Below is an extract from the MIM-E03CN manual, which is the recommended controller for use with your heat pump.
Do you only have the one water pump?
Is your system still short cycling at the same frequency?
One possible problem could be incorrect settings within the controller. If possible go into the installer menu and make a note of any parameter settings that you can find, and then post the results.
@derek-m I have two pumps I believe. You can see both pumps in this pic.Â
I am still getting short cycling, yes.Â
What settings do you mean, sorry?Â
It's entirely possible the settings are incorrect, I've had to wing it to get as far as I have.Â
What is the temperature setting of the two thermostats, and what is their make and model?
@derek-m okay, I'm not at home at the moment. I'll do it later and report back. I've made various adjustment to water law which is Samsung for WC. The temp in the house is nice and the COP is acceptable too. Just the cycling. Thanks again
The Joule Samsung instructions are available on line, they don’t use a PWM pump. They have a separate interface PCB that comes after the MIM. I’ll see if I can find a link.
I would be inclined to get the installer to wire/plumb it up as per the Midsummer wholesale instructions that give details on how to fit a PWM pump and use the Samsung controller as the room stat.
- 2,171 Topics
- 47.8 K Posts
- 27 Online
- 5,744 Members
We could I'm sure (mine for example, nothing special at...
By JamesPa , 13 minutes ago
How it does it's job is something of a mystery although...
By Abernyte , 2 hours ago
The refresh time of climate-related curves in heating m...
By Tasos , 2 hours ago
RE: MCS certificate SCOP vs real-world performance
MCS:3.65 Reported by Vaillant: 3.96 (heating only); 3....
By JamesPa , 3 hours ago
Yes I was thinking of outdoor, IP65 batteries with buil...
By Temperature_Gradient , 6 hours ago
Water pump will certainly make a hum (which could conce...
By JamesPa , 9 hours ago
@jamespa Thanks. Yeah any adjustments Ive made at pr...
By cliffhanger , 9 hours ago
By GrahamF , 2 days ago
By bontwoody , 2 days ago
By Scalextrix , 2 days ago
By cathodeRay , 3 days ago
By Paul G , 4 days ago
