									Creative trials on Night-time Setbacks to @ faster recovery, improved comfort and even greater energy reductions. - Air Source Heat Pumps (ASHPs)				            </title>
            <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/</link>
            <lastBuildDate>Fri, 07 Aug 2026 19:25:48 +0000</lastBuildDate>
                        <title>RE: Creative trials on Night-time Setbacks to @ faster recovery, improved comfort and even greater energy reductions.</title>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55313</link>
                        <pubDate>Sun, 04 Jan 2026 11:09:30 +0000</pubDate>
                        <description><![CDATA[Thanks for your comments @old_scientist. It sounds like you’ve managed to get the room temperatures you want albeit by manually adjusting the flow temperatures. 
We have had similar problem...]]></description>
<p>The heat pump is oversized, and even at minimum output will output too much heat overnight unless it's below freezing outside, so a setback or switch off is almost mandatory for overnight comfort.</p>
<p>Thanks for your comments @old_scientist. It sounds like you’ve managed to get the room temperatures you want albeit by manually adjusting the flow temperatures. </p>
<p>We have had similar problems with finding the lowest flow temperatures but perhaps not as extreme as yours. We have found the 36C flow temperature is about as low as our Ecodan 8.5kw model will modulate down to before it starts to cycle. So at warmer nights above 10c we might have to let it run to a higher set temperature and switch off using the thermostat. </p>
<p>The overall effect is the indoor temp is oscillating between 17C and 20C over a 24h period in a fashion that suits our lifestyle and heat requirements. After a cooling period to 17C, we are gently reheating back to 20C throughout the day. Much of this is dictated by the fact we have an oversized heat pump that isn't capable of maintaining a steady state of 19C in anything other than the very coldest of weather. Our SCOP is in the region of 4.0 which I am more than happy with.</p>
<p>It’s good you’re getting a SCOP of 4 and you have a convenient way of adjusting the thermostat.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55313</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55242</link>
                        <pubDate>Sat, 03 Jan 2026 11:05:52 +0000</pubDate>
                        <description><![CDATA[@sunandair we operate a very similar overnight setback with our Samsung ASHP using a 3rd party wireless programmable room thermostat.
The heat pump is oversized, and even at minimum output ...]]></description>
                        <content:encoded><![CDATA[<p>@sunandair we operate a very similar overnight setback with our Samsung ASHP using a 3rd party wireless programmable room thermostat.</p>
<p>We have no way to schedule changes in LWT (other than WC), so that must be done manually. The room thermostat allows us to program start/stop times and set room temperatures so we can achieve similar results to yourself.</p>
<p>During milder weather, we simply turn off overnight and turn back on in the morning when we get up and find the house soon reheats to an acceptable minimum temperature.</p>
<p>During winter (below 5C) we schedule a 4am restart. We are on the Cosy tariff, and although we have a battery it makes sense to try to schedule any reheats from the grid rather than from the battery, so we normally schedule the heating to go off at midnight and to restart at 4am, although we could schedule a later start time based on room temp as you do (e.g, 4am if &lt;17C, 5am if &lt;18C etc) - good idea, thank you! I also manually turn the flow temps down to 30C when we go to bed and then turn them back up to 32-33C (or as required) when we get up. This has the desired effect of maintaining house temp at ~17-18C overnight and allows us to reheat to 19C in the morning. We then target 20C for the evening when we become more sedentary and require a little more heat. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55242</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55232</link>
                        <pubDate>Fri, 02 Jan 2026 18:20:06 +0000</pubDate>
                        <description><![CDATA[Here is an update of the setback we operate on our system.
We have created a simple schedule which copes with different night time outside temperatures. This is worth considering because if...]]></description>
                        <content:encoded><![CDATA[<p>Here is an update of the setback we operate on our system.</p>
<p>We have created a simple schedule which copes with different night time outside temperatures. This is worth considering because if the outside temperature is particularly cold the indoor temperature will also drop lower than you might expect. So this means the morning reheat would need to start earlier in the morning to achieve a comfortable room temperature by a targeted time in the morning. </p>
<p>the attached graph shows the times our schedule changes and the degree of setback. The room temperature line is the black line and in this illustration the room temperature doesn’t drop to 17C. But the temperature is below 18C at 4.30am so the HP will,start to heat at 4.30am.</p>
13250
<p>Conversely,  if the night time temperature was above 18C there needs to be an automated way, built into the schedule, to delay the start of the reheat of the house. This means you are not wasting energy bringing on the heating too early. So in a milder night the heating would be delayed until 6am which is the next scheduled start targeting 19C. </p>
<p>The heating on our system operates in weather compensation mode which would typically overshoot the target temperature by 1C before switching into standby mode. However our weather curve is set to operate at a gentle output and only slowly attains 20C in about 3 hours.</p>
<p>We usually manually adjust the temperature up to 20C or 21C around mid afternoon. </p>
<p>This works for us in our particular house but I think it’s fair to say differences in property characteristics, insulation influences and Heat Pump performance will vary from one property to another.</p>
<p>Perhaps the attached pie chart helps to show how energy can be saved during a setback. The yellow section shows how much time the HP was in freeze stat mode (in this case only activating the circulation pump to prevent the outside piped water dropping below 15C) it did this to protect the system for 4.5 hours. The red portion of the pie chart shows the heating when it was switched on at 4.30 am and  operating for the next 4.5 hours until the graph was created at 8.55am.</p>
<p>I hope some people will find this useful.</p>
13251]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55232</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55231</link>
                        <pubDate>Fri, 02 Jan 2026 18:17:17 +0000</pubDate>
13250
<p>Perhaps the attached pie chart helps to show how energy can be saved during a setback. The yellow section shows how much time the HP was in freeze stat mode (in this case only activating the circulation pump to prevent the outside piped water dropping below 15C) it did this to protect the system for 4.5 hours. The red portion of the pie chart shows the heating when it was switched on at 4.30 am and  operating for the next 5 hours until the graph was created.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-55231</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40663</link>
                        <pubDate>Wed, 22 Jan 2025 12:51:25 +0000</pubDate>
Like you say it varies dependant on OAT, but room temperature over the last week it averages 1 around 1.5 Deg drop.
This is till 4am when we heat the water cylinder that takes ...]]></description>
                        <content:encoded><![CDATA[<p>@sunandair </p>
<p>Like you say it varies dependant on OAT, but room temperature over the last week it averages 1 around 1.5 Deg drop.</p>
<p>This is till 4am when we heat the water cylinder that takes 45 to 60 mins to get to 48 deg and central heating obviously turns off during that period.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/">Air Source Heat Pumps (ASHPs)</category>                        <dc:creator>NJT</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40663</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40654</link>
                        <pubDate>Wed, 22 Jan 2025 10:43:26 +0000</pubDate>
                        <description><![CDATA[That’s great to here….
im curious, If you’re putting a 2c drop on the flow temp what’s your room temperature drop at the end of the setback? (Of course this might vary from day to day)
I’v...]]></description>
                        <content:encoded><![CDATA[<p><em>That’s great to here….</em></p>
<p>im curious, If you’re putting a 2c drop on the flow temp what’s your room temperature drop at the end of the setback? (Of course this might vary from day to day)</p>
<p>I’ve been very impressed with the Daikin MMI controller. I’ve been helping a neighbour set up their WC curve and found it looks good and is easy to navigate.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40654</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40646</link>
                        <pubDate>Wed, 22 Jan 2025 08:21:37 +0000</pubDate>
Yes the -2 takes it off the LWT, and I have the Daikin 8kw
Using offset, obviously keeps the heat pump running as opposed to stop/start thermostat control, saving the 20 ish mi...]]></description>
<p>Yes the -2 takes it off the LWT, and I have the Daikin 8kw</p>
<p>Using offset, obviously keeps the heat pump running as opposed to stop/start thermostat control, saving the 20 ish mins start up  boost that Daikin do every time it restarts before settling back to set LWT.</p>
<p>I initially tried thermostat control overnight but that's not accurate enough with Daikin (0.5 to 1.5 deg variation that can't be adjusted) </p>
<p>So far so good &#x1f44d;</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40646</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40643</link>
                        <pubDate>Tue, 21 Jan 2025 23:06:49 +0000</pubDate>
                        <description><![CDATA[yes I’m already using weather compensation on our Mitsubishi but, as stated above, there isn’t a scheduled LWT setback option available. The trial I have done was by manually adjusting the f...]]></description>
<p>@sunandair </p>
<p>I've just recently started using pure weather compensation which is what you seen to be looking for. </p>
<p>It's building the same weather curve, but removes the thermostat and just works on leaving water temperature that can be offset in the daily/weekly planner or via the app.</p>
<p>I've near enough set up right for us, with a -2 Deg offset at 9pm and reverting back to 0 at 5am</p>
<p>yes I’m already using weather compensation on our Mitsubishi but, as stated above, there isn’t a scheduled LWT setback option available. The trial I have done was by manually adjusting the flow temperature just to see how the system responded. And the graphs shown above were the results.</p>
<p>But I’m using an Ecodan system which doesn’t appear to have a programmable schedule for the flow temperature the schedule only appears to adjust the room set temperature.</p>
<p>Is your system a Daikin model or is it another make? How have you found the setback operates? Have you seen any benefits using the LWT setback? And just to clarify;  when you state -2c setback that means your schedule takes 2c off the LEaving Water temperature during the setback period? Is that right?</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40643</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40640</link>
                        <pubDate>Tue, 21 Jan 2025 22:24:44 +0000</pubDate>
I&#039;ve just recently started using pure weather compensation which is what you seen to be looking for. 
It&#039;s building the same weather curve, but removes the thermostat and just ...]]></description>
<p>I've near enough set up right for us, with a -2 Deg offset at 9pm and reverting back to 0 at 5am</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40640</guid>
                        <link>https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40627</link>
                        <pubDate>Tue, 21 Jan 2025 17:59:44 +0000</pubDate>
                        <description><![CDATA[Update: it looks like Daikin do exactly what I’m looking for in this post.
I’ve just seen this video done by Heat Geek… over 2 years ago. It’s at 8mins 46 seconds.
To recap what I was lo...]]></description>
<p>Picking up this thread from last year </p>
<p>Following discussion on what is missing in the controls of heat pumps I've done a trial on a different kind of setback for overnight operation which might be more efficient than simply dropping the target room temperature. </p>
<p>On the Ecodan controls the only way to operate a scheduled setback is to program a temperature drop on the set temperature control. On the current system there  is no way, in weather compensation of making a setback FLOW TEMPERATURE.</p>
<p>Im suggesting that there is already a theoretical advantage of making a setback using flow temperature drop of say 5c and based on the widely quoted benefit of a 3% energy saving for every 1c reduction in flow temperature. This would mean a potential 15% saving on just a room temperature setback of say 2c.</p>
<p>But there would appear to be a second big saving which only revealed itself during the test responses from the heat pump. </p>
<p>The first thing to notice in the reheat graph is the large ramp up when the room stat setback temperature is reached. This is because the HP is following the NORMAL WEATHER COMPENSATION CURVE. However this is night time. Do we need a heavy duty ramp up?</p>
9895
<p>Another costly activity of the heat pump is the defrost cycle which only takes about 5 minutes to complete but induces another ramp up and the return flow temperature takes around 25 minutes to reach its pre-defrost temperature.</p>
9898
<p>The Ecodan controller has an on screen flow temp adjustment option. This simply adjusts the weather compensation curve  flow temperature up or down. So we have induced a low reaction setback by manually adjusting downwards the flow temperature to -5c.</p>
9899
<p>The resulting lower flow resulted in a gentler start during the overnight setback. It was lowered in 2 stages from 40c down to 38c and then finally to 35c flow temp. The first graph shows the step change at 3.35am.</p>
9903
9901
9902
<p>The last graph shows the flow temperature returned to the normal WC Curve setting. You might notice it goes straight into defrost mode when the flow temp is raised back to normal.</p>
<p>Here is the hidden result... </p>
<p>the outside ambient temperature was 2c so we were operating with hourly defrosts.</p>
<p>However, by reducing the Flow Temperature the system appeared to operate below the rapid output which induces the defrost cycle.</p>
<p>This low flow temp adjustment of 5c off the WC Curve appears to have saved 8 defrosts. In addition to have reduced the consumption by as much as 10 to 15%. </p>
<p><strong>If only this WC Curve setback was available as a scheduled setting as a night time setback.</strong></p>
<p>(resultant temp drop at 6am showed a room temp of 18.5c. This raised to 20c during normal operation by 9am)</p>
<p>Update: it looks like Daikin do exactly what I’m looking for in this post.</p>
<p>I’ve just seen this video done by Heat Geek… over 2 years ago. It’s at 8mins 46 seconds.</p>
9951
<p>To recap what I was looking for was : *While operating our Ecodan in Weather Compensation, a scheduled setback which sets the flow temperature lower rather than the room temperature lower. Reason being a room temperature setback will result in the temperature dropping then reheating at ‘full’ weather curve output until the lower room temperature is passed again. </p>
<p>The Daikin system has the option of setting up a schedule for night time (or any time) where a cooler more comfortable night time is preferred. And by lowering the flow temperature say 5c this would also produce an improved energy saving over just lowering the room temperature. Even better- the room target could stay the same but by lowering the flow temperature the target room temperature will simply never be reached.</p>
<p>I guess you would need to play around with the flow temp drop so that the room temp only drops by 2c but it seems it can be done.</p>
<p>I wonder if there are any Daikin owners reading this post who use this setback feature who might shed some light on its effectiveness?</p>
<p>So now wondering if Mitsubishi have any plans on introducing such a control?</p>
<p>I’ll try and post the video.</p>
<p>the topic comes up at 8mins46.</p>
<p>https://youtu.be/-EUeqDSv5ag?si=DCbcdSATFxKd4gUh</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/renewable-heating-air-source-heap-pumps-ashps/creative-trials-on-night-time-setbacks-to-faster-recovery-improved-comfort-and-even-greater-energy-reductions/paged/4/#post-40627</guid>
Served from: renewableheatinghub.co.uk @ 2026-08-07 20:25:48 by W3 Total Cache
