									Checking a fuse - DIY				            </title>
            <link>https://renewableheatinghub.co.uk/forums/diy/checking-a-fuse/</link>
            <lastBuildDate>Sun, 11 Oct 2026 20:29:27 +0000</lastBuildDate>
                        <title>RE: Checking a fuse</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/checking-a-fuse/#post-16429</link>
                        <pubDate>Thu, 16 Feb 2023 10:57:06 +0000</pubDate>
                        <description><![CDATA[If your multimeter has a resistance range, then remove the fuse and check for continuity. If the reading is showing open circuit, then obviously the fuse has blown.
Another simple way is to...]]></description>
<p>Is it possible to check if a fuse is working using a multimeter?</p>
<p>Our iBoost has stopped working and there is a fuse where it's plugged into the mains. It's a 13A fuse and I don't have a spare to hand – wanted to see if it's the fuse or if the iBoost itself has died.</p>
<p>If your multimeter has a resistance range, then remove the fuse and check for continuity. If the reading is showing open circuit, then obviously the fuse has blown.</p>
<p>Another simple way is to fit the fuse to a different item of equipment, lamp, hairdryer or similar, and check that it works. Obviously, don't fit a lower rated fuse to equipment with a higher operating rating.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Derek M</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/checking-a-fuse/#post-16429</guid>
                        <title>Checking a fuse</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/checking-a-fuse/#post-16425</link>
                        <pubDate>Thu, 16 Feb 2023 10:15:44 +0000</pubDate>
                        <description><![CDATA[Is it possible to check if a fuse is working using a multimeter?
Our iBoost has stopped working and there is a fuse where it&#039;s plugged into the mains. It&#039;s a 13A fuse and I don&#039;t have a spa...]]></description>
                        <content:encoded><![CDATA[<p>Is it possible to check if a fuse is working using a multimeter?</p>
<p>Our iBoost has stopped working and there is a fuse where it's plugged into the mains. It's a 13A fuse and I don't have a spare to hand – wanted to see if it's the fuse or if the iBoost itself has died.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/checking-a-fuse/#post-16425</guid>
Served from: renewableheatinghub.co.uk @ 2026-10-11 21:29:27 by W3 Total Cache
