									Shelly energy meter - Electricity, Tariffs, Monitoring, Electrics &amp; Providers				            </title>
            <link>https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/</link>
            <lastBuildDate>Tue, 21 Apr 2026 17:08:32 +0000</lastBuildDate>
                        <title>RE: Shelly energy meter</title>
                        <link>https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40168</link>
                        <pubDate>Tue, 14 Jan 2025 19:54:21 +0000</pubDate>
                        <description><![CDATA[@mikefl Thank you]]></description>
                        <content:encoded><![CDATA[@mikefl Thank you]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/electricity-providers/">Electricity, Tariffs, Monitoring, Electrics &amp; Providers</category>                        <dc:creator>Potatoman</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40168</guid>
                        <link>https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40166</link>
                        <pubDate>Tue, 14 Jan 2025 19:37:33 +0000</pubDate>
                        <description><![CDATA[I think all Shelly devices work the same - by default they&#039;ll be broadcasting a WiFi access point (AP) and you can connect your phone to that AP, and then the Shelly has a web interface at I...]]></description>
                        <content:encoded><![CDATA[<p>I think all Shelly devices work the same - by default they'll be broadcasting a WiFi access point (AP) and you can connect your phone to that AP, and then the Shelly has a web interface at IP address 192.168.33.1 -  you connect to that and then go into Settings -&gt; WiFi to connect the Shelly to your local network, and go from there.</p>
<p>In simple steps:</p>
<p>- power up the Shelly device</p>
<p>- look on your phone for a WiFi network called "ShellyXXXXXXXX" (usually mentions the type of device)</p>
<p>- once connected, use the browser on your phone to go to http://192.168.33.1</p>
<p>- from that web-page go to settings, and connect to your WiFi (you can set up the details for up to two WiFi networks I think)</p>
<p>(where 'phone' is mentioned above, 'laptop' or 'PC' will do - anything with a WiFi card that can be used to connect to the Shelly)</p>
<p>The Shelly docs are pretty good:</p>
<p>https://kb.shelly.cloud/knowledge-base/shelly-pro-1-web-interface-guide</p>
<p>btw, if you've changed the Shelly to disable its AP (which is wise once you're all set) and you can't find it when you scan for WiFi networks, then there's a reset procedure for the device (usually a small reset button on it somewhere) and that will do what it says on the tin.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/electricity-providers/">Electricity, Tariffs, Monitoring, Electrics &amp; Providers</category>                        <dc:creator>MikeFl</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40166</guid>
                        <link>https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40106</link>
                        <pubDate>Tue, 14 Jan 2025 07:16:45 +0000</pubDate>
                        <description><![CDATA[Happy to Google it for you &#x1f609;]]></description>
                        <content:encoded><![CDATA[<p>Happy to Google it for you &#x1f609; </p>
<p>https://shellystore.co.uk/wp-content/uploads/2021/05/ShellyEM_UserGuide_EN_v01.pdf</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/electricity-providers/">Electricity, Tariffs, Monitoring, Electrics &amp; Providers</category>                        <dc:creator>MPHB</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40106</guid>
                        <title>Shelly energy meter</title>
                        <link>https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40072</link>
                        <pubDate>Mon, 13 Jan 2025 15:06:47 +0000</pubDate>
                        <description><![CDATA[Hi, has anybody got a step-by-step installation guide to connect my Shelly energy meter to cloud/ phone. Thanks]]></description>
                        <content:encoded><![CDATA[<p>Hi, has anybody got a step-by-step installation guide to connect my Shelly energy meter to cloud/ phone. Thanks</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/electricity-providers/shelly-em/#post-40072</guid>
