									What’s the modern take on advised types of insulation? - Well &amp; Truly Off The Grid				            </title>
            <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/</link>
            <lastBuildDate>Thu, 12 Nov 2026 20:04:15 +0000</lastBuildDate>
                        <title>RE: What’s the modern take on advised types of insulation?</title>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/4/#post-50358</link>
                        <pubDate>Mon, 13 Oct 2025 12:12:42 +0000</pubDate>
                        <description><![CDATA[I suppose Green indeed... &#x1f601;
And everybody has their soft spots, some enjoy their fossil fuel cars, others fly.  
<p>He was one of the more green MPs, with an electric vehicle and I remember he had his house assessed for a heat pump when he was a government minister in 2023.</p>
<p>I suppose Green indeed... &#x1f601;</p>
<p>And everybody has their soft spots, some enjoy their fossil fuel cars, others fly.  </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/other-renewables/">Well &amp; Truly Off The Grid</category>                        <dc:creator>Batpred</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/4/#post-50358</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/4/#post-46609</link>
                        <pubDate>Thu, 29 May 2025 14:57:51 +0000</pubDate>
                        <description><![CDATA[@jeff I am sorry @jeff if I have misunderstood what you wrote; I certainly did not mean to infer anything, in fact, I am agreeing with your thoughts. I was following up on your writing:
”Al...]]></description>
                        <content:encoded><![CDATA[<p>@jeff I am sorry @jeff if I have misunderstood what you wrote; I certainly did not mean to infer anything, in fact, I am agreeing with your thoughts. I was following up on your writing:</p>
<p>”<span>Also things have moved on over the last few years I feel with perhaps more pragmatism around the fabric first approach which I remember well this forum championing strongly.”</span></p>
<p>Insulation being added to the fabric of the building is, in my opinion a good idea, whether before, during or after installing a heat pump.</p>
<p>If my writing has offended you in some way, I apologise; no offence was intended and I hope I have not put words in your mouth. Regards, Toodles.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/other-renewables/">Well &amp; Truly Off The Grid</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/4/#post-46609</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46608</link>
                        <pubDate>Thu, 29 May 2025 14:45:28 +0000</pubDate>
                        <description><![CDATA[I did say anything to infer this.
I am offended and would like a apology]]></description>
<p>@jeff <strong>Insulation (or lack of same) will not mean that a heat pump will lose any more or less of the precious heat we would pump into a property than that with an oil burner, gas boiler or even night store electric heating. A therm is a therm, however created and the better the insulation, the less thermal loss will take place (all else being equal).</strong></p>
<p>Insulation is, as they say, a ‘no brainer’ and ought to be accomplished when affordable. Meanwhile, is it not better to produce the heat required within the property by the cleanest and most efficient method available? A heat pump is likely to be the preferred method in many if not most cases. If energy is going to be wasted due to heat loss, it is probably preferable that that heat be supplied by the most efficient means and thus leave the fossils in the ground - and also insulate as soon as possible commensurate with available funds and practicality. (Tucks soap box away again) Toodles.</p>
<p>I did say anything to infer this.</p>
<p>I am offended and would like a apology </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/other-renewables/">Well &amp; Truly Off The Grid</category>                        <dc:creator>Jeff</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46608</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46607</link>
                        <pubDate>Thu, 29 May 2025 14:35:24 +0000</pubDate>
                        <description><![CDATA[@jeff Insulation (or lack of same) will not mean that a heat pump will lose any more or less of the precious heat we would pump into a property than that with an oil burner, gas boiler or ev...]]></description>
                        <content:encoded><![CDATA[<p>@jeff Insulation (or lack of same) will not mean that a heat pump will lose any more or less of the precious heat we would pump into a property than that with an oil burner, gas boiler or even night store electric heating. A therm is a therm, however created and the better the insulation, the less thermal loss will take place (all else being equal).</p>
<p>Insulation is, as they say, a ‘no brainer’ and ought to be accomplished when affordable. Meanwhile, is it not better to produce the heat required within the property by the cleanest and most efficient method available? A heat pump is likely to be the preferred method in many if not most cases. If energy is going to be wasted due to heat loss, it is probably preferable that that heat be supplied by the most efficient means and thus leave the fossils in the ground - and also insulate as soon as possible commensurate with available funds and practicality. (Tucks soap box away again) Toodles.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46607</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46584</link>
                        <pubDate>Wed, 28 May 2025 18:44:02 +0000</pubDate>
                        <description><![CDATA[Grant was my local MP before he lost his seat.
He was one of the more green MPs, with an electric vehicle and I remember he had his house assessed for a heat pump when he was a government m...]]></description>
                        <content:encoded><![CDATA[Grant was my local MP before he lost his seat.<br />
<p>I suspect his comments are primarily based on the feedback he received in 2023 which would have been interesting to say the least with the conservatory etc as we know from other posters recently. So without further info I am not sure if the blame sits primarily with Grant or the one or more installers who visited him.</p>
<p>Also things have moved on over the last few years I feel with perhaps more pragmatism around the fabric first approach which I remember well this forum championing strongly.</p>
<p>I do wonder if Grant had a couple of assessments now from installers, what feedback they would give him. It would clearly depend which installers from what we have seen.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46584</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46518</link>
                        <pubDate>Tue, 27 May 2025 09:08:31 +0000</pubDate>
                        <description><![CDATA[The former Energy Secretary claims his 1930s house is “too awkward” for a heat pump and compares installing one to “fitting a Rolls-Royce engine to a shopping trolley.” &#x1f926;&#x200d;&amp;#x2...]]></description>
                        <content:encoded><![CDATA[<p class="p1">The former Energy Secretary claims his 1930s house is “too awkward” for a heat pump and compares installing one to “fitting a Rolls-Royce engine to a shopping trolley.” &#x1f926;&#x200d;&#x2642;&#xfe0f;</p>
<p>So I thought we should write a rebuttal (link below), and also resurrect old threads on insulation to see how well or poorly your home is insulted and what you're doing about it and debunk some of those old (and unhelpful) narratives.</p>
<p><a href="https://renewableheatinghub.co.uk/grant-shapps-and-the-heat-pump-myth-that-wont-die/">https://renewableheatinghub.co.uk/grant-shapps-and-the-heat-pump-myth-that-wont-die/</a></p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/other-renewables/">Well &amp; Truly Off The Grid</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-46518</guid>
                        <title>RE: Insulation</title>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-8605</link>
                        <pubDate>Mon, 09 May 2022 20:50:45 +0000</pubDate>
                        <description><![CDATA[Draught proofing of windows done this weekend. Check.
We&#039;ve tried using an endless amount of products (caulks, silicone, fillers, etc.) to draught proof our windows, and they never seem to ...]]></description>
                        <content:encoded><![CDATA[<p>Draught proofing of windows done this weekend. Check.</p>
<p>We've tried using an endless amount of products (caulks, silicone, fillers, etc.) to draught proof our windows, and they never seem to last more than a few months before they start to crack. So we've turned to our go to all-in-one product, Maxam's DURA+, to draught proof 29 windows across the property. It's been a winner of a product so far, from sealing our shower to sticking a broken slate step together, so we're optimist it's going to work sealing our windows, keeping draughts out this winter (and the heat in): https://myhomefarm.co.uk/draught-proofing-windows</p>
<p>DURA+ on Amazon: https://amzn.to/3FsDYiQ</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-8605</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-483</link>
                        <pubDate>Fri, 26 Mar 2021 11:49:51 +0000</pubDate>
                        <description><![CDATA[@editor We have insulated with hempcrete and iso-hemp blocks.  More expensive than foil backed foam but as a breatheable/moisture permeable material does not need all the membranes and is be...]]></description>
                        <content:encoded><![CDATA[<p>@editor We have insulated with hempcrete and iso-hemp blocks.  More expensive than foil backed foam but as a breatheable/moisture permeable material does not need all the membranes and is better suited to our (no damp proof course 1880s) cottage.  </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/other-renewables/">Well &amp; Truly Off The Grid</category>                        <dc:creator>Merrion</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-483</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-481</link>
                        <pubDate>Fri, 26 Mar 2021 10:20:12 +0000</pubDate>
                        <description><![CDATA[@merrion, that&#039;s on my hit list of things to get this summer so that we can embark on the next part of our heating efficiency journey.]]></description>
                        <content:encoded><![CDATA[<p>@merrion, that's on my hit list of things to get this summer so that we can embark on the next part of our heating efficiency journey.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-481</guid>
                        <link>https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-479</link>
                        <pubDate>Fri, 26 Mar 2021 10:07:43 +0000</pubDate>
                        <description><![CDATA[@editor See if you can hire an IR camera (or buy one) and take a set of photos to see where the heat loss is occuring - it may be that some draft and cold bridge patching can suffice?]]></description>
                        <content:encoded><![CDATA[<p>@editor See if you can hire an IR camera (or buy one) and take a set of photos to see where the heat loss is occuring - it may be that some draft and cold bridge patching can suffice?</p>
23
22]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/other-renewables/insulations/paged/3/#post-479</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-12 20:04:15 by W3 Total Cache
