									Is it normal to use power from the grid when running off the battery? - Energy Storage				            </title>
            <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/</link>
            <lastBuildDate>Mon, 16 Nov 2026 10:38:41 +0000</lastBuildDate>
                        <title>RE: Is it normal to use power from the grid when running off the battery?</title>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56763</link>
                        <pubDate>Tue, 20 Jan 2026 22:12:39 +0000</pubDate>
                        <description><![CDATA[The reason I said the voltages vary slightly is because the Solis inverter has a screen that shows the grid and inverter voltages for each phase, along with A and W.  Also they are recorded ...]]></description>
                        <content:encoded><![CDATA[<p>The reason I said the voltages vary slightly is because the Solis inverter has a screen that shows the grid and inverter voltages for each phase, along with A and W.  Also they are recorded in the Soliscloud, at the usual 5 minute intervals, a snap shot from this morning when the voltage varied the most between the phases</p>
13705
<p>And I ahve just discovered that I can export that data from the Soliscloud.</p>
13706]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>JohnnyB</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56763</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56738</link>
                        <pubDate>Tue, 20 Jan 2026 16:30:30 +0000</pubDate>
                        <description><![CDATA[Agreed. In the Solis S6, the readings are via a dedicated meter that connects to an RS 435 port. Some of the data is relevant for export.
I say this, as the inverter also provides direct el...]]></description>
<p>I assume a single phase monitor would still work on a 3 phase board for single circuits but wouldn't be as accurate if trying to measure circuits on more than one phase as the voltages vary slightly.</p>
<p>Given inverters with the ability to export to the grid must, by law, stop exporting if the voltage goes above 253V (or thereabouts, I believe), I'm pretty sure all inverter manufacturers take care to ensure their kit can be accurate in its measurement of voltage. As a result, what I get via modbus from my inverter is, I believe, easily accurate enough for my purposes.</p>
<p>Agreed. In the Solis S6, the readings are via a dedicated meter that connects to an RS 435 port. Some of the data is relevant for export.</p>
<p>I say this, as the inverter also provides direct electricity data via modbus, about the electricity from its various ports. </p>
<p>And in the case of <span>@johnnyb </span>triphasic Solis, the modbus integration would also add it for the other two phases.  </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>Batpred</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56738</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56735</link>
                        <pubDate>Tue, 20 Jan 2026 16:18:19 +0000</pubDate>
                        <description><![CDATA[The relevant statute is this:
The &#039;Declared Voltage&#039; in GB is 230v RMS.
So the permissible range is 216.4v – 253v.
Equipment/appliances certified to G98/G99 must have detached themselve...]]></description>
<p>inverters with the ability to export to the grid must, by law, stop exporting if the voltage goes above 253V (or thereabouts, I believe)</p>
<p>The relevant statute is this:</p>
13701
<p>The 'Declared Voltage' in GB is 230v RMS.</p>
<p>So the permissible range is 216.4v – 253v.</p>
<p>Equipment/appliances certified to G98/G99 must have detached themselves from the grid by the time the voltage drops to 186v.</p>
<p>What happens between 186v and 216.4v is subject to voltage/time graphs, which are submitted to the ENA as part of the evidence for G98 certification.</p>
<p>In practice the DNO doesn't concern itself with that.<br />They generally record the average voltage over an interval of up to 10 minutes.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56735</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56734</link>
                        <pubDate>Tue, 20 Jan 2026 16:09:18 +0000</pubDate>
                        <description><![CDATA[As you can see from the timeline graph, when your Solis inverter takes electricity from the grid to recharge a battery, it lowers the voltage...... hence the fall of 11-volts at 00:30 this m...]]></description>
                        <content:encoded><![CDATA[<p>As you can see from the timeline graph, when your Solis inverter takes electricity from the grid to recharge a battery, it lowers the voltage...<br />... hence the fall of 11-volts at 00:30 this morning, followed by a further reduction to 224v by 01:00.</p>
<p>Measuring line voltage on the far end of a supply cable from a consumer unit isn't going to provide useful data about the grid.<br />It tells me more about the size of copper cable connecting your inverter!</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56734</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56731</link>
                        <pubDate>Tue, 20 Jan 2026 15:55:14 +0000</pubDate>
                        <description><![CDATA[@batpred, I have been pulling what the inverter believes to be the grid voltage for quite a long time now, and it has been VERY useful. My DNO - UK Power Networks - has been having some issu...]]></description>
<p>I have monitors 'out on the grid' and you'd be surprised just how much variation there is between phases (voltage and current).</p>
<p>It begs the question as to how a 3ph inverter 'decides' to use the phases evenly when re-charging a battery from the grid.<br />There would be a significant difference between a decision based on current than one based on kW.</p>
<p>This looks very interesting... using what would otherwise cause issues or be wasted. </p>
<p>Perhaps you and @majordennisbloodnok may be interested in this:  </p>
<p>Via the Solis modbus integration (so data going onto a pc via the solis modbus) and that I believe is coming from the meter that they supplied me with (via modbus as well - I think), I see the following data points for A.  There's A, B, C so I think these are phases. In my single phase  inverters, B and C are 0.. </p>
13700
<p>All the data can be charted..</p>
13699
<p>If this was from a Tuya clamp, I would not trust the figures. But they are probably from the Eastron meter that Solis supplied. </p>
<p>To be clear, on my HA, this is flimsy, but perhaps that can be avoided..</p>
<p>@batpred, I have been pulling what the inverter believes to be the grid voltage for quite a long time now, and it has been VERY useful. My DNO - UK Power Networks - has been having some issues recovering from a problem back in June last year, and this has meant some significant swings in voltage, all picked up by the inverter. As a result, I've been able to use the data held in HA as evidence for UKPN, and they have been prepared to rely on it as reliable grounds for despatching engineers (albeit the engineers would, of course, double check themselves once on site).</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/energy-storage/">Energy Storage</category>                        <dc:creator>Majordennisbloodnok</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56731</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56727</link>
                        <pubDate>Tue, 20 Jan 2026 15:17:20 +0000</pubDate>
                        <description><![CDATA[This looks very interesting... using what would otherwise cause issues or be wasted. 
Via the Solis modbus integration (so...]]></description>
13700
13699
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56727</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56725</link>
                        <pubDate>Tue, 20 Jan 2026 14:32:25 +0000</pubDate>
                        <description><![CDATA[Hah!
I have monitors &#039;out on the grid&#039; and you&#039;d be surprised just how much variation there is between phases (voltage and current).
It begs the question as to how a 3ph inverter &#039;decides&#039;...]]></description>
<p>Hah!</p>
<p>The timeline below has four '240v' monitors at different locations, all supplied from the same Primary substation.</p>
13698
<p>Ignore the red and purple lines because they're recording the output from two different inverters.</p>
<p>The other four lines show voltage variations all over the place.<br />However, I've been doing this long enough to be able to detect which sequences are the consequence of variations on an 11kV supply,<br />and which are due to changes being made by the DNO at the 33kV level (outside of the area being monitored).</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56725</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56716</link>
                        <pubDate>Tue, 20 Jan 2026 13:30:30 +0000</pubDate>
                        <description><![CDATA[I assumed they need to be connected to the supply to measure the volts to work out the kWh used so there needs to be a separate breaker. I guess it wouldn&#039;t need to be separate but the only ...]]></description>
<p>I hadn't expected that the Eastron meter would be given its own 3-ph breaker!<br />Is that because the electrician decided to supply it by using thinner wires, I wonder?</p>
<p>I assumed they need to be connected to the supply to measure the volts to work out the kWh used so there needs to be a separate breaker. I guess it wouldn't need to be separate but the only other 3ph breaker is for the inverter.  The board is much larger than it needs to be so there is plenty of space for another breaker. The right hand side of the board is fairly empty.</p>
<p>@batpred I'm looking to monitor 2 circuits on a single phase board so the type you are using is probably what I need.  My son bought a 3ph Vue monitor from Amazon as a Christmas present which will monitor up to 16 circuits on this board.  I assume a single phase monitor would still work on a 3 phase board for single circuits but wouldn't be as accurate if trying to measure circuits on more than one phase as the voltages vary slightly.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/4/#post-56716</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/3/#post-56679</link>
                        <pubDate>Tue, 20 Jan 2026 10:59:25 +0000</pubDate>
                        <description><![CDATA[The most common &#039;standard&#039; for clamps and shunts which read current is that their max output (at whatever current they&#039;re intended for) is 75mV.
You can either buy &#039;cheaply&#039; from suppliers ...]]></description>
                        <content:encoded><![CDATA[<p>The most common 'standard' for clamps and shunts which read current is that their max output (at whatever current they're intended for) is 75mV.</p>
<p>You can either buy 'cheaply' from suppliers on AliExpress,<br />or get a certified 'industry level' current sensor from <a href="https://www.sonnecy-shop.com/en/hall-sensors/hall-current-sensors.html?p=1" target="_blank" rel="noopener">Sonnency in Germany</a>.</p>
<p>The picture below shows a Battery Combiner Board being built with three different approaches to current measurement.<br />The red arrow points to a Hall Effect current sensor by Sonnency.</p>
13694
<p>As you'd expect, the level of technical support from Sonnency is excellent!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/3/#post-56679</guid>
                        <link>https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/3/#post-56659</link>
                        <pubDate>Mon, 19 Jan 2026 23:58:16 +0000</pubDate>
                        <description><![CDATA[Well, the Huawei CT clamps I have are 100amp and 230V.
So even if technically they would read a couple of triphasic live lines, the smartlife software would probably get confused. They are ...]]></description>
<p>I have a clamp meter similar to the one you have included but it doesn't record amps used. I'm looking for something that will record the electricity used over weeks and months. I think @batpred has linked to one he has.  I have seen the cheap ones of this type and wondered if they are reliable and reasonably accurately.</p>
<p>Well, the Huawei CT clamps I have are 100amp and 230V.</p>
<p>So even if technically they would read a couple of triphasic live lines, the smartlife software would probably get confused. They are also meant to be supplied from the same power the clamps are reading from </p>
<p>I did not find similar clamps for triphasic power.</p>
<p>But the Solis meter readings are available via modbus via the Solis so this could be an easy way to get them. In my case, I have the readings available via Home assistant (even if I have not found this setup particularly reliable for uninterrupted charting). &#x1f609;</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/energy-storage/is-it-normal-to-use-2-300w-from-the-grid-when-running-off-the-battery/paged/3/#post-56659</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-16 10:38:41 by W3 Total Cache
