									DIY - Renewable Heating Hub Forums				            </title>
            <link>https://renewableheatinghub.co.uk/forums/diy/</link>
            <lastBuildDate>Thu, 12 Mar 2026 23:27:52 +0000</lastBuildDate>
                        <title>Plant Room Panel in Garage for ASHP, PV &amp; Battery</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/</link>
                        <pubDate>Mon, 09 Feb 2026 10:31:06 +0000</pubDate>
                        <description><![CDATA[We are about install ASHP, PV, &amp; Battery. The &quot;control centre&quot; will be a space allocated along about ¼ of the back wall of our double-garage. PV/Battery and the ASHP installs are two dis...]]></description>
                        <content:encoded><![CDATA[<p>We are about install ASHP, PV, &amp; Battery. The "control centre" will be a space allocated along about ¼ of the back wall of our double-garage. PV/Battery and the ASHP installs are two discrete contracts over different timeframes.</p>
<p>I am planning to put a back-panel board for mounting equipment. Neither installer has stipulated whether their equipment is mounted on a board or onto the concrete 'breeze-block'  wall.</p>
<p>1. Am I wasting resources here on pandering a tendency to have,  "a place for everything, and everything in it's place ?"</p>
<p>2. If others here have done this in their property, what  batten depth would suffice to mount an OSB board ?  I am thinking 50mm x 25mm tanalised batten.</p>
<p>Grateful for any views,  ... on both questions !</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>colinc</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/plant-room-panel-in-garage/</guid>
                        <title>Fitting new shower valve ..........</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/fitting-new-shower-valve/</link>
                        <pubDate>Tue, 29 Jul 2025 15:06:22 +0000</pubDate>
                        <description><![CDATA[This may be too generic but
I need to change the Thermostatic valve on our shower. Draining our old conventional system was straightforward (maybe it still is ? )
There is an isolator t...]]></description>
                        <content:encoded><![CDATA[<p>This may be too generic but</p>
<p>I need to change the Thermostatic valve on our shower. Draining our old conventional system was straightforward (maybe it still is ? )</p>
<p>There is an isolator tap in the "cold supply in pipe", if I close this and drain through the shower and bathroom taps will that empty the hot and cold sufficient to disconnect the shower ?</p>
<p>TIA  </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Lenny</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/fitting-new-shower-valve/</guid>
                        <title>How to Clean a Y-Strainer Filter</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/how-to-clean-a-y-strainer-filter/</link>
                        <pubDate>Tue, 10 Dec 2024 12:21:02 +0000</pubDate>
                        <description><![CDATA[Flow errors are among the most common issues homeowners face with their heat pumps, as discussed on the Renewable Heating Hub forums. Often, the culprit is a blocked Y-strainer filter, which...]]></description>
                        <content:encoded><![CDATA[<!-- wp:paragraph -->
<p>Flow errors are among the most common issues homeowners face with their heat pumps, as discussed on the <a href="//renewableheatinghub.co.uk/forums" target="_blank" rel="noopener" title="">Renewable Heating Hub forums</a>. Often, the culprit is a blocked Y-strainer filter, which can restrict the system’s flow and cause operational issues. The good news? Cleaning the filter is simple and can be done in a few easy steps.</p>
<!-- /wp:paragraph -->
<!-- wp:heading -->
<h4 class="wp-block-heading"><strong>Why Clean the Y-Strainer?</strong></h4>
<!-- /wp:heading -->
<p>The Y-strainer filter plays a crucial role in preventing debris from circulating through your heating system. Over time, sludge, rust and other particles can accumulate, leading to reduced efficiency or even flow errors. Regular maintenance helps keep your system running smoothly.</p>
<!-- wp:embed -->
<figure><div class="wp-block-embed__wrapper">
https://youtu.be/f_SZtIaM2LY
</div></figure>
<!-- /wp:embed -->
<!-- wp:heading -->
<h4 class="wp-block-heading"><strong>Step-by-Step Guide to Cleaning the Y-Strainer</strong></h4>
<p>1. <strong>Prepare</strong>: Grab a bowl or container to catch any water and a spanner or water pipe pliers.</p>
<p>2. <strong>Shut Down</strong>: Turn off the heat pump and wait for the distribution pumps to stop.</p>
<p>3. <strong>Isolate the Filter</strong>: Locate and close the valves on either side of the Y-strainer.</p>
<p>4. <strong>Loosen the Nut</strong>: Place your bowl underneath the strainer and use your spanner to loosen the nut (lefty loosey). Once loose, remove the nut by hand.</p>
<p>5. <strong>Clean the Filter</strong>: Take the gauze filter and nut to a sink. Rinse them thoroughly under running water, ensuring all debris is removed.</p>
<p>6. <strong>Inspect</strong>: Check the water collected in your bowl – it’ll give you an idea of how dirty your system is.</p>
<p>7. <strong>Reassemble</strong>: Reinsert the clean gauze filter into the nut and screw it back onto the strainer (righty tighty). Tighten by hand first, then snug it up with your spanner.</p>
<p>8. <strong>Check for Leaks</strong>: Slowly reopen the valves while watching for leaks. If there’s any seepage, isolate and re-tighten.</p>
<p>9. <strong>Restart</strong>: With no leaks and the valves fully open, restart your heat pump.</p>
<!-- wp:heading -->
<h4 class="wp-block-heading"><strong>When to Call for Help</strong></h4>
<p>If flow errors persist after cleaning the filter, the issue might lie elsewhere. Consult a heating engineer or your heat pump manufacturer for further support.</p>
<p>Routine cleaning of the Y-strainer can significantly enhance your system’s performance, keeping your home warm and your heat pump efficient.</p>
<!-- /wp:paragraph -->]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/how-to-clean-a-y-strainer-filter/</guid>
                        <title>Draining and refilling ASHP.</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/draining-and-refilling-ashp/</link>
                        <pubDate>Sun, 13 Oct 2024 13:24:13 +0000</pubDate>
                        <description><![CDATA[My install is months away but I am intending to make a few radiator changes in the bedrooms and wondering whether to do them beforehand or after the install in the summer? 
Draining and ref...]]></description>
                        <content:encoded><![CDATA[<p>My install is months away but I am intending to make a few radiator changes in the bedrooms and wondering whether to do them beforehand or after the install in the summer? </p>
<p>Draining and refilling my present system  is reasonably straightforward as it will be the upstairs rads only and I have some Fernox to replace what is lost but when the heat pump is in how much does water quality matter? Is it OK to refill and top up directly from the mains as at present? It will be water only, no glycol.</p>
<p>I live in the area supplied by South West Water which is from boreholes and subsequently hard (some kettle furring). At present our water has a TDS (total dissolved solids ) of 230. </p>
<p>My homebrew group got the following water report  from SWW  Ca2+ 65 Mg2+13 Na+ 10 Cl+32 So42- 20 Hco3- 193. if that helps.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Jancold</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/draining-and-refilling-ashp/</guid>
                        <title>Rising Damp – Production Recommendation</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/rising-damp-production-recommendation/</link>
                        <pubDate>Mon, 06 May 2024 08:30:47 +0000</pubDate>
                        <description><![CDATA[We&#039;ve noticed some rising damp around a window after this winter. I&#039;ve looked up solutions, and it typically involves removing the plasterboard and applying treatments. It&#039;s not something I&#039;...]]></description>
                        <content:encoded><![CDATA[<p><span>We've noticed some rising damp around a window after this winter. I've looked up solutions, and it typically involves removing the plasterboard and applying treatments. It's not something I'm keen on tackling at the moment. I vaguely remember seeing a product a while ago that involves sanding off the layer of paint in the affected area, applying it, and then painting over it again. Has anyone used a product like this that they can recommend?</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/rising-damp-production-recommendation/</guid>
                        <title>Gravel driveway</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/gravel-driveway/</link>
                        <pubDate>Fri, 05 Jan 2024 12:37:18 +0000</pubDate>
                        <description><![CDATA[Our main project for this year is our gravel driveway. As you can see from the attached photos there are two issues:
Grass and weeds growing through the gravel
Grass encroaching onto the...]]></description>
                        <content:encoded><![CDATA[<p>Our main project for this year is our gravel driveway. As you can see from the attached photos there are two issues:</p>
<li>Grass and weeds growing through the gravel</li>
<li>Grass encroaching onto the gravel from both sides</li>
<p>It's taken 5 years to get this point, so I wanted to do a hard reset and get it looking new. We don't like to use weedkillers like Round Up, so would like to tackle this project manually. I was thinking of a box scraper of some description. </p>
<p>If anyone has any creative ideas, please let me know.</p>
5714
5715
5716]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/gravel-driveway/</guid>
                        <title>Alexa help requested please.</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/alexa-help-requested-please/</link>
                        <pubDate>Sat, 09 Sep 2023 13:56:07 +0000</pubDate>
                        <description><![CDATA[I have Alexa (for one purpose only at this time) and would like to ask for advice.
The only use I make of it is for smart light bulbs control. When the house is vacant I like to have lights...]]></description>
                        <content:encoded><![CDATA[<p>I have Alexa (for one purpose only at this time) and would like to ask for advice.</p>
<p>The only use I make of it is for smart light bulbs control. When the house is vacant I like to have lights coming on and off in different rooms in order to simulate occupancy as a security measure.  The issue I have is the tedium of being required to physically enable 30+ routines on exit and the reverse on return.  I have Googled like a mad thing and cannot find an answer, work around or solution to my issue. <br /><br /></p>
<p>So to my question.  Is it possible to enable and disable all routines with a single voice command?  It would be a great advantage to be able to leave the house and issue a voice command of “Alexa enable all lights routines” or “Alexa enable security light routines” and similar on my return home.</p>
<p>If it’s at all possible can you please (PLEASE) make instructions or better still a walk through very simple as I’m not too hot with techie stuff such as this.</p>
<p>Many thanks in advance.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Morgan</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/alexa-help-requested-please/</guid>
                        <title>Sonic Wi-Fi: AI-powered leak detector</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/sonic-wi-fi-ai-powered-leak-detector/</link>
                        <pubDate>Tue, 22 Aug 2023 13:30:42 +0000</pubDate>
                        <description><![CDATA[Just came across this product which looks interesting – as the subject line implies, it&#039;s a leak detector. Has anyone tried it or anything similar:]]></description>
                        <content:encoded><![CDATA[<p>Just came across this product which looks interesting – as the subject line implies, it's a leak detector. Has anyone tried it or anything similar: https://tidd.ly/3KPZVfr</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/sonic-wi-fi-ai-powered-leak-detector/</guid>
                        <title>A question about voltage, batteries and battery operated tools</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/a-question-about-voltage-batteries-and-battery-operated-tools/</link>
                        <pubDate>Tue, 01 Aug 2023 08:23:30 +0000</pubDate>
                        <description><![CDATA[Can someone please explain this to me? Most battery operated tools are 24, 40, 48 or 60V.
To my understanding, you cannot use a 24V battery on a 48V tool because the motor in the tool is de...]]></description>
                        <content:encoded><![CDATA[<p>Can someone please explain this to me? Most battery operated tools are 24, 40, 48 or 60V.</p>
<p><span>To my understanding, you cannot use a 24V battery on a 48V tool because the motor in the tool is designed to run on a specific voltage, and using a lower voltage battery will not provide enough power to the motor, which could cause the motor to overheat and burn out. </span></p>
<p><span>Does the inverse apply? Will fitting a 48V battery into a 24V </span>tool cause the <span>motor to try and draw more current than it is designed for, leading to potential damage?</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/a-question-about-voltage-batteries-and-battery-operated-tools/</guid>
                        <title>Earth Bonding</title>
                        <link>https://renewableheatinghub.co.uk/forums/diy/earth-bonding/</link>
                        <pubDate>Sun, 23 Apr 2023 14:36:42 +0000</pubDate>
                        <description><![CDATA[Earth Bonding.
I have recently had my gas meter removed by Octopus Energy (no more gas standing charges!) as we are now all-electric. When OE took the meter out, they fitted an earth strap ...]]></description>
                        <content:encoded><![CDATA[<p><span style="font-size: 14pt">Earth Bonding.</span></p>
<p><span style="font-size: 14pt">I have recently had my gas meter removed by Octopus Energy (no more gas standing charges!) as we are now all-electric. When OE took the meter out, they fitted an earth strap across the still existing gas inlet point where it terminates with the valve and the other end was fitted to the gas inlet pipe to the house. I am wondering if I need to keep this bond - OE put the link in to be sure, to be sure. I have the DNO’s earth bond on the electrical feed to the house meter and also a 4 foot stake driven into the ground with heavy gauge strap fitted to the solar PV and Powerwall installation. Is there likely to be any good reason to maintain this old gas pipe earth bond any more please? Regards, Toodles.</span></p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/diy/">DIY</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/diy/earth-bonding/</guid>
