									Say hello and introduce yourself - Introductions, Forum Rules &amp; Updates				            </title>
            <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/</link>
            <lastBuildDate>Sun, 19 Jul 2026 22:32:52 +0000</lastBuildDate>
                        <title>RE: Say hello and introduce yourself</title>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64798</link>
                        <pubDate>Sat, 04 Jul 2026 07:54:36 +0000</pubDate>
                        <description><![CDATA[@jandp awesome system I hope it works out well.]]></description>
                        <content:encoded><![CDATA[@jandp awesome system I hope it works out well.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/rules-terms-of-use/">Introductions, Forum Rules &amp; Updates</category>                        <dc:creator>Judith</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64798</guid>
                        <title>RE: Finally got everything up and running (well, almost)</title>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64761</link>
                        <pubDate>Tue, 30 Jun 2026 15:24:03 +0000</pubDate>
                        <description><![CDATA[&nbsp;
Hi Guys
I&#039;m new to the forum but have been using a lot of the content from the RHH over the past 12 months or so as a way to try and limit the mistakes in picking and installing a s...]]></description>
                        <content:encoded><![CDATA[<p>&nbsp;</p>
<p>Hi Guys</p>
<p>I'm new to the forum but have been using a lot of the content from the RHH over the past 12 months or so as a way to try and limit the mistakes in picking and installing a system. I wont go into all that on an intro page, but I could not believe the difficulty in trying to do things right, and even then the pitfalls which awaited me. I naïvely thought - get three quotes and go with the cheapest - wow, was I in for a shock &#x1f923; Probably got 7 or 8 quotes in the end and now know more about the process than most of the people who came to quote &#x1f633; I still can't believe companies are so poor at what they are supposed to be professional at, and as soon as I started asking questions, and then questioning their replies, half of them went into scrip mode and answered questions I had not asked, and the other half were like rabbits in the headlights.</p>
<p>Anyway, this is what I went for in the end:</p>
<p>2000sqft 70s bungalow, just getting the underfloor and loft insulation sorted now that the system is pretty much in and up and running, although there are still a couple of small bits which need resolving from the install. I asked all companies to do the heat loss report based on my insulation being right as I was going to do it after the project, so wanted it included in the calculations which were incidentally - ranging from just over 8kw to just over 12kw! &#x1f644; </p>
<p>Heat loss used was Approx. 8.5kw and located in central Scotland not far from the coast. Using a Vaillant 10kw Aerotherm, with standard controls and a 250L slimline Vaillant cylinder. Got 19 radiators linked up to it, mostly new styles, but kept some older ones to reduce the costs, and got new underfloor pipework where required according to the installer.</p>
<p>At the same time I got a large solar system installed, its 34 x 475w Aiko Neostar 475w panels @ 16.1kw, a Sigenstore system with a 12kw inverter and gateway which also has DNO approval for the same, 27kwh of battery storage and a Sigen 7kw EV charger.</p>
<p>I've just started playing with tariffs and asked Googles AI for help on this also - which I'm not convinced is right, but the conversations did give me thinking material, so worth looking at, but I ended up not doing what it suggested anyway. I went for Octopus Agile for both import and export and have left the Sigen AI to manage the process. Again, I'm not sure if this is the right thing to do but you have to start somewhere, so until I have it running a while it will be hard to tell how good it is, and TBH, my initial thoughts were just go for an EV overnight tariff and rely on solar and the batteries during the day (octopus intelligent go is not supported by the Sigen 7kw EV charger BTW), so we will see?? Got my gas disconnected also &#x1f609; </p>
<p>James</p>
15376
15375]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/rules-terms-of-use/">Introductions, Forum Rules &amp; Updates</category>                        <dc:creator>JandP</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64761</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64752</link>
                        <pubDate>Tue, 30 Jun 2026 10:34:51 +0000</pubDate>
                        <description><![CDATA[@alincork, welcome to the forums. It’s great to have someone with your background join us, especially someone who’s worked on both air-to-water and ground source systems. 
Looking forward t...]]></description>
                        <content:encoded><![CDATA[@alincork, welcome to the forums. It’s great to have someone with your background join us, especially someone who’s worked on both air-to-water and ground source systems. 
<p class="p3">Looking forward to your contributions.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/rules-terms-of-use/">Introductions, Forum Rules &amp; Updates</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64752</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64727</link>
                        <pubDate>Mon, 29 Jun 2026 19:54:48 +0000</pubDate>
                        <description><![CDATA[I;m living in Ireland, fridge man by trade, have both A2A and A2W in the house, running on rads. Solar PV on e/w orientation. Been lurking here for a while, interesting to see the difference...]]></description>
                        <content:encoded><![CDATA[<p>I;m living in Ireland, fridge man by trade, have both A2A and A2W in the house, running on rads. Solar PV on e/w orientation. Been lurking here for a while, interesting to see the difference in acceptance of A2W between here and the UK, all new builds here have them since a good few years ago. I've worked on A2W and ground source for many years, stick mainly to AC now. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/rules-terms-of-use/">Introductions, Forum Rules &amp; Updates</category>                        <dc:creator>alincork</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/115/#post-64727</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64693</link>
                        <pubDate>Sun, 28 Jun 2026 17:41:17 +0000</pubDate>
                        <description><![CDATA[@etchedpixels Ours is a little more involved as one room upstairs is outside the original ‘envelope’ as it is a flat roof extension. The ground floor would presumably require disturbing the ...]]></description>
                        <content:encoded><![CDATA[@etchedpixels Ours is a little more involved as one room upstairs is outside the original ‘envelope’ as it is a flat roof extension. The ground floor would presumably require disturbing the floorspace upstairs to provide pipe work to various rooms. I am not sure we are quite ready for this yet! Toodles.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/rules-terms-of-use/">Introductions, Forum Rules &amp; Updates</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64693</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64692</link>
                        <pubDate>Sun, 28 Jun 2026 17:24:51 +0000</pubDate>
It really depends on the building and what you want to aircon. Trying to aircon an entire house if you already have an air/water heating system is probably overkill.
One big item wh...]]></description>
<p>@watcher Encouraging except that a bungalow is probably an easier and less disruptive installation than a ground and first floor job. Regards, Toodles.</p>
<p>It really depends on the building and what you want to aircon. Trying to aircon an entire house if you already have an air/water heating system is probably overkill.</p>
<p>One big item when doing a bigger install is the loft. If you've got a loft that's just a loft not rooms then it's hugely easier to do the upper floor as you can do it from the loft space with ceiling units and the like.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/rules-terms-of-use/">Introductions, Forum Rules &amp; Updates</category>                        <dc:creator>EtchedPixels</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64692</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64662</link>
                        <pubDate>Sat, 27 Jun 2026 16:16:54 +0000</pubDate>
                        <description><![CDATA[@watcher Encouraging except that a bungalow is probably an easier and less disruptive installation than a ground and first floor job. Regards, Toodles.]]></description>
                        <content:encoded><![CDATA[@watcher Encouraging except that a bungalow is probably an easier and less disruptive installation than a ground and first floor job. Regards, Toodles.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64662</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64661</link>
                        <pubDate>Sat, 27 Jun 2026 15:56:21 +0000</pubDate>
                        <description><![CDATA[@toodles 
AC was relatively painless, installer drilled a couple of holes in the lounge wall screwed the interior blower inside and hung the HP up high outside to match, gas up, wire up the...]]></description>
                        <content:encoded><![CDATA[<p>@toodles </p>
<p>AC was relatively painless, installer drilled a couple of holes in the lounge wall screwed the interior blower inside and hung the HP up high outside to match, gas up, wire up the wall to loft for leccy and hoover up.</p>
<p>I was really torn between A2W or putting another aircon at the other end of the house and running them as main heat source but decided to take the MCS grant route for winter comfort…..or rather ‘she’ did!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/rules-terms-of-use/">Introductions, Forum Rules &amp; Updates</category>                        <dc:creator>Watcher</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64661</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64660</link>
                        <pubDate>Sat, 27 Jun 2026 15:56:10 +0000</pubDate>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64660</guid>
                        <link>https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64659</link>
                        <pubDate>Sat, 27 Jun 2026 15:31:46 +0000</pubDate>
                        <description><![CDATA[@majordennisbloodnok has welcomed you, may I second that? We went straight from mains gas to heat pump some three years or so back. Had solar panels and battery the year before and it was a ...]]></description>
                        <content:encoded><![CDATA[<p>@majordennisbloodnok has welcomed you, may I second that? We went straight from mains gas to heat pump some three years or so back. Had solar panels and battery the year before and it was a memorable day that we had the gas supply capped and disconnected; an all electric household we have been ever since. No AC here but can’t bear to think about the disruption involved if a pukker system were to be installed! Regards, Toodles. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/rules-terms-of-use/say-hello-and-introduce-yourself/paged/114/#post-64659</guid>
Served from: renewableheatinghub.co.uk @ 2026-07-19 23:32:52 by W3 Total Cache
