									What do we need to know before installing a heat pump? - Government Schemes, Regulations, Training, Planning &amp; Organisations				            </title>
            <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/</link>
            <lastBuildDate>Fri, 13 Nov 2026 17:41:17 +0000</lastBuildDate>
                        <title>RE: What do we need to know before installing a heat pump?</title>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20097</link>
                        <pubDate>Wed, 28 Jun 2023 16:53:18 +0000</pubDate>
                        <description><![CDATA[@toodles We have (now) a World Heat air source compatible unvented hot water cylinder with all the necessary changes to pipe work that a HP installation would require. If it remains an absol...]]></description>
                        <content:encoded><![CDATA[@toodles We have (now) a World Heat air source compatible unvented hot water cylinder with all the necessary changes to pipe work that a HP installation would require. If it remains an absolute MCS requirement to have it replaced, and it’s not just BG being awkward, then I’ll just forget about a heat pump.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/government-schemes/">Government Schemes, Regulations, Training, Planning &amp; Organisations</category>                        <dc:creator>Davesoa</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20097</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20096</link>
                        <pubDate>Wed, 28 Jun 2023 16:51:53 +0000</pubDate>
                        <description><![CDATA[I am guessing that they use the hp manufacturers pre plumbed cylinder to ensure that their rookie plumbers can&#039;t completely screw up.]]></description>
<p>Following my failed attempt to get a HP installed earlier this year I decided to have a heat pump ready unvented hot water tank installed. My showers work wonderfully now and water is being heated via an iBoost every day from the PVs. My plumber took great care to select the right tank. I thought I’d try British Gas and see if they would quote for a heat pump as they offer a guarantee of performance. They will, but only on the understanding that they would want to rip out the newly installed tank and put theirs in instead. They weren’t interested in discussing why they take this approach or what might be wrong with the tank. </p>
<p>I am guessing that they use the hp manufacturers pre plumbed cylinder to ensure that their rookie plumbers can't completely screw up.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/government-schemes/">Government Schemes, Regulations, Training, Planning &amp; Organisations</category>                        <dc:creator>JamesPa</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20096</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20095</link>
                        <pubDate>Wed, 28 Jun 2023 16:16:21 +0000</pubDate>
                        <description><![CDATA[@davesoa Though our 99 litre tank was in good order and only 3-4 years old (replaced by BG when they couldn’t locate the reason for a fault in the boiler whilst under service contact - you k...]]></description>
                        <content:encoded><![CDATA[@davesoa <span style="font-size: 14pt">Though our 99 litre tank was in good order and only 3-4 years old (replaced by BG when they couldn’t locate the reason for a fault in the boiler whilst under service contact - you know the one, it is called an annual service and is carried out every 18 - 20 months!), it was large enough for our washing needs. Of course MCS wouldn’t accept this and in any case, the standard or slimline heat pump HWT would not fit in our space when they hold 210 litres! Fitting the Sunamp Thermino ePV 210 was a very neat solution for us. Summer consumption averages 2.5 kW/h per day and in colder weather, this figure was 3 - 3.5 kW/h per day powered via our Eddi rom the PV. I’m very pleased with the unit and it fits in the airing cupboard! ‘Smart tanks’ look to me like a sledge hammer to crack a nut with all that plumbing, pumping system, sensors and controls! (No space except possibly in the loft if the trap were enlarged first…) Regards, Toodles.</span>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/government-schemes/">Government Schemes, Regulations, Training, Planning &amp; Organisations</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20095</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20094</link>
                        <pubDate>Wed, 28 Jun 2023 15:59:36 +0000</pubDate>
                        <description><![CDATA[Very good. And yes it was a quick goodbye to BG.]]></description>
                        <content:encoded><![CDATA[<p>Very good. And yes it was a quick goodbye to BG. <br /><br /></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20094</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20093</link>
                        <pubDate>Wed, 28 Jun 2023 15:57:28 +0000</pubDate>
                        <description><![CDATA[S I take it that you said: ‘Tanks, but no Tanks.?  This sort of inflexibility is going to give MCS a bad reputation — err…. Oh Yes, they have already!]]></description>
                        <content:encoded><![CDATA[<p><span style="font-size: 14pt">S I take it that you said: ‘Tanks, but no Tanks.?  This sort of inflexibility is going to give MCS a bad reputation — err…. Oh Yes, they have already!</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/26/#post-20093</guid>
                        <title>We want to do it our way…or no way</title>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-20092</link>
                        <pubDate>Wed, 28 Jun 2023 15:31:31 +0000</pubDate>
                        <description><![CDATA[Following my failed attempt to get a HP installed earlier this year I decided to have a heat pump ready unvented hot water tank installed. My showers work wonderfully now and water is being ...]]></description>
                        <content:encoded><![CDATA[<p>Following my failed attempt to get a HP installed earlier this year I decided to have a heat pump ready unvented hot water tank installed. My showers work wonderfully now and water is being heated via an iBoost every day from the PVs. My plumber took great care to select the right tank. I thought I’d try British Gas and see if they would quote for a heat pump as they offer a guarantee of performance. They will, but only on the understanding that they would want to rip out the newly installed tank and put theirs in instead. They weren’t interested in discussing why they take this approach or what might be wrong with the tank. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-20092</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-20075</link>
                        <pubDate>Fri, 23 Jun 2023 11:38:08 +0000</pubDate>
                        <description><![CDATA[Graham, you have a respectable expertise/experience in this industry, yet somehow you are happy to promote the idea that a high temp heat pump(rads at 50C, dhw way over 50C) and that weather...]]></description>
<p>@ginny i was the founder of freedom. But i dont work there any more, i haven't for 2 1/2 years, i sold it. I got fed up of people constantly asking for free advice. </p>
<p>im done with the whole heat pump industry, its plagued by people who want free advice who wont stop pressing buttons, why not go back to the installer you paid to fit the unit and ask them to help, after all they have your cash. </p>
<p>asking a bunch of people who have absolutely no idea what they are on about in a forum is not the best idea. Free advice is just that free and usually crap. </p>
<p>Graham, you have a respectable expertise/experience in this industry, yet somehow you are happy to promote the idea that a high temp heat pump(rads at 50C, dhw way over 50C) and that weather compensation is worthless.</p>
<p>No wonder the results are bad if the specialist industry men are happy with a hot radiator at the expense of the customer.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/government-schemes/">Government Schemes, Regulations, Training, Planning &amp; Organisations</category>                        <dc:creator>Ginny</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-20075</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-19746</link>
                        <pubDate>Thu, 25 May 2023 11:34:23 +0000</pubDate>
                        <description><![CDATA[@jamespa PM me if you want to discuss offline.  have you considered the possibility of doing the same as Peter yourself? its something I&#039;m pondering. For someone like Peter I suspect the &quot;lo...]]></description>
                        <content:encoded><![CDATA[@jamespa PM me if you want to discuss offline.  have you considered the possibility of doing the same as Peter yourself? its something I'm pondering. For someone like Peter I suspect the "local" thing will always be important. as it would be for me if I was to do similar for local people around where I live.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/government-schemes/">Government Schemes, Regulations, Training, Planning &amp; Organisations</category>                        <dc:creator>iancalderbank</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-19746</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-19744</link>
                        <pubDate>Thu, 25 May 2023 11:21:10 +0000</pubDate>
                        <description><![CDATA[@fazel I have made contact and exchanged emails.  His coworker is supposed to call me.  However it&#039;s clear that I&#039;m &#039;out of area&#039; so I&#039;m not sure he will take it on, but I&#039;m still hopeful.]]></description>
                        <content:encoded><![CDATA[@fazel I have made contact and exchanged emails.  His coworker is supposed to call me.  However it's clear that I'm 'out of area' so I'm not sure he will take it on, but I'm still hopeful.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-19744</guid>
                        <link>https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-19743</link>
                        <pubDate>Thu, 25 May 2023 10:43:05 +0000</pubDate>
                        <description><![CDATA[@jamespa any reply from Peter?]]></description>
                        <content:encoded><![CDATA[<p>@jamespa any reply from Peter?</p>
3975]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/government-schemes/">Government Schemes, Regulations, Training, Planning &amp; Organisations</category>                        <dc:creator>Fazel</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/government-schemes/what-we-need-to-know-before-installing-a-heat-pump/paged/25/#post-19743</guid>
Object Caching 60/68 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-11-13 17:41:17 by W3 Total Cache
