									Pergola project - DIY				            </title>
            <link>https://renewableheatinghub.co.uk/forums/diy/pergola-project/</link>
            <lastBuildDate>Sun, 08 Nov 2026 01:48:41 +0000</lastBuildDate>
                        <title>Pergola project</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/pergola-project/#post-16090</link>
                        <pubDate>Thu, 09 Feb 2023 21:07:38 +0000</pubDate>
                        <description><![CDATA[Hello everyone! As well as considering my home heat &amp; energy setup after finding this forum, I wondered if anyone could impart any knowledge to my pergola build, in between sorting every...]]></description>
                        <content:encoded><![CDATA[<p>Hello everyone! As well as considering my home heat &amp; energy setup after finding this forum, I wondered if anyone could impart any knowledge to my pergola build, <em>in between sorting everyone's heating problems out!</em><br /><br />After a couple of summers of not getting around to it, I am determined to get a lean-to-pergola erected this year. My procrastination has mainly been down to a few issues I need to be sure of before commencing. Please refer to attached images.<br /><br />I want the pergola to cover the entire area of the raised patio which is 5m x 5m with a height of 2.3m to the centre of the 'decorative' brick course.</p>
<p>My idea is for the ledger board to be attached to the garage. I will then have 4 supporting posts (6"x6"?) against the back of</p>
<p>the low wall. My 1st doubt is how to secure the posts and would like advice please.<br /><br />Posts 1 &amp; 2 have a drain pipe underneath the patio so digging isn't an option. Post 1 can be secured to the bungalow wall IMO.</p>
<p>Posts 3 &amp; 4 could be dug and secured with concrete(?). Post 4 I have concerns as it is right in the corner of the raised patio area and I would suspect that digging will result in the collapse of the immediate earth? (image)<br /><br />Could Post 2 &amp; 3 be secured with a kind of 'above deck' post bracket? I would suggest a bracket for Post 4 too, but as you can see the paving bricks already seem to be falling away so I have concerns about solid foundations for Post 4 if I went for a bracket.<br /><br />These 4 posts would support the main beam (2"x8"?) which has a total length of 5m! The gap between posts 1 &amp; 2 and 3 &amp; 4 would be 1m leaving a span of 3m between 2 &amp; 3. There would also be a number of cross rafters from the ledger board to the main beam, which raises more doubts...</p>
<p>1) The main beam: a 5m length of 2x8 will be quite weighty I imagine. Will I need 1 beam or 2 (1 at either side of posts)</p>
<p>2) the 5m rafters will have no support along their span, is this unadvised? i guess the rafters aren't as thick/heavy as the main beam(s) but still, 5m might be a bit of an ask.<br /><br />-The light post would obv be removed - <br />- the low wall would be rebuilt to extend to hide posts.<br /><br />If anyone is able to offer any advice, it would be appreciated. <span class="ipsEmoji">🙏</span></p>
2964
2966
2965
2963
2962
<p><span class="ipsEmoji"> </span></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Si Fillo</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/pergola-project/#post-16090</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-08 01:48:41 by W3 Total Cache
