pubDate>Sat, 28 Jan 2023 07:45:18 +0000</pubDate>
                        <description><![CDATA[You could do something with the door but clearly a bigger change 
A more drastic solution is to reverse what looks like a back door and or fit a door a bit narrower if that would help. 
Or...]]></description>
                        <content:encoded><![CDATA[<p>You could do something with the door but clearly a bigger change </p>
<p>A more drastic solution is to reverse what looks like a back door and or fit a door a bit narrower if that would help. </p>
<p>Or have the door open out rather than in to the house. We have that on one of our doors in a utility room where room is tight </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Jeff</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15086</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15077</link>
                        <pubDate>Fri, 27 Jan 2023 20:29:31 +0000</pubDate>
                        <description><![CDATA[You could also box off just the front and left side and hide it behind a curtain on the side by the door if there&#039;s not enough space there.]]></description>
                        <content:encoded><![CDATA[<p>You could also box off just the front and left side and hide it behind a curtain on the side by the door if there's not enough space there.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>scrchngwsl</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15077</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15064</link>
                        <pubDate>Fri, 27 Jan 2023 16:29:01 +0000</pubDate>
                        <description><![CDATA[We have builders here just now due to the garage. Got them to have a look and they reckon it can be done!]]></description>
                        <content:encoded><![CDATA[<p>We have builders here just now due to the garage. Got them to have a look and they reckon it can be done! </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15064</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15047</link>
                        <pubDate>Fri, 27 Jan 2023 11:20:13 +0000</pubDate>
looks like you could squeeze in some 12mm ply?]]></description>
                        <content:encoded><![CDATA[<p>@marvinator80 </p>
<p>looks like you could squeeze in some 12mm ply?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15047</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15031</link>
                        <pubDate>Fri, 27 Jan 2023 09:27:11 +0000</pubDate>
                        <description><![CDATA[@marvinator80, let us know what you decide.]]></description>
                        <content:encoded><![CDATA[@marvinator80, let us know what you decide.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15031</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15026</link>
                        <pubDate>Thu, 26 Jan 2023 22:09:39 +0000</pubDate>
                        <description><![CDATA[@editor yes it’s very tight with the door in mind. We shall see!]]></description>
                        <content:encoded><![CDATA[@editor yes it’s very tight with the door in mind. We shall see!]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/boxing-in-your-cylinders/#post-15026</guid>
Served from: renewableheatinghub.co.uk @ 2026-08-07 11:56:05 by W3 Total Cache
