									Plant Room Panel in Garage for ASHP, PV &amp; Battery - DIY				            </title>
            <link>https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/</link>
            <lastBuildDate>Sun, 11 Oct 2026 02:53:33 +0000</lastBuildDate>
                        <title>RE: Plant Room Panel in Garage for ASHP, PV &amp; Battery</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58454</link>
                        <pubDate>Mon, 09 Feb 2026 22:25:59 +0000</pubDate>
                        <description><![CDATA[@colinc 
Ours have their own LEDs, with plenty of colour.. But being indoors, we got as much of it covered as possible! &#x1f600;]]></description>
                        <content:encoded><![CDATA[<p>@colinc </p>
<p>Ours have their own LEDs, with plenty of colour.. But being indoors, we got as much of it covered as possible! &#x1f600;  </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Batpred</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58454</guid>
                        <link>https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58452</link>
                        <pubDate>Mon, 09 Feb 2026 21:46:36 +0000</pubDate>
                        <description><![CDATA[Thanks, @batpred , I will look into potential heat issues. The batteries and inverter will be floor-stacked; Sigenstore ... ie. &quot;Lego style&quot;. The Sig Gateway and other switch-gear will be wa...]]></description>
                        <content:encoded><![CDATA[<p>Thanks, @batpred , I will look into potential heat issues. The batteries and inverter will be floor-stacked; Sigenstore ... ie. "Lego style". The Sig Gateway and other switch-gear will be wall-mounted.</p>
<p>My thoughts are a panel will be more about aesthetic than function, given the equipment will be in the  darkest corner of a large garage. </p>
<p>Perhaps I should consider colour-sequencing LED strips ... &#x1f914; ...  then again, maybe not ... &#x1f923; </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>colinc</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58452</guid>
                        <link>https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58421</link>
                        <pubDate>Mon, 09 Feb 2026 18:00:46 +0000</pubDate>
                        <description><![CDATA[We have some of those breeze-blocks, so I can see why you would want to provide a separate support. 
The component that connects battery and PV (the inverter) can be a heavy piece of kit an...]]></description>
<p>I am planning to put a back-panel board for mounting equipment. Neither installer has stipulated whether their equipment is mounted on a board or onto the concrete 'breeze-block'  wall.</p>
<p>We have some of those breeze-blocks, so I can see why you would want to provide a separate support. </p>
<p>The component that connects battery and PV (the inverter) can be a heavy piece of kit and may get warm, so whatever material you use, it is likely that they will want to attach it to the wall behind the board and may have special requirement for the board. As for the batteries even if wall mounted, should not get as warm. lifepo4 batteries do not "like" any freezing temperatures.. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58421</guid>
                        <title>Plant Room Panel in Garage for ASHP, PV &amp; Battery</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58383</link>
                        <pubDate>Mon, 09 Feb 2026 10:31:06 +0000</pubDate>
                        <description><![CDATA[We are about install ASHP, PV, &amp; Battery. The &quot;control centre&quot; will be a space allocated along about ¼ of the back wall of our double-garage. PV/Battery and the ASHP installs are two dis...]]></description>
                        <content:encoded><![CDATA[<p>We are about install ASHP, PV, &amp; Battery. The "control centre" will be a space allocated along about ¼ of the back wall of our double-garage. PV/Battery and the ASHP installs are two discrete contracts over different timeframes.</p>
<p>1. Am I wasting resources here on pandering a tendency to have,  "a place for everything, and everything in it's place ?"</p>
<p>2. If others here have done this in their property, what  batten depth would suffice to mount an OSB board ?  I am thinking 50mm x 25mm tanalised batten.</p>
<p>Grateful for any views,  ... on both questions !</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/#post-58383</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-11 03:53:33 by W3 Total Cache
