									Sofar 6kw Hyd 6000 ES inverter - Energy Storage				            </title>
            <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/</link>
            <lastBuildDate>Tue, 08 Sep 2026 18:29:15 +0000</lastBuildDate>
                        <title>RE: Sofar 6kw Hyd 6000 ES inverter</title>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20254</link>
                        <pubDate>Sat, 08 Jul 2023 18:49:51 +0000</pubDate>
                        <description><![CDATA[Apart from Transparent, probably most of us only have experience of one inverter so can&#039;t compare easily I guess.
As mentioned before, the Sunsynk brand seems pretty good for the Hybrid ...]]></description>
                        <content:encoded><![CDATA[<p>Apart from Transparent, probably most of us only have experience of one inverter so can't compare easily I guess.</p>
<p>As mentioned before, the Sunsynk brand seems pretty good for the Hybrid inverters, they can be used happily as an AC-coupled or Hybrid inverter.  You have a choice of 5kW or 8.8kW, the latter being a bigger jump up - personally think 5kW is fine.</p>
<p>https://www.itstechnologies.shop/products/sunsynk-ecco-5k-on-off-grid-hybrid-solar-wind-inverter?_pos=2&amp;_psq=sunsynk&amp;_ss=e&amp;_v=1.0</p>
<p>The 5kW will charge and discharge at 5kW.  Take a look at their Youtube channel, there are loads of vidoes which help with how it functions.  Here is my set up below (pictures when it was mostly installed, had a few extra bits and bobs to finish up.</p>
4149
4151
4153
<p>I'm just installing a 12kW 3 phase version which will be used only for battery storage, with no direct solar (a previous FIT based 30kW solar install with Solis inverter). </p>
<p>One thing I don't know is how a Sunsynk works when there is an existing FIT solar install, and then also solar attached to the Sunsynk Hybrid, I think it still only needs one CT clamp as if it detects export on going to the grid it'll charge the battery.</p>
<p>You can set up different timeslots, to charge or discharge only between certain times.  My intention at the moment is to charge the battery off-peak to 50% in summer (leaving space for Solar), 75% Autumn and 100% winter.  I tried a lower than 50% off peak charge for summer but I see it as better to pay 7.5p/kWh than run out of juice and pay 30p peak.  This will vary on your PV size, but we've only got half of ours installed at the moment (2.6kW out of 5.2kW).  When days are really good then it doesn't actually need to top up to 50% as we've ended the day with a higher charge.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>vaugi</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20254</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20248</link>
                        <pubDate>Sat, 08 Jul 2023 11:11:24 +0000</pubDate>
                        <description><![CDATA[another reason NOT to even hunt down a Sofar HYD 6000 EP is that ir is NOT on the approved list, which i should have checked !!!]]></description>
                        <content:encoded><![CDATA[<p>another reason NOT to even hunt down a <span>Sofar HYD 6000 EP is that ir is <strong>NOT</strong> on the approved list, which i should have checked !!!</span></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>MisterB</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20248</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20242</link>
                        <pubDate>Sat, 08 Jul 2023 04:31:25 +0000</pubDate>
                        <description><![CDATA[Thanks for that, obv I need to go to spec savers lol! 
I&#039;m still looking for an inverter that can deliver more than 3kw FROM the grid during off peak times then ...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for that, obv I need to go to spec savers lol! </p>
<p>I'm still looking for an inverter that can deliver more than 3kw FROM the grid during off peak times then ...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20242</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20241</link>
                        <pubDate>Fri, 07 Jul 2023 19:21:57 +0000</pubDate>
                        <description><![CDATA[@misterb Sofar HYD 6000 EP
Different model than the title, and that seems to matter as the specs are different.  Can you see it for sale in UK?]]></description>
                        <content:encoded><![CDATA[<p>@misterb Sofar HYD 6000 <strong>EP</strong></p>
<p>Different model than the title, and that seems to matter as the specs are different.  Can you see it for sale in UK?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20241</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20240</link>
                        <pubDate>Fri, 07 Jul 2023 19:16:04 +0000</pubDate>
                        <description><![CDATA[Sorry it&#039;s a bit blurred, I will try to add the link
Hopefully someone will confirm so I can go ahead and purchase one! It&#039;s in the section &#039;technical details&#039;]]></description>
                        <content:encoded><![CDATA[4142
<p>Sorry it's a bit blurred, I will try to add the link</p>
<p>https://sofarsolar.eu/products/hyd-3k6k-ep/</p>
<p>Hopefully someone will confirm so I can go ahead and purchase one! It's in the section 'technical details'</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20240</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20239</link>
                        <pubDate>Fri, 07 Jul 2023 19:12:10 +0000</pubDate>
                        <description><![CDATA[@misterb Do you have a different spec sheet from the one above, as that shows charge and discharge at 3kW?]]></description>
                        <content:encoded><![CDATA[@misterb Do you have a different spec sheet from the one above, as that shows charge and discharge at 3kW?]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20239</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20238</link>
                        <pubDate>Fri, 07 Jul 2023 19:08:20 +0000</pubDate>
                        <description><![CDATA[It wasn&#039;t the discharge rate that got me looking at it, I understand it has a charge rate of 5kw but of course I need to check that to make sure]]></description>
                        <content:encoded><![CDATA[<p>It wasn't the discharge rate that got me looking at it, I understand it has a charge rate of 5kw but of course I need to check that to make sure</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20238</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20237</link>
                        <pubDate>Fri, 07 Jul 2023 18:40:53 +0000</pubDate>
                        <description><![CDATA[Sorry, no experience here.   But doesn&#039;t it have a 3kW maximum charge/discharge limit so not a massive upgrade to your current 3kW version? You&#039;ll only get output of 6kW if both battery and ...]]></description>
                        <content:encoded><![CDATA[<p>Sorry, no experience here.   But doesn't it have a 3kW maximum charge/discharge limit so not a massive upgrade to your current 3kW version? You'll only get output of 6kW if both battery and solar involved (or Solar only)?</p>
4141]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20237</guid>
                        <title>Sofar 6kw Hyd 6000 ES inverter</title>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20236</link>
                        <pubDate>Fri, 07 Jul 2023 17:51:20 +0000</pubDate>
                        <description><![CDATA[Has anyone any experience of the Sofar 6kw HYD 6000ES inverter.
After considering lots of well made points in another discussion re linking two inverters, I am slowly coming round the the c...]]></description>
                        <content:encoded><![CDATA[<p>Has anyone any experience of the Sofar 6kw HYD 6000ES inverter.</p>
<p>After considering lots of well made points in another discussion re linking two inverters, I am slowly coming round the the conclusion that I might aswell just go for one 'more capable' inverter, which offers potential expansion of adding a further solar array.  Which was the option of a couple of contributors and it makes sense. </p>
<p>The Sofar 6k offers a charging capacity of 5kw per hour at 100A, so is very close to being able to fill my batteries during off peak periods ( I'm looking at installing 2x 14.3 Seplos Mason) in the winter and in the summer will utilise the 4kw PV system that was installed about 7 years ago on FiT scheme, second phase. </p>
<p>Has anyone any experience of these inverters. I have a Sofar ME3000ES which I am happy with, hence the preferred option of sticking with the same manufacturer. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/sofar-6kw-hyd-6000-es-inverter/#post-20236</guid>
Served from: renewableheatinghub.co.uk @ 2026-09-08 19:29:15 by W3 Total Cache
