									Air source heat pump roll call – what heat pump brand and model do you have? - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/</link>
            <lastBuildDate>Mon, 05 Oct 2026 18:53:23 +0000</lastBuildDate>
                        <title>RE: Air source heat pump roll call – what heat pump brand and model do you have?</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/13/#post-65800</link>
                        <pubDate>Wed, 05 Aug 2026 06:50:21 +0000</pubDate>
                        <description><![CDATA[Forum Handle: adrian 
Manufacturer: Appliandirect.co.uk
Model: Superheat R32 7kW
Type: ASHP
Arrangement: Mono
Area of Country: Schleswig-Holstein, Germany 
Home Type: detached house
S...]]></description>
                        <content:encoded><![CDATA[<p>Forum Handle: adrian </p>
<p>Manufacturer: Appliandirect.co.uk</p>
<p>Model: Superheat R32 7kW</p>
<p>Type: ASHP</p>
<p>Arrangement: Mono</p>
<p>Area of Country: Schleswig-Holstein, Germany </p>
<p>Home Type: detached house</p>
<p>Size: Square Metres: 100</p>
<p>Insulation Level: 5</p>
<p>Heat Loss Calculation: 6kW @ Amb. Temp, of: -10C</p>
<p>Type of Controller: supplied with HP</p>
<p>Type of Control:, Weather Compensation</p>
<p>Very simple DIY install, got the heatpump refurbished from appliance direct for £568 and installed it with just the minimum components (1x anti freeze valve, y-filter, magnetic filter and expansion vessel). The house already had plenty of radiators as my dad had been told that you needed one under each window and was piped with 18mm copper pipes. Hot water is supplied by an electric instant heater. Total cost £1400. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Adrian</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/13/#post-65800</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/13/#post-65775</link>
                        <pubDate>Tue, 04 Aug 2026 15:00:43 +0000</pubDate>
                        <description><![CDATA[Samsung 16kw has been working well at home in Perthshire for the 1st year since commissioning, though made the error of turning things down while away for a few weeks over Xmas - which of co...]]></description>
                        <content:encoded><![CDATA[<p>Samsung 16kw has been working well at home in Perthshire for the 1st year since commissioning, though made the error of turning things down while away for a few weeks over Xmas - which of course cost a packet to reheat the house and probably strained the kit a bit. Won't do that again, though we do keep heating off over the summer and will restart at end of August.</p>
<p>Have also installed Mitsubishi Ecodan in an old stone cottage on west coast of Ireland (Connemara) after renovations to insulate floor, install UFH, insulate and airtightness, MVHR, triple glazed windows etc.  So far so good but can't quite understand seemingly  high energy consumption in June when it was so mild there.  Now also running only DHW as solar gain and insulation keep house warm (at lease during the heatwave in July). Will heat again from end of August.  One niggle - tried to install the wifi unit (not standard it seems) and the MAC-5971F-E was a trial.  Docs pointed to wrong app (MELCloud Home is the right one).  Blutooth connectivity to start is an issue noted by MEL on their availability pages (https://www.melcloud.com/en/support/service-health/service-statuses-table) as is availability of their servers!  The last may explain why I eventually had to give up as the final registration step to those servers has not yet succeeded. Will try again periodically. A bit annoying after shelling out for the wifi unit but hey ho!</p>
<p>Unit is less than 100m from the sea so some trepidation about longevity and storm survivability tbh (having recently experienced some of the worst that the Atlantic can generate) but we'll see how that goes over time.</p>
<p>Mftr: Mitsubishi</p>
<p>Indoor Model: Ecodan EHST17D-VM2E</p>
<p>Outdoor model: SUZ-SWM40VA</p>
<p>Area: ca. 95m2</p>
<p>Heating: UFH throughout</p>
<p>Occupancy: normally 2, max 6</p>
<p>DHW: 4 sinks, 1 shower. - scheduled for 8hrs a day to see how it goes.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>DowallyDrifter</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/13/#post-65775</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-64856</link>
                        <pubDate>Mon, 06 Jul 2026 21:19:39 +0000</pubDate>
                        <description><![CDATA[&nbsp;
Forum Handle: GotGordon
Manufacturer: Samsung
Model: 16kW EHS Mono Outdoor Unit AE16OCXYBEK/EU
Type: ASHP
Arrangement: Gas Boiler replacement: DHW converted from gravity feed to ...]]></description>
                        <content:encoded><![CDATA[<p>&nbsp;</p>
<p>Forum Handle: GotGordon</p>
<p>Manufacturer: Samsung</p>
<p>Model: 16kW EHS Mono Outdoor Unit AE16OCXYBEK/EU</p>
<p>Type: ASHP</p>
<p>Arrangement: Gas Boiler replacement: DHW converted from gravity feed to mains pressure system</p>
<p>Low temperature (55 C) Two UFH zones with Thermostats &amp; 2 port Valves</p>
<p>+ two radiator circuit loops with 8 radiators + 250 L Tempest  Horizontal DHW Cylinder in loft</p>
<p>Area of Country: Hampshire</p>
<p>Home Type: 4 Bedroom Detached Chalet Bungalow + annexe</p>
<p>Size: 2,152 sq m</p>
<p>Insulation Level: Insulated cavity walls, 2014 refurbished house </p>
<p>Heat Loss Calculation: Energy requirement for heating and hot water total 18045 kWh per year</p>
<p>Type of Controller: Wired controller &amp; WiFi access to Samsung Smart Things</p>
<p>Type of Control: Weather Compensation plus thermostats on 2 x UFH zones</p>
<p>System Type: 2 x UFH zones downstairs, 8 radiators upstairs with TRV's</p>
<p>Total Output of Heat Emitters: 14.5 kW</p>
<p>Buffer Tank : CALEFFI Buffer tank</p>
<p>Secondary Pumps: 2 (UFH manifold mixing valves probably not now necessary)</p>
<p>Solar PV System: 18 panels 5kW SolarEdge Invertor</p>
<p>Power Diverter: EDDI hot water immersion divertor (considering SolarEdge Home Hub off grid divertor)</p>
<p>Battery System: 10kWh SolarEdge</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Gotgordon</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-64856</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-64732</link>
                        <pubDate>Mon, 29 Jun 2026 20:33:21 +0000</pubDate>
                        <description><![CDATA[orum Handle: alincork
Manufacturer: Midea
Model: Mono R32 6kW
Type: ASHP
Arrangement: monobloc
Area of Country: South
Home Type: detached
Size: 120 sq m
Insulation Level: 7/10
Heat ...]]></description>
                        <content:encoded><![CDATA[<p>orum Handle: alincork</p>
<p>Manufacturer: Midea</p>
<p>Model: Mono R32 6kW</p>
<p>Type: ASHP</p>
<p>Arrangement: monobloc</p>
<p>Area of Country: South</p>
<p>Home Type: detached</p>
<p>Size: 120 sq m</p>
<p>Insulation Level: 7/10</p>
<p>Heat Loss Calculation: 5kw</p>
<p>Type of Controller: 2 zones plus hot water</p>
<p>Type of Control: Weather Compensation only</p>
<p>System Type: Radiators throughout house </p>
<p>Total Output of Heat Emitters:</p>
<p>Buffer Tank or Low Loss Header: NA</p>
<p>Secondary Pumps: No</p>
<p>Solar PV System: 10kw 22 panels 5.5kw inverter </p>
<p>Power Diverter: No</p>
<p>Battery System: 32kw </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>alincork</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-64732</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-64035</link>
                        <pubDate>Sat, 13 Jun 2026 11:15:26 +0000</pubDate>
                        <description><![CDATA[Vaillant arotherm plus 12kW.  Installed March 2025.  Excellent performance.  I rarely use its full capacity as it is designed to cover the whole house and as I live alone and have the Honeyw...]]></description>
                        <content:encoded><![CDATA[<p>Vaillant arotherm plus 12kW.  Installed March 2025.  Excellent performance.  I rarely use its full capacity as it is designed to cover the whole house and as I live alone and have the Honeywell controller system with 12 zones to select the temperatures of each zone.  Despite being more powerful than necessary it still is efficient in my 1975 bungalow, which wasn't built to modern standards, and I get a SCOP of 3.6, including heating my water.  Thanks to solar panels, batteries and Octopus Intelligent Go my bills are much lower than when I had gas heating and, in fact, owing to a generous export tariff my energy use costs me nothing, including car charging.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Harebell</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-64035</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62765</link>
                        <pubDate>Mon, 11 May 2026 21:02:16 +0000</pubDate>
                        <description><![CDATA[Ecodan 14Kw R32]]></description>
                        <content:encoded><![CDATA[<p>Ecodan 14Kw R32</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Weemalkie</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62765</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62716</link>
                        <pubDate>Sun, 10 May 2026 13:44:27 +0000</pubDate>
                        <description><![CDATA[Manufacturer: appliances direct/superheat
Model: 7Kw
Type: ASHP.
Arrangement: Monoblock + single zone, open loop. No hot water
Home Type: De...]]></description>
                        <content:encoded><![CDATA[<p>Manufacturer: appliances direct/superheat</p>
<p>Model: 7Kw</p>
<p>Type: ASHP.</p>
<p>Arrangement: Monoblock + single zone, open loop. No hot water</p>
<p>Area of Country: Schleswig-Holstein, Germany</p>
<p>Home Type: Detached, long bungalow. </p>
<p>Size: Square Metres: 120. </p>
<p>Heat Loss Calculation: 6</p>
<p>Type of Controller: supplied with heatpump</p>
<p>Type of Control: Weather compensation </p>
<p>System Type: Radiators. </p>
<p>Buffer Tank or Low Loss Header: No</p>
15003
<p>DIY installation cost w/o grant: £1400</p>
15002]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62716</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62714</link>
                        <pubDate>Sun, 10 May 2026 13:26:03 +0000</pubDate>
Peak system has now replaced with a Grant Aerona r290 12KW and a Grant quick recovery 210l water tank.
Full Weather Compensation control.
No buffer tank or volumiser.
&amp;nbs...]]></description>
<p>Forum Handle: @davec</p>
<p>Manufacturer: Peak Energy</p>
<p>Model: 11kW V-Therm S-Maxi</p>
<p>Type: ASHP</p>
<p>Arrangement: Monobloc</p>
<p>Area of Country: North West England</p>
<p>Home Type: House, semi-detached</p>
<p>Size: Square Metres: 122m2</p>
<p>Insulation level: loft insulation, some suspended floor insulation, no cavity insulation</p>
<p>Heat Loss Calculation: 7kW @ Amb. Temp, of: -2C</p>
<p>Type of Controller: external EPH Thermostat, each radiator with TRV</p>
<p>Type of Control: Weather Compensation, Flow Temperature, Room Temperature via EPH thermostat</p>
<p>System Type: Radiators</p>
<p>Total Output of Heat Emitters: 11 triple column radiators and 2 towel rail radiators</p>
<p>Buffer Tank or Low Loss Header: BT, I think built in to the water cylinder</p>
<p>Solar PV System: SunSynk 3.6kW Inverter with 3.5kWh panels</p>
<p>Power Diverter: Yes solar diverter, but switched off</p>
<p>Battery System: 10kWh house battery</p>
<p>Peak system has now replaced with a Grant Aerona r290 12KW and a Grant quick recovery 210l water tank.</p>
<p>Full Weather Compensation control.</p>
<p>No buffer tank or volumiser.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>DaveC</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62714</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62244</link>
                        <pubDate>Sun, 26 Apr 2026 16:11:57 +0000</pubDate>
                        <description><![CDATA[Forum Handle: ispookie666
Manufacturer: Vaillant
Model: 10Kw
Type: ASHP.
Arrangement: Monoblock + single zone + Unistor 250L tank
Area of Country: Cambridgeshire
Home Type: Detached. ...]]></description>
                        <content:encoded><![CDATA[<p>Forum Handle: ispookie666</p>
<p>Manufacturer: Vaillant</p>
<p>Model: 10Kw</p>
<p>Type: ASHP.</p>
<p>Arrangement: Monoblock + single zone + Unistor 250L tank</p>
<p>Area of Country: Cambridgeshire</p>
<p>Home Type: Detached. </p>
<p>Size: Square Metres: 150. </p>
<p>Insulation Level: 8</p>
<p>Heat Loss Calculation: 8.07</p>
<p>Type of Controller: Vaillant Sensocomfort</p>
<p>Total Output of Heat Emitters: 12</p>
<p>Solar PV System: 9.2 KWp Enphase micro inverters  and export limit of 10.Kwh</p>
<p>Power Diverter: Yes  (disconnected - iBoost) + EV Charger</p>
<p>Battery System: 8.2KWh * 2 Givenergy AC coupled + 2.4KWh * 2 Renogy - Victron Mulplux 2 GX</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>ispookie666</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-62244</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-61951</link>
                        <pubDate>Mon, 20 Apr 2026 18:30:53 +0000</pubDate>
                        <description><![CDATA[Forum Handle: Alan(alan22)
Manufacturer: Valiant
Model: 7kw
Type: ASHP.
Arrangement: No idea.
Area of Country: Ayrshire Scotland.
Home Type: Cottage. 
Size: Square Metres: 185 square ...]]></description>
                        <content:encoded><![CDATA[<p>Forum Handle: Alan(alan22)</p>
<p>Manufacturer: Valiant</p>
<p>Model: 7kw</p>
<p>Type: ASHP.</p>
<p>Arrangement: No idea.</p>
<p>Area of Country: Ayrshire Scotland.</p>
<p>Home Type: Cottage. </p>
<p>Size: Square Metres: 185 square m. </p>
<p>Insulation Level: 8 heading to 9/10</p>
<p>Heat Loss Calculation: I'd need to go check</p>
<p>Type of Controller: black box on the wall, no idea how it works yet.</p>
<p>Type of Control: Adaptive.</p>
<p>Total Output of Heat Emitters: ?</p>
<p>Buffer Tank or Low Loss Header: don't know, it's got a small tank on the wall?</p>
<p>Solar PV System: No</p>
<p>Battery System: No</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>Alan</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/air-source-pump-roll-call/paged/12/#post-61951</guid>
Object Caching 61/73 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-10-05 19:53:23 by W3 Total Cache
