									Repiping and Reconfiguring our Heat Pump System Including Removing the Buffer Tank - Heat Pump Retrofix - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/</link>
            <lastBuildDate>Fri, 17 Jul 2026 12:22:15 +0000</lastBuildDate>
                        <title>RE: Repiping and Reconfiguring our Heat Pump System Including Removing the Buffer Tank - Heat Pump Retrofix</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50571</link>
                        <pubDate>Wed, 15 Oct 2025 12:48:20 +0000</pubDate>
                        <description><![CDATA[Even that may not be enough.  Air can still collect, it seems, at local high points eg tall radiators, which will need to be manually bled unless also fitted with an an ARV.  Despite having ...]]></description>
<p>Merely having air-release valves present isn't enough.<br />They also need to be placed at the highest points in the pipework because that's where the air will collect.</p>
<p>Even that may not be enough.  Air can still collect, it seems, at local high points eg tall radiators, which will need to be manually bled unless also fitted with an an ARV.  Despite having an ARV at what is otherwise the highest point, I have 2 tall radiators one of which had to be bled every other day for a month and one of which I had to bleed recently.  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50571</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50564</link>
                        <pubDate>Wed, 15 Oct 2025 12:12:46 +0000</pubDate>
                        <description><![CDATA[Exactly what I said in the video, and that is one of the worst AAVs in the market, so they can expect leaks in the future.
                        <content:encoded><![CDATA[Exactly what I said in the video, and that is one of the worst AAVs in the market, so they can expect leaks in the future.<br />
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Pirate Rich</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50564</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50563</link>
                        <pubDate>Wed, 15 Oct 2025 11:52:45 +0000</pubDate>
                        <description><![CDATA[Merely having air-release valves present isn&#039;t enough.They also need to be placed at the highest points in the pipework because that&#039;s where the air will collect.
Look at this photo of a cy...]]></description>
                        <content:encoded><![CDATA[<p>Merely having air-release valves present isn't enough.<br />They also need to be placed at the highest points in the pipework because that's where the air will collect.</p>
<p>Look at this photo of a cylinder fitted sideways on in a cramped attic space:</p>
12151]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50563</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50549</link>
                        <pubDate>Wed, 15 Oct 2025 08:10:42 +0000</pubDate>
                        <description><![CDATA[After our recent heat pump ordeal, we learned a hard lesson: there are key system accessories you MUST discuss with your installer. Never let them skip a proper air release product because t...]]></description>
                        <content:encoded><![CDATA[<p class="ds-markdown-paragraph"><span>After our recent heat pump ordeal, we learned a hard lesson: there are key system accessories you MUST discuss with your installer. Never let them skip a proper air release product because trapped air is a nightmare!</span></p>
<p class="ds-markdown-paragraph"><span>We spoke with @pirate-rich to identify upgrades that can make a difference. Arm yourself with the right questions to ask before your installation.</span></p>
<p class="ds-markdown-paragraph"><span>Watch now: https://youtu.be/9n6R937sTsM</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50549</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50210</link>
                        <pubDate>Sat, 11 Oct 2025 09:04:30 +0000</pubDate>
                        <description><![CDATA[Thank you. That simultaneously answers my question about the bore and level of pipe insulation for the underground section.
Now we know one of the causes of global warming! &#x1f928;]]></description>
                        <content:encoded><![CDATA[<p>Thank you. That simultaneously answers my question about the bore and level of pipe insulation for the underground section.</p>
<p>Now we know one of the causes of global warming! &#x1f928; </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50210</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50199</link>
                        <pubDate>Sat, 11 Oct 2025 01:37:43 +0000</pubDate>
                        <description><![CDATA[&#x1f3f4;&#x200d;&#x2620;&#xfe0f;&#x1f52d;&#x1f602;&#x1f499;&#x1f44d;&#x1f3fb;
<p>As promised, here's Cap'n Burrows delivering on his promise during a long day of filming. Nearly fours of raw content to edit! Enjoy the short clip.</p>
12103
<p>&#x1f3f4;&#x200d;&#x2620;&#xfe0f;&#x1f52d;&#x1f602;&#x1f499;&#x1f44d;&#x1f3fb;</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50199</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50190</link>
                        <pubDate>Fri, 10 Oct 2025 20:42:45 +0000</pubDate>
                        <description><![CDATA[As promised, here&#039;s Cap&#039;n Burrows delivering on his promise during a long day of filming. Nearly fours of raw content to edit! Enjoy the short clip.]]></description>
                        <content:encoded><![CDATA[<p>As promised, here's Cap'n Burrows delivering on his promise during a long day of filming. Nearly fours of raw content to edit! Enjoy the short clip.</p>
12103]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50190</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50114</link>
                        <pubDate>Thu, 09 Oct 2025 17:54:49 +0000</pubDate>
                        <description><![CDATA[If you&#039;ve never played (or heard of) Pirate Fluxx, then I recommend it.It&#039;s the best of the Fluxx varients, and very suitable for drawing a crowd together at a pub &#x1f37b; 
However, I s...]]></description>
                        <content:encoded><![CDATA[<p>If you've never played (or heard of) <a href="https://www.bgextras.co.uk/looney-labs/fluxx/pirate-fluxx-card-game" target="_blank" rel="noopener">Pirate Fluxx</a>, then I recommend it.<br />It's the best of the Fluxx varients, and very suitable for drawing a crowd together at a pub &#x1f37b; </p>
12094
<p>However, I seem to have drawn the conversation so far away from the topic title that my more serious question about <a href="https://renewableheatinghub.co.uk/forums/postid/50098/" target="_blank" rel="noopener">the bore and insulation of Mars' underground pipes</a> has been overlooked.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50114</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50111</link>
                        <pubDate>Thu, 09 Oct 2025 17:08:47 +0000</pubDate>
                        <description><![CDATA[@majordennisbloodnok There’s Rrwwroooom for all shades of complexion I think.]]></description>
                        <content:encoded><![CDATA[<ol>
<li>@majordennisbloodnok There’s Rrwwroooom for all shades of complexion I think.</li>
</ol>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/11/#post-50111</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/10/#post-50110</link>
                        <pubDate>Thu, 09 Oct 2025 17:01:00 +0000</pubDate>
                        <description><![CDATA[If I managed that, I’d be tickled pink.
<p>@majordennisbloodnok Is that an attempt to Panther for all tastes?</p>
<p>If I managed that, I’d be tickled pink.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/big-changes-coming-to-our-heat-pump-system/paged/10/#post-50110</guid>
Served from: renewableheatinghub.co.uk @ 2026-07-17 13:22:15 by W3 Total Cache
