									Making best use of Agile with a battery and ASHP - Energy Storage				            </title>
            <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/</link>
            <lastBuildDate>Fri, 13 Nov 2026 16:52:32 +0000</lastBuildDate>
                        <title>RE: Making best use of Agile with a battery and ASHP</title>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32949</link>
                        <pubDate>Sun, 11 Aug 2024 20:01:05 +0000</pubDate>
                        <description><![CDATA[Or you could possibly have 3 single phase inverters, connected from each phase of the grid supply to a common storage battery. The inverters may be able to reduce phase imbalance, by drawing...]]></description>
<p>even if I cannot contribute anything useful myself, I would like to read what others think!</p>
<p>You <span style="text-decoration: underline">can</span> contribute @toodles</p>
<p>There's some background research required before the proposal can be made appealing to Social Housing providers.</p>
<p>For a start, have a think about the need to have 3-phase input to charge batteries from the grid, but still have single-phase supplies to each house.</p>
<p><strong>A.</strong> Is there an inverter which could operate like that?</p>
<p><strong>B.</strong> Or would it need to be one type of 3ph inverter for charging, and another single-phase type to take the battery voltage and supply it to houses at 240v AC?</p>
7772
<p>Or you could possibly have 3 single phase inverters, connected from each phase of the grid supply to a common storage battery. The inverters may be able to reduce phase imbalance, by drawing power from a lightly loaded phase and feeding it to a more heavily loaded phase via the battery, with the DNO supply seeing approximately equal loading on each phase.</p>
<p>This arrangement could also help smooth out the peaks and troughs of demand, by charging the batteries during periods of low demand and then using the stored energy to help supply periods of peak demand, while also helping to reduce phase imbalance.</p>
<p>One possible benefit of this arrangement would be that not all the demand is going through the inverters, since power would still be coming from the distribution network. A further benefit is that one or more inverters failing should not cut off supply to the consumers.</p>
<p>@transparent I will leave you to do the graphic at which you are much more accomplished.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>Derek M</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32949</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32948</link>
                        <pubDate>Sun, 11 Aug 2024 18:34:22 +0000</pubDate>
                        <description><![CDATA[You can contribute @toodles
There&#039;s some background research required before the proposal can be made appealing to Social Housing providers.
For a start, have a think about the need to hav...]]></description>
7772
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32948</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32943</link>
                        <pubDate>Sun, 11 Aug 2024 15:39:57 +0000</pubDate>
                        <description><![CDATA[@majordennisbloodnok 
That&#039;s very kind. You are a gent.
I&#039;ve got a few things integrated such as my TV, Melcloud, Solar Forecast and others.  But they were easy as pressing a few buttons. ...]]></description>
                        <content:encoded><![CDATA[<p>@majordennisbloodnok </p>
<p>That's very kind. You are a gent.</p>
<p>I've got a few things integrated such as my TV, Melcloud, Solar Forecast and others.  But they were easy as pressing a few buttons.  I will eventually wish to understand how to instal the HACS so that I can have a go at getting more control of my battery storage etc.  But I can wait and as you say, play until I gain more understanding.  Never know the penny might just drop in one day re the HACS.</p>
<p>Thanks for your time and patience.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>Morgan</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32943</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32941</link>
                        <pubDate>Sun, 11 Aug 2024 15:22:13 +0000</pubDate>
                        <description><![CDATA[@transparent I hope that Mars thinks such a topic would have legs, for even if I cannot contribute anything useful myself, I would like to read what others think! Regards, Toodles.]]></description>
                        <content:encoded><![CDATA[@transparent I hope that Mars thinks such a topic would have legs, for even if I cannot contribute anything useful myself, I would like to read what others think! Regards, Toodles.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32941</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32940</link>
                        <pubDate>Sun, 11 Aug 2024 15:21:24 +0000</pubDate>
                        <description><![CDATA[In that case, sit on it for a bit. Have a gentle play as and when the mood takes you and simply get a bit more familiar with it when you feel up to it. If at any stage you want to get a bit ...]]></description>
<p>I have purchased the HA Green already LOL.  I was determined.  Now less so.</p>
<p>In that case, sit on it for a bit. Have a gentle play as and when the mood takes you and simply get a bit more familiar with it when you feel up to it. If at any stage you want to get a bit more adventurous and need a spot of help you can always drop me a line.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>Majordennisbloodnok</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/4/#post-32940</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32939</link>
                        <pubDate>Sun, 11 Aug 2024 13:56:38 +0000</pubDate>
I have purchased the HA Green already LOL.  I was determined.  Now less so.]]></description>
<p>I have purchased the HA Green already LOL.  I was determined.  Now less so.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32939</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32938</link>
                        <pubDate>Sun, 11 Aug 2024 13:50:47 +0000</pubDate>
                        <description><![CDATA[Frankly, @morgan, I suspected that would be your conclusion and if that means we&#039;ve saved you the cost of the Home Assistant Green then I&#039;ll still take that as a win.]]></description>
<p>Interesting reading but............... beyond my comprehension.  Reading the documentation on how to download and install HACS is enough to completely confuse me and make me realise that this isn't for me.  Thanks for trying guys, much appreciated, but I have to recognise my limitations.  It's all Greek to me. &#x1f606; </p>
<p>Frankly, @morgan, I suspected that would be your conclusion and if that means we've saved you the cost of the Home Assistant Green then I'll still take that as a win.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32938</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32937</link>
                        <pubDate>Sun, 11 Aug 2024 13:49:17 +0000</pubDate>
                        <description><![CDATA[Often, yes, but not necessarily. The TOU tariffs being discussed are costlier at peak demand and cheaper at periods of lower use. As a result, rather than thinking of exploiting those tariff...]]></description>
<p>And that's the issue isn't it?</p>
<p>For all the care Tim has taken to give us data in kWh, the final answer is in <span style="color: #666699"><strong>pounds sterling</strong></span>.</p>
<p>The 'solutions' we need to implement should be altruistic towards our neighbours and the grid.<br />The present range of tariffs are 'selfish' in that they favour <span style="color: #003300"><em>what's best for me</em></span>.</p>
<p>Often, yes, but not necessarily. The TOU tariffs being discussed are costlier at peak demand and cheaper at periods of lower use. As a result, rather than thinking of exploiting those tariffs as being selfish it's also reasonable to consider the lower prices as a reward for consumers doing the right thing. I'm well aware that's just sophistry but does it matter if someone's motivations are altruistic and they're rewarded vs acting selfishly in response to lower prices? If the resultant behaviour benefits everyone else that's a win either way isn't it?</p>
<p>Here's the 'Duck Curve' which <a style="color: #993366" title="Toodles" href="https://renewableheatinghub.co.uk/participant/toodles">@toodles</a> referred to above</p>
<figure contenteditable="false">
<div class="wpfa-item wpfa-img"><a title="EveningPeak" href="https://renewableheatinghub.co.uk/wp-content/uploads/wpforo/attachments/2297/7767-EveningPeak.png?x55038"><img class="lazy" style="max-width: 400px;max-height: 300px" title="EveningPeak" src="data:image/svg+xml,%3Csvg%20xmlns%3D%22http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg%22%20viewBox%3D%220%200%201%201%22%3E%3C%2Fsvg%3E" data-src="https://renewableheatinghub.co.uk/wp-content/uploads/wpforo/attachments/2297/thumbnail/7767-EveningPeak.png?x55038" alt="EveningPeak" /></a></div>
</figure>
<p>I've deliberately chosen a substation feed which <span style="text-decoration: underline">does</span> demonstrate that demand-curve pretty closely.<br />It's a 3-phase underground supply to a housing estate where a high proportion of households will be on prepayment meters.<br />By definition, they are unable to enjoy any of the ToU tariffs being discussed here.</p>
<blockquote>
<div class="wpforo-post-quote-head">
<div class="wpforo-post-quote-author"><strong> Posted by: @toodles </strong></div>
<div class="wpforo-post-quote-link"><a title="Go to original post" href="https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3#post-32921">↑</a></div>
</div>
<p>What inducements other than off-peak pricing could be adopted?</p>
<p>Where there's a lot of social-housing in close proximity, a 3-phase storage battery could be installed to <span style="text-decoration: underline">serve a number of households</span>.<br />Each house is then supplied with single-phase, as at present,<br />but the grid only 'sees' a low-level current across all 3 phases to recharge the battery as required.</p>
<p>That would facilitate:</p>
<li>electricity bills payed to the social-housing provider instead of a For-Profit energy supplier</li>
<li>lower cost per kWh because electricity is only taken from the grid when it has available capacity</li>
<li>the gradual removal of those iniquitous pre-pay meters</li>
<li>and a reduction in energy poverty.</li>
<p>What's not to like?</p>
<p>Subsidies for social-housing providers to install multi-property storage-battery hubs is <span style="text-decoration: underline">way</span> cheaper than trying to upgrade the 11kV Distribution Grid.</p>
<p>Now here I have to agree wholeheartedly. To be frank I don't really care if the solutions you've put forward are more altruistic or still pandering to selfishness because the key point for me is that you're tackling the situation for those who are most hamstrung. A solution only a few can afford means only a small proportion of the population are contributing to any improvement. A solution that works for the majority means everyone can become part of the answer and I applaud that approach.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32937</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32936</link>
                        <pubDate>Sun, 11 Aug 2024 13:35:25 +0000</pubDate>
                        <description><![CDATA[Not quite...
We here on the RHH Forum have a possible solution. &#x1f60e; 
National Grid&#039;s licence from Ofgem prohibits them from owning or controlling any generation or storage assets.
I...]]></description>
<p>So the NG has a solution (or at least an ‘easement’) to the present problem that would save costs and obviate the need to spend £Bn’s upgrading the distribution grid</p>
<p>Not quite...</p>
<p><span style="text-decoration: underline">We</span> here on the RHH Forum have a possible solution. &#x1f60e; </p>
<p>National Grid's licence from Ofgem prohibits them from owning or controlling any generation or storage assets.</p>
<p>I've thrown this idea into the melting pot precisely because this forum has a wealth of technically-astute contributors who could chew this over and tweek it into a viable proposal.</p>
<p>If others think this is worthy of further consideration, then let's move it out of this topic and into one of its own.<br />What's @editor  think?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32936</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32933</link>
                        <pubDate>Sun, 11 Aug 2024 13:27:18 +0000</pubDate>
                        <description><![CDATA[@transparent said: Subsidies for social-housing providers to install multi-property storage-battery hubs is way cheaper than trying to upgrade the 11kV Distribution Grid.
That is what I wan...]]></description>
                        <content:encoded><![CDATA[<p>@transparent said: <span>Subsidies for social-housing providers to install multi-property storage-battery hubs is </span><span>way</span><span> cheaper than trying to upgrade the 11kV Distribution Grid.</span></p>
<p>That is what I wanted to hear! So the NG has a solution (or at least an ‘easement’) to the present problem that would save costs and obviate the need to spend £Bn’s upgrading the distribution grid - so when can we expect to see these energy storage schemes get under way. Perhaps Mr. Milliband is working on it now? &#x1f609; Toodles.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/making-best-use-of-agile-with-a-battery-and-ashp/paged/3/#post-32933</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 16:52:32 by W3 Total Cache
