									Daikin Altherma noisy heat pump - help and advice needed - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/</link>
            <lastBuildDate>Sat, 12 Sep 2026 08:44:10 +0000</lastBuildDate>
                        <title>RE: Daikin Altherma noisy heat pump - help and advice needed</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/6/#post-37925</link>
                        <pubDate>Mon, 25 Nov 2024 19:21:58 +0000</pubDate>
                        <description><![CDATA[Hi @clairelp  I’m not sure if you will see this as it has been some time since your earlier messages, but if you can, please can you let me know the name of the people that helped fix your s...]]></description>
                        <content:encoded><![CDATA[<p>Hi @clairelp  I’m not sure if you will see this as it has been some time since your earlier messages, but if you can, please can you let me know the name of the people that helped fix your system? I’m based not too far from you on the Suffolk/Essex border and am having similar troubles with loud, intermittent noises I think coming from the pipes since I had an ASHP installed. It has made 2 bedrooms almost unusable unfortunately. Thank you! (And thanks also to everyone who also helpfully made suggestions on this thread - good ideas for me to back to my installer with).</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>AndyRisk</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/6/#post-37925</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/6/#post-29289</link>
                        <pubDate>Thu, 28 Mar 2024 11:03:43 +0000</pubDate>
                        <description><![CDATA[Hello,
So we had another visit yesterday, two installers with lot more experience. They sorted it, in about 30 minutes. They unclipped the pipes from the ceiling joists, so they now just si...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p>
<p>So we had another visit yesterday, two installers with lot more experience. They sorted it, in about 30 minutes. They unclipped the pipes from the ceiling joists, so they now just sitting on top of insulation. Said they okay to leave as not moving. </p>
<p>like you all recommended it was pipes attached to joists. <br /><br />They said from the beginning they wouldn’t have installed as their colleagues had. They would have gone from the top of roof and put the volumiser on top of the airing cupboard. The ceiling was  like  a drum vibrating from the pipes. </p>
<p>Anyway so far so good and we wasn’t woken last night. hope this may help someone else. We do still have noise but that is purely the ashp and when it’s not on full speed you can’t hear it. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Clairelp</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/6/#post-29289</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29143</link>
                        <pubDate>Sat, 23 Mar 2024 19:40:29 +0000</pubDate>
                        <description><![CDATA[The old volumiser used to have 28mm entry and 22mm exit now have 28mm in and out, then reducing to 22mm somewhere between volumiser and the airing cupboard before going into manifold. 
we a...]]></description>
                        <content:encoded><![CDATA[<p>The old volumiser used to have 28mm entry and 22mm exit now have 28mm in and out, then reducing to 22mm somewhere between volumiser and the airing cupboard before going into manifold. </p>
<p>we are wondering if this could be the noise. The force of change of thickness and if it would be better to be 28mm to the manifold. Just idea we thinking. Not sure what sort of noise this would make. </p>
<p>the installers are good at trying to sort the problem, I just don’t think they know what to do. So we trying to find out ourselves.</p>
<p>they didn’t sent specialist this time as they said they wanted to try changing the volumiser first. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29143</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29136</link>
                        <pubDate>Sat, 23 Mar 2024 15:21:43 +0000</pubDate>
                        <description><![CDATA[New added noise on top of the usual annoying whirring sound. is a drumming, like an old ceiling fan going round. Which you can’t hear in the loft like can in the rooms. I think it must be so...]]></description>
                        <content:encoded><![CDATA[<p>New added noise on top of the usual annoying whirring sound. is a drumming, like an old ceiling fan going round. Which you can’t hear in the loft like can in the rooms. I think it must be something under insulation. It’s definitely not the ashp unit, as can hear that, that’s different. Also didn’t have this noise before them came. So we now have more then one noise issue to solve &#x1f62c; </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29136</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29135</link>
                        <pubDate>Sat, 23 Mar 2024 15:07:17 +0000</pubDate>
                        <description><![CDATA[@derek-m yes sorry think so. They seem to call it different things.]]></description>
                        <content:encoded><![CDATA[@derek-m yes sorry think so. They seem to call it different things.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29135</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29133</link>
                        <pubDate>Sat, 23 Mar 2024 14:39:24 +0000</pubDate>
                        <description><![CDATA[It would appear to be a volumiser rather than a buffer tank.]]></description>
                        <content:encoded><![CDATA[It would appear to be a volumiser rather than a buffer tank.
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29133</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29130</link>
                        <pubDate>Sat, 23 Mar 2024 13:59:19 +0000</pubDate>
                        <description><![CDATA[This also put a new buffer In. Lot of waste of money.]]></description>
                        <content:encoded><![CDATA[<p>This also put a new buffer In. Lot of waste of money. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29130</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29129</link>
                        <pubDate>Sat, 23 Mar 2024 13:58:24 +0000</pubDate>
                        <content:encoded><![CDATA[6847]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29129</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29128</link>
                        <pubDate>Sat, 23 Mar 2024 13:57:18 +0000</pubDate>
                        <description><![CDATA[Hi, 
We had another one of their installers come. They changed the entry into the buffer to a side entry and changed some pipe to 28mm. And they attached buffer to the wall instead of the w...]]></description>
                        <content:encoded><![CDATA[<p>Hi, </p>
<p><br />We had another one of their installers come. They changed the entry into the buffer to a side entry and changed some pipe to 28mm. And they attached buffer to the wall instead of the wood. </p>
<p>also they sorted the pipe that was attached to the floor with no insulation under. </p>
<p>however they have made it worse as we also now have the noise in bathroom and another bedroom rather then just one bedroom. <br /><br /></p>
<p>Husband has spoke to Daikain who said will sent out someone to look at it. <br /><br /></p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-29128</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-28456</link>
                        <pubDate>Wed, 06 Mar 2024 15:00:36 +0000</pubDate>
                        <description><![CDATA[@clairelp That sounds positive. Glad you are on the way to getting the noise sorted. &#x1f600;]]></description>
                        <content:encoded><![CDATA[@clairelp That sounds positive. Glad you are on the way to getting the noise sorted. &#x1f600;]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Louise Howlett</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-noise-help/paged/5/#post-28456</guid>
Served from: renewableheatinghub.co.uk @ 2026-09-12 09:44:10 by W3 Total Cache
