									How do I choose a single room MVHR to prevent losing heat in my bathroom ? - Insulation				            </title>
            <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/</link>
            <lastBuildDate>Fri, 13 Nov 2026 17:53:54 +0000</lastBuildDate>
                        <title>RE: How do I choose a single room MVHR to prevent losing heat in my bathroom ?</title>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-47907</link>
                        <pubDate>Thu, 07 Aug 2025 12:08:03 +0000</pubDate>
                        <description><![CDATA[An update on the Heatsava. It is the most difficult thing to clean. I had to get a strong bloke to remove the heat cell, couldn’t get all the crud out of it anyway, and trying to get it back...]]></description>
                        <content:encoded><![CDATA[<p>An update on the Heatsava. It is the most difficult thing to clean. I had to get a strong bloke to remove the heat cell, couldn’t get all the crud out of it anyway, and trying to get it back into the unit is so far impossible. Should have got your one @heacol &#x1f926;&#x1f3fc;&#x200d;&#x2640;&#xfe0f;</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/insulation/">Insulation</category>                        <dc:creator>heat-pump-newbie</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-47907</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-29623</link>
                        <pubDate>Sat, 06 Apr 2024 15:33:20 +0000</pubDate>
                        <description><![CDATA[As others might come across this topic in future, may I chip in and mention a two-room solution?
I was once faced with the need to draw in fresh air into the living area in a small flat, wh...]]></description>
                        <content:encoded><![CDATA[<p>As others might come across this topic in future, may I chip in and mention a two-room solution?</p>
<p>I was once faced with the need to draw in fresh air into the living area in a small flat, whilst also removing stale/humid air from the adjacent room with a shower and toilet.</p>
<p>The solution I hit upon was a tiny version of a 4-port MVHR unit, made by Vent Axia, and costing about £300. The <strong>HR100</strong> has two varients; one allows access to the heat-exchange plates from the top, and the other from below. I chose the latter, and placed it directly above the doorway between the two rooms.</p>
7032
<p>The HR100 has standard 110mm diameter ports which could be connected to solid-PVC tubing or flexible pipe with a reinforcement spiral wire to maintain the shape.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/insulation/">Insulation</category>                        <dc:creator>Transparent</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-29623</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-29600</link>
                        <pubDate>Fri, 05 Apr 2024 21:46:52 +0000</pubDate>
                        <description><![CDATA[Update ! I have had an Envirovent Heatsava installed. It seemed noisy at first but now we’re used to it. It’s on all the time, uses only 20 W, it ramps up automatically when the shower is on...]]></description>
                        <content:encoded><![CDATA[<p>Update ! <br />I have had an Envirovent Heatsava installed. It seemed noisy at first but now we’re used to it. It’s on all the time, uses only 20 W, it ramps up automatically when the shower is on and is quite obvious then, but clears the mist from the window and mirror very quickly. I like the constant fresh air flow and can’t smell the neighbour’s smoky log burner or bonfires as the filter works very well. Nearly all our trickle vents can be closed now as we have real fresh air coming in at last.<br />The only downside is that it’s quite big.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-29600</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-28108</link>
                        <pubDate>Sat, 24 Feb 2024 17:08:51 +0000</pubDate>
                        <description><![CDATA[Yes it does, a direct swap, same 4&quot; hole. 
The mini is fine.]]></description>
<p>@heacol this looks pretty awesome. Does/can it replace an existing extractor fan in a bathroom.</p>
<p> Yes it does, a direct swap, same 4" hole. </p>
<p>The mini is fine.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/insulation/">Insulation</category>                        <dc:creator>BU</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-28108</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-28055</link>
                        <pubDate>Fri, 23 Feb 2024 18:00:53 +0000</pubDate>
                        <description><![CDATA[@west  this sounds like you&#039;re referring to something much bigger than a single room unit .]]></description>
                        <content:encoded><![CDATA[<p>@west  this sounds like you're referring to something much bigger than a single room unit . </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-28055</guid>
                        <title>I have a MVHR Vent Axia</title>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-28047</link>
                        <pubDate>Fri, 23 Feb 2024 16:57:53 +0000</pubDate>
                        <description><![CDATA[Mine was a waste of time and money, first installer did it wrong so all had to be ripped out by installer number 2, trading standards would not accept installer number 2 report as they were ...]]></description>
                        <content:encoded><![CDATA[<p>Mine was a waste of time and money, first installer did it wrong so all had to be ripped out by installer number 2, trading standards would not accept installer number 2 report as they were not independent!! second install, takes heat from shower rooms, but shower rooms never hot, as GSHP not right, so waste of time puts cold air in heated rooms, I have mine disconnected, put it on in the summer for cool air.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/insulation/">Insulation</category>                        <dc:creator>west</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/paged/2/#post-28047</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28020</link>
                        <pubDate>Fri, 23 Feb 2024 08:36:22 +0000</pubDate>
                        <description><![CDATA[I&#039;ve also found the Envirovent heatSava which I like. Does anyone have experience of this ?]]></description>
                        <content:encoded><![CDATA[<p>I've also found the Envirovent heatSava which I like. Does anyone have experience of this ?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28020</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28015</link>
                        <pubDate>Thu, 22 Feb 2024 21:00:58 +0000</pubDate>
                        <description><![CDATA[@heacol this looks pretty awesome. Does/can it replace an existing extractor fan in a bathroom.]]></description>
                        <content:encoded><![CDATA[@heacol this looks pretty awesome. Does/can it replace an existing extractor fan in a bathroom.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/insulation/">Insulation</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28015</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28014</link>
                        <pubDate>Thu, 22 Feb 2024 20:51:04 +0000</pubDate>
                        <description><![CDATA[Thanks Brendon, that&#039;s exactly the kind of thing I was looking at. Would you recommend the Vento Duo for a bathroom as their brochure suggests or would the Vento Mini be sufficient ?]]></description>
                        <content:encoded><![CDATA[<p>Thanks Brendon, that's exactly the kind of thing I was looking at. Would you recommend the Vento Duo for a bathroom as their brochure suggests or would the Vento Mini be sufficient ?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28014</guid>
                        <link>https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28010</link>
                        <pubDate>Thu, 22 Feb 2024 18:10:16 +0000</pubDate>
                        <description><![CDATA[I helped develop these, they are brilliant, I have 1 in my house and no damp or condensation.]]></description>
<p>Now that I've got a warm bathroom heated by my ASHP I want to prevent losing all that lovely heat from being extracted with the steam from the shower ?</p>
<p>How do I choose what single room MVHR would be appropriate ? Everything I see online directs my to whole house systems or just technical stuff I don't understand. Help !</p>
<p>  I helped develop these, they are brilliant, I have 1 in my house and no damp or condensation.</p>
<p>https://www.blauberg.co.uk/blauberg-mini-air-decentralised-heat-recovery-unit-single-wall-mounted-d-mvhr-ventilator-smart-wifi-control</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/insulation/how-do-i-choose-a-single-room-mvhr-to-prevent-losing-heat-in-my-bathroom/#post-28010</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 17:53:54 by W3 Total Cache
