									ASHP at cold temperatures - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/</link>
            <lastBuildDate>Mon, 16 Nov 2026 10:44:00 +0000</lastBuildDate>
                        <title>RE: ASHP at cold temperatures</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/4/#post-13392</link>
                        <pubDate>Sat, 24 Dec 2022 09:39:35 +0000</pubDate>
                        <description><![CDATA[@Huwsy,
I don&#039;t think the house can react that quickly.  The drops in flow temp are only for 10 or 15 minutes. Like I said it pulls the average flow temp down, which means my house is about...]]></description>
<p>Hi</p>
<p>Thank you for this.  I see the flow temp drop and the radiators must get colder but the room temps don’t seem to drop. Does it reduce the flow or anything to compensate?</p>
<p>Thanks</p>
<p>@Huwsy,</p>
<p>I don't think the house can react that quickly.  The drops in flow temp are only for 10 or 15 minutes. Like I said it pulls the average flow temp down, which means my house is about 1 degree cooler than it should be.  I try to aim for 21.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/4/#post-13392</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/4/#post-13390</link>
                        <pubDate>Sat, 24 Dec 2022 07:45:38 +0000</pubDate>
                        <description><![CDATA[Kev - your room temp line looks suspiciously straight to me. It is almost a perfect flat line, with a minute wobble at about 0830. My room temp measured hourly even when in steady state cond...]]></description>
<p>On my system, defrosts definitely lower the flow temp, both on the monitoring and the rads getting noticeably cooler. Does it make the house cooler?  Almost certainly because the average flow temp shown in the graph below is about 3 deg lower that the WC target. Interestingly, defrosting neither increases power used nor decreases the COP.  It would have done both had I maintained the WC flow temp by bumping up the curve. </p>
<figure contenteditable="false">
<div class="wpfa-item wpfa-img"><a title="Defrosts" href="https://renewableheatinghub.co.uk/wp-content/uploads/wpforo/attachments/15/2066-Defrosts.png?x86989"><img class="jetpack-lazy-image jetpack-lazy-image--handled lazy" style="max-width: 400px;max-height: 300px" title="Defrosts" src="data:image/svg+xml,%3Csvg%20xmlns%3D%22http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg%22%20viewBox%3D%220%200%201%201%22%3E%3C%2Fsvg%3E" data-src="https://renewableheatinghub.co.uk/wp-content/uploads/wpforo/attachments/15/thumbnail/2066-Defrosts.png?x86989" alt="Defrosts" /></a></div>
</figure>
<p>Kev - your room temp line looks suspiciously straight to me. It is almost a perfect flat line, with a minute wobble at about 0830. My room temp measured hourly even when in steady state conditions varies by a degree or a bit less either side of a mean. Your ambient record on the other hand is sensitive enough to pick up the brief warming caused by the defrosts. Such a plot would have me wondering about that room temp line, or rather the sensor, and what is actually being plotted. It wouldn't need to be much flatter for me to think it was plotting the set temperature rather than the actual temperature. Might be worth checking what another unconnected room thermometer shows.     </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/4/#post-13390</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/4/#post-13389</link>
                        <pubDate>Fri, 23 Dec 2022 22:44:00 +0000</pubDate>
<p>Hi</p>
<p>Thanks</p>
<p>@Huwsy,</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/4/#post-13389</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13388</link>
                        <pubDate>Fri, 23 Dec 2022 21:20:46 +0000</pubDate>
                        <description><![CDATA[It is all to do with the amount of stored heat energy and its location. A litre of water contains approximately 3500 times more energy than a litre of air. When an ASHP carries out a defrost...]]></description>
<p>Hi</p>
<p>Thanks</p>
<p>It is all to do with the amount of stored heat energy and its location. A litre of water contains approximately 3500 times more energy than a litre of air. When an ASHP carries out a defrost cycle, it uses electrical energy to drive the compressor and heat the refrigerant gas, along with heat energy from the water, or in your case air, to provide the heat necessary to melt the ice on the evaporator.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13388</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13387</link>
                        <pubDate>Fri, 23 Dec 2022 21:02:42 +0000</pubDate>
                        <description><![CDATA[Hi
Thanks]]></description>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>HuwSy</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13387</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13386</link>
                        <pubDate>Fri, 23 Dec 2022 20:03:36 +0000</pubDate>
                        <description><![CDATA[On my system, defrosts definitely lower the flow temp, both on the monitoring and the rads getting noticeably cooler. Does it make the house cooler?  Almost certainly because the average flo...]]></description>
                        <content:encoded><![CDATA[<p>On my system, defrosts definitely lower the flow temp, both on the monitoring and the rads getting noticeably cooler. Does it make the house cooler?  Almost certainly because the average flow temp shown in the graph below is about 3 deg lower that the WC target. Interestingly, defrosting neither increases power used nor decreases the COP.  It would have done both had I maintained the WC flow temp by bumping up the curve. </p>
2066
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13386</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13385</link>
                        <pubDate>Fri, 23 Dec 2022 19:48:02 +0000</pubDate>
So on a air to air a defrost cycle actively blows cold 10-15C air into the room (for at least 7 minutes typically 10-20min) but are you saying an air to water during defrost the radiator...]]></description>
<p>So on a air to air a defrost cycle actively blows cold 10-15C air into the room (for at least 7 minutes typically 10-20min) but are you saying an air to water during defrost the radiators in the home hardly change in temperature at all?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13385</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13379</link>
                        <pubDate>Fri, 23 Dec 2022 10:37:21 +0000</pubDate>
                        <description><![CDATA[I doubt that having a PHE will make much if any difference to the defrost cycle.
The temperature change at the flow and return temperature sensors will be much more noticeable, because all ...]]></description>
<p>The primary water flow does not change direction, it is the refrigerant gas flow inside the heat pump which changes direction.</p>
<p>That's what I thought, it's the heat pump that 'inverts' to become a fridge, and uses the warm exhaust gas from the fridge to do the defrosting (put like this, it does shows it is a somewhat bizarre thing to be doing in cold weather...). But I needed to get my head round what the primary circuit does, and yes, now I have got it: the 'fridge' takes the heat from the returning water which is still going round the circuit the same normal way, and as a result, the leaving water has a lower temp than the returning water.</p>
<p>But that still leaves the question of whether the PHE somehow provides some protection against heat being lost from the secondary circuit. Based on only a few observations, I could see the LWT falling and then rising over a period of a few minutes, but a nearby and not particularly large rad didn't appear to change temp to the same extent, if at all. The reason for asking this rather obscure question is if it does provide any meaningful protection, then it becomes a possible argument in favour of PHEs. </p>
<p>I doubt that having a PHE will make much if any difference to the defrost cycle.</p>
<p>The temperature change at the flow and return temperature sensors will be much more noticeable, because all the water flow is going through the same pipes at that point. This water flow is shared over the number of radiators within the system, so the temperature change at the radiators will be much smaller.</p>
<p>The same process will take place whether a PHE is installed or not.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13379</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13375</link>
                        <pubDate>Fri, 23 Dec 2022 08:23:12 +0000</pubDate>
                        <description><![CDATA[That&#039;s what I thought, it&#039;s the heat pump that &#039;inverts&#039; to become a fridge, and uses the warm exhaust gas from the fridge to do the defrosting (put like this, it does shows it is a somewhat...]]></description>
<p>But that still leaves the question of whether the PHE somehow provides some protection against heat being lost from the secondary circuit. Based on only a few observations, I could see the LWT falling and then rising over a period of a few minutes, but a nearby and not particularly large rad didn't appear to change temp to the same extent, if at all. The reason for asking this rather obscure question is if it does provide any meaningful protection, then it becomes a possible argument in favour of PHEs. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13375</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13364</link>
                        <pubDate>Thu, 22 Dec 2022 20:12:31 +0000</pubDate>
                        <description><![CDATA[The primary water flow does not change direction, it is the refrigerant gas flow inside the heat pump which changes direction.]]></description>
<p>Not if you have a GSHP, which I believe is often the case in the Scandinavian countries.</p>
<p>Good point about GSHPs. It would still be interesting to know how other countries deal with ASHP frosting. Maybe they adopt @batalto's solution, choose to live where it is -10! But even in Finland and other cold places, there must be times in the year when they are in frosting temps.</p>
<p>The Midea seems fairly quick in it's defrost cycles, and when I've seen one happen, there isn't much of a dip in the secondary circuit temperature. I wonder if that may be a hidden benefit of the plate heat exchanger? If the direction of flow in the primary circuit reverses - not sure whether it does or not, but I think it must do, because the LWT goes below the RWT - then the PHE is the wrong way round, parallel flow rather than contraflow, and so it will be less efficient, and the secondary circuit will lose less heat back to the primary circuit. The heat pump then only has to heat the primary circuit during recovery.    </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/ashp-at-cold-temperatures/paged/3/#post-13364</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-16 10:44:00 by W3 Total Cache
