									Aira Heat Pump: Stylish Scandinavian Heating - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/</link>
            <lastBuildDate>Fri, 13 Nov 2026 16:33:14 +0000</lastBuildDate>
                        <title>RE: Aira Heat Pump: Stylish Scandinavian Heating</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63365</link>
                        <pubDate>Fri, 29 May 2026 10:25:20 +0000</pubDate>
                        <description><![CDATA[As anyone with any kind of Internet savvy will know, this is one of the major red flags when looking out for malicious emails. Scammers deliberately manufacture an artificial sense of urgenc...]]></description>
<p>This sort of thing honestly makes my skin crawl.</p>
<p>“Sign within 24 hours or lose £1,000” is not how a homeowner-focused heating transition should work. It’s straight out of the double-glazing playbook from the 1990s… not what you’d expect from a company positioning itself as a modern, trusted renewable brand.</p>
15142
<p>If the system is correctly designed and correctly priced today, it’ll still be correctly designed and correctly priced in a few days’ time, after the homeowner has had a chance to compare quotes, ask questions here, review the heat loss calculation, ask technical questions and think clearly without someone breathing down their neck.</p>
<p>The industry talks endlessly about building consumer confidence and I think tactics like this actively destroy it.</p>
<p> “Act now.” “Today only.” “Last chance.” “Everything must go.” It’s textbook scarcity BS designed to compress the decision window before the customer has time to properly interrogate the proposal or get independent advice.</p>
<p>Of course that doesn’t mean every Aira installation is poor. But high-pressure sales and good engineering culture are uncomfortable bedfellows IMO. A good heat pump design and proposal should survive scrutiny… it shouldn’t need urgency to close the deal.</p>
<p>As anyone with any kind of Internet savvy will know, this is one of the major red flags when looking out for malicious emails. Scammers deliberately manufacture an artificial sense of urgency to try to manipulate the email recipient into action.</p>
<p>From previous threads, Aira have been found to try stopping homeowners from installing independent monitoring (implying this may void their warranty). Now this "buy now or lose out" tactic. Approaches like that are only used when the product won't speak for itself, so it begs the question of what Aira are worried about people finding out. If their installations bear scrutiny, why not welcome potential buyers comparing and contrasting? If their installations bear scrutiny, why not welcome third party monitoring to corroborate? If their installations bear scrutiny, why not let the home owners have access to their own historic data?</p>
<p>The only conclusion I can draw is that Aira, using badged Vaillant kit as it does, is perfectly capable of installing a well performing system but no better than any other competent installer, and they don't want consumers to know that because they want to be able to mark their own homework.</p>
<p>This becomes more obvious when you look at their claims on their web site. For instance, they claim their Aira Home Energy System (heat pump, solar panels, battery) can save 90% over a standard setup (gas boiler, no solar panels, no battery). They then give a bit of gumph about how they calculate this and it seems reasonable until you actually dive into the detail. They also have a similar bit of gumph to "support" their claim of £490 annual energy bill savings for switching to a heat pump. However, they claim in gumph 1 to assume household use of 10,000 kWh gas and 2,500 kWh electricity (at 5.74p for gas and 24.67p for electricity) and yet in gumph 2 they assume 20,000 kWh gas and 4,500 kWh electricity (at 6.29p for gas and 22.93p for electricity). Both of these they claim are typical of an Aira customer based on Aira's own data. Which is it, Aira?</p>
<p>All these figures, by the way, assume a heat pump efficiency of 4 where we already know from Open Energy Monitor that 3.5 is far more realistic; 4 and above is possible but in a minority of cases and so not reasonable to use as the norm.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63365</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63363</link>
                        <pubDate>Fri, 29 May 2026 09:55:42 +0000</pubDate>
                        <description><![CDATA[I posted earlier about my experience which was not of sales based on solid engineering but on understanding the customer. 
But just curious about your £240 a year cost. Is this including th...]]></description>
<p>The other 14 years would cost approx £240 per year.</p>
<p>Total cost  a big "no thank you."</p>
<p>I posted earlier about my experience which was not of sales based on solid engineering but on understanding the customer. </p>
<p>But just curious about your £240 a year cost. Is this including the yearly service?</p>
<p>As Vaillant also make similarly priced yearly servicing a condition of their typical 7yrs warranty, which makes sense to me. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63363</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63361</link>
                        <pubDate>Fri, 29 May 2026 09:18:24 +0000</pubDate>
                        <description><![CDATA[Had a quote from this company.
The main item to watch other than the price and large buffer tank is their 15 year comfort guarantee.
Mine started at 15 years then moved to 10 with the sale...]]></description>
                        <content:encoded><![CDATA[Had a quote from this company.
Mine started at 15 years then moved to 10 with the sales person and then to one year with the actual contract.
&nbsp;]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>glacken</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63361</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63352</link>
                        <pubDate>Thu, 28 May 2026 22:09:31 +0000</pubDate>
                        <description><![CDATA[@editor They should respond, if I sign today will you install tomorrow and if you cannot meet my 24hr demand will you further discount and loose another £1,000 for me?
Pressure sales needs ...]]></description>
                        <content:encoded><![CDATA[@editor They should respond, if I sign today will you install tomorrow and if you cannot meet my 24hr demand will you further discount and loose another £1,000 for me?
Pressure sales needs to be met with pressure expectations otherwise its a 1 sided deal. Also lets be honest, the only way my company could offer a £1,000 discount is to artificially inflate the job by £1,000 in the 1st place, just saying!
Im not sure any of us as smaller companies really make £1,000 to even try to give away, perhaps I should raise the price by 25% (i'm jesting, we would prefer credibility over hard sales tactics)   
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63352</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63349</link>
                        <pubDate>Thu, 28 May 2026 21:28:16 +0000</pubDate>
                        <description><![CDATA[This sort of thing honestly makes my skin crawl.“Sign within 24 hours or lose £1,000” is not how a homeowner-focused heating transition should work. It’s straight out of the double-glazing p...]]></description>
                        <content:encoded><![CDATA[<p>This sort of thing honestly makes my skin crawl.<br /><br />“Sign within 24 hours or lose £1,000” is not how a homeowner-focused heating transition should work. It’s straight out of the double-glazing playbook from the 1990s… not what you’d expect from a company positioning itself as a modern, trusted renewable brand.</p>
15142
<p><br /><br />If the system is correctly designed and correctly priced today, it’ll still be correctly designed and correctly priced in a few days’ time, after the homeowner has had a chance to compare quotes, ask questions here, review the heat loss calculation, ask technical questions and think clearly without someone breathing down their neck.<br /><br />The industry talks endlessly about building consumer confidence and I think tactics like this actively destroy it.<br /><br /> “Act now.” “Today only.” “Last chance.” “Everything must go.” It’s textbook scarcity BS designed to compress the decision window before the customer has time to properly interrogate the proposal or get independent advice.<br /><br />Of course that doesn’t mean every Aira installation is poor. But high-pressure sales and good engineering culture are uncomfortable bedfellows IMO. A good heat pump design and proposal should survive scrutiny… it shouldn’t need urgency to close the deal.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/35/#post-63349</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-62774</link>
                        <pubDate>Tue, 12 May 2026 10:35:32 +0000</pubDate>
                        <description><![CDATA[I was very pleased with the Aira survey. Even if (more on that later) it did not last more than 15 minutes. 
They booked the survey a few weeks in advance. But asked for no info, so only di...]]></description>
It has been just over a year since we changed over to an Aira heat pump and they swapped out all but one of our radiators. Really pleased with it and the service from Aira, they even came and fitted an extra radiator in a room that wasn't getting warm enough (their pre-install heat loss calculations reckoned that they could take out two old rads and put in one big one, but they should have just replaced both). We have an 8kW unit with a 250L tank.
They booked the survey a few weeks in advance. But asked for no info, so only discovered basic stuff after arrival. 
Great time management and comms on the day. 
When she arrived, she was naturally looking to engage quickly. For praising, she used the quality of the EWI insulation (with lots of questions on the cost). We got past that relatively quickly, and also moved on from discussing our home battery details. 
The conversation was pleasant. But early on, the buffer and justification for it showed some strongly held beliefs. Apparently their installation would not cause much disruption. A few seconds spent visually evaluating space for all the paraphernalia, we got to a new discussion point where I could sense some concerning pride in talking about a case where "the home owner did not want much disruption but, after getting into it,, agreed to around 18 holes in various parts of the house" to place new pipework and the like! 
It looked like a lovely concept house from the external pictures, amazing what people can agree to! The redecorating cost and timeline must have been interesting..
Anyway, after 15 minutes intense discovery, we exchanged advice on mutual ways forward and parted ways. 
It is clear that, if they keep to this approach, Ed's retrofit numbers will be made 99.99% from brands other than Aira. 
For new build, they may be great though. If our green belt continues to be made into grey belt, perhaps the market will explode. But I suspect Aira is one for my next life. 
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-62774</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-56842</link>
                        <pubDate>Wed, 21 Jan 2026 19:47:52 +0000</pubDate>
                        <description><![CDATA[@chandykris Nice, that&#039;s great. Thank you for the update!
Mine was commissioned in Sep 2024; I&#039;ll put in a reminder for myself for Sep 2026 and let you know how it goes then.]]></description>
                        <content:encoded><![CDATA[<p>@chandykris Nice, that's great. Thank you for the update!</p>
<p>Mine was commissioned in Sep 2024; I'll put in a reminder for myself for Sep 2026 and let you know how it goes then.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>trungdong</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-56842</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-56817</link>
                        <pubDate>Wed, 21 Jan 2026 14:57:03 +0000</pubDate>
                        <description><![CDATA[@trungdong Finally, I remembered to call Aira about servicing. Month later than I planned to! They mentioned that servicing is only every two years, so they will call and schedule next Janua...]]></description>
                        <content:encoded><![CDATA[<p>@trungdong Finally, I remembered to call Aira about servicing. Month later than I planned to! They mentioned that servicing is only every two years, so they will call and schedule next January. Also, the helpful customer service agent told me that the magnetic filter needs not be cleaned now if the flow is all fine, and will be checked during the service. But, asked me to call about the filter is there's any problem with the system.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>ChandyKris</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-56817</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-54155</link>
                        <pubDate>Mon, 08 Dec 2025 12:23:27 +0000</pubDate>
                        <description><![CDATA[Aira called me back today, but not sure we got to the actual problem. The support agent was just saying that if I am happy to set the manual schedule I should use that. They won&#039;t tell me wh...]]></description>
                        <content:encoded><![CDATA[<p>Aira called me back today, but not sure we got to the actual problem. The support agent was just saying that if I am happy to set the manual schedule I should use that. They won't tell me whether there is a bug in their algorithms. So, I have just turned smart tariff control off. If they can preheat the house a bit during the off-peak hours slightly higher than the set temperature, I guess it will help. But, not sure how this works, so not going to experiment much and stick to the standard mode.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-54155</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-54125</link>
                        <pubDate>Sun, 07 Dec 2025 10:16:44 +0000</pubDate>
                        <description><![CDATA[Thanks @gmuzz @mikeh 
They still mention on the app that it if you choose smart tariff control they will shift DHW to off peak. They should at least tweak the app to remove that wording unt...]]></description>
                        <content:encoded><![CDATA[<p>Thanks @gmuzz @mikeh </p>
<p>They still mention on the app that it if you choose smart tariff control they will shift DHW to off peak. They should at least tweak the app to remove that wording until they fix their algorithms. I have reached out to Aira Support, will update here when I hear their response.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/aira-heat-pump-stylish-scandinavian-heating/paged/34/#post-54125</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 16:33:14 by W3 Total Cache
